Old 1st November 2008, 22:38   #681  |  Link
You're wondering why DGAVCDecNV cannot use the GPU to encode the video?
It's very simple. DGAVCDecNV is a decoder, not an encoder.
Guest is offline
Old 1st November 2008, 23:38   #682  |  Link
elitondimer
OK, I understand. only 2 questions:
1 - It's possible use this plugin with the tmpgenc plus?
2 - you want to launch a video encoder with the power of the GPU?
elitondimer is offline
Old 1st November 2008, 23:50   #683  |  Link
If that application can open Avisynth scripts, then yes.
I never said anything about that. I make a decoder. Go talk to the guys that make encoders. It's OT for this thread, so please drop it.
Guest is offline
Old 2nd November 2008, 01:45   #684  |  Link
woah!
just to let you know, i saw a driver set on nvidia's site http://www.nvidia.com/object/winxp_180.43_beta.html
Version: 180.43 which crashes your server app on my setup anyways.. back to the GeForce Release 178 WHQL Version: 178.24 and all is good. i know they were beta and this is just for reference in case anyone else has issues...
woah! is offline
Old 2nd November 2008, 02:57   #685  |  Link
I've informed Nvidia. Thank you.
Guest is offline
Old 3rd November 2008, 04:56   #686  |  Link
saint-francis
too much lurking
saint-francis's Avatar
On some machines there may be a small performance improvement, but the main purpose of using CUDA is to get correct decoding for the streams that are not handled by libavcodec, and to access some of the post-processing capabilities of CUDA. Also, to add support for VC-1 in the future.
Does CoreAVC correctly handle the sources that libavcodec doesn't? If so then the advantage DGAVCdecNV has over it with directshowsource is frame accuracy?
This is an important question for me (as an ATI owner) and many others since ATI doesn't support CUDA and purchasing a new video card can be a big step.
saint-francis is offline
Old 3rd November 2008, 13:05   #687  |  Link
avivahl
@neuron2: I'm not really familiar with how it all works, but will it ever be possible to have a H.264 DirectShow decoder/filter that uses CUDA the way DGAVCDecNV does? Currently, MPC-HC and PowerDVD use DXVA (which is somewhat similar, but buggy/restricted)...
avivahl is offline
Old 3rd November 2008, 13:55   #688  |  Link
nm
The next version of CoreAVC should have similar CUDA support.
nm is offline
Old 3rd November 2008, 13:57   #689  |  Link
Yes, that is the point of DGAVCDecNV, to be a frame accurate Avisynth source filter. Many people also find DGAVCIndexNV to be a useful little app in its own right for quickly inspecting AVC streams, getting PIDs, seeing what audio is present, etc. The NV support also brings you the PureVideo deinterlacing. And it will bring you VC-1 support in the future. For some it also brings a performance inprovement when transcoding. For fast systems, that will be modest.
Guest is offline
Old 3rd November 2008, 14:00   #690  |  Link
Yes, of course. IIRC, CoreAVC plans to roll out CUDA support at some point.
Guest is offline
Old 3rd November 2008, 23:43   #691  |  Link
Devilman1
Do you plan to add ATI support? At the beginning of the post you said so, but I didn't see any other information.
Or the ATI decoding is not so friendly in this kind of operation?
Thanks
Devilman1 is offline
Old 3rd November 2008, 23:46   #692  |  Link
Sharc
.....DGAVCDecNV....... And it will bring you VC-1 support in the future .....
Good news! Much appreciated
Sharc is offline
Old 4th November 2008, 01:54   #693  |  Link
woah!
sorry to ask this again, but just to clear my mind of this, i know this is AVCindex but will you be adding mpeg2 NV decode to this app, or maybe to your other app DGIndex ?
avc and vc1 of course makes sense, but using purevideo to deinterlace mpeg2 content before passing to the encoder would be great i have lost the plot it seems...
woah! is offline
Old 4th November 2008, 02:09   #694  |  Link
It's possible but unlikely. I simply have too much on my plate already and I own an Nvidia card, so...
Guest is offline
Old 4th November 2008, 02:11   #695  |  Link
Originally Posted by woah! View Post
sorry to ask this again, but just to clear my mind of this, i know this is AVCindex but will you be adding mpeg2 NV decode to this app, or maybe to your other app DGIndex?
One way or another I will have CUDA support for MPEG2. It's a feature that I need myself, so the likliehood of rapid implementation is very high. Higher than VC-1. But right now I am just finishing up double rate deinterlacing for DGAVCDecNV.
Guest is offline
Old 4th November 2008, 03:51   #696  |  Link
Sagekilla
x264aholic
neuron2, is the double rate deint is already present in hardware? or did you have to do extra tricks with single rate to get double rate too?
Sagekilla is offline
Old 4th November 2008, 04:01   #697  |  Link
It's already present. The only trickiness needed is in the random access code of DGAVCDecodeNV. It uses a single instance of the decoder.
Guest is offline
Old 5th November 2008, 01:53   #698  |  Link
slip_
Hi!
I've muxed out a .264 file (from a Bluray disc with tsmuxer), and when I tried to load it the following error message is appeard:
GPU decoder: Failed to create video decoder [100]
CUDA driver, sdk, toolkit is installed, i've started the server application, and the dll file is in the right place (Windows\SysWOW64)
My pc details:
OS: Vista Business x64 SP1
CPU: AMD Athlon 64 X2 64 6000+
GPU: 8800GTS 320MB (NV50/G80 revision A2)
I hope that somebody can help me
slip_ is offline
Old 5th November 2008, 02:29   #699  |  Link
What Nvidia driver version are you running?
Guest is offline
Old 5th November 2008, 07:24   #700  |  Link
nm
G80 chips don't have VP2, so you'll need to get a new graphics card.
nm is offline
