21st July 2017, 14:40 | #21 | Link |
Only if he cuts up his changes in small chunks and adds new custom renderers instead of replacing current ones. Otherwise the risk of things breaking are too high. He doesn´t seems to want to do it this way, so chance is probably zero.
23rd July 2017, 09:07 | #22 | Link | |
Is there a chance that the sanear WASAPI audio renderer could support Windows Sonic/Dolby Atmos for headphones? It doesn't need to use the new API's, but as its designed the renderer won't actually output 5.1 or 7.1 to Windows if Sonic is enabled.
The reason for it is that sanear uses the GetMixFormat API, which will only output 2.0 if Sonic is selected. If it uses the IsFormatSupported API, Windows should report 7.1 if Sonic is enabled and output surround sound for Sonic to mix. Here's an explanation from a MSFT employee Quote:
26th July 2017, 13:10 | #23 | Link |
@clsid: the built-in internal audio renderer needs to be updated ASAP to the current master branch of sanear. That's the biggest bug that MPC-HC has for more than a year!
(You tried to compile it with it couple of months ago, and as I recall it it went fine. I use it as an external filter for more than a year and it's flawless.)
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
27th July 2017, 13:07 | #25 | Link |
No worries, I just wanted to put it in the log
6th August 2017, 19:15 | #26 | Link |
I just wanted to give a supportive comment. I really appreaciate that you are picking up the development of MPC-HC. This is by far my favourite player. I tried a lot VLC, MPC-BE, and many others, but in the end I always come back to MHC-HC.
Some features that I use a lot: - Download subtitles from subtitle sites from the playing movie in the app itself (can this be done on VLC? I don't think so, I always have to go a web browser download, and load manually.) - Easy to change subtitle and audio tracks (in MPC-BE it is still akward) - Unified Remote Full on my Android phone to act as a remote control (doesn't exist for MPC-BE, it exists for VLC) As for what features/bugs you develop: maybe make a wide table with scores on different criteria. Development time needed, complexity, urgency, usefullness, number of requests, etc. And from that table go for the low effort, high benefit development possibilities. All in all, the feature I love the most in MPC-HC is how it handles subtitles. It's so convenient to press D, and select the subtitles file from the list, it's incredible. My vote is to develop any features regarding subtitles, more sites, even more easier. Then, if we could have a dedicated button for changing audio and subtitle tracks in Unified Remote on Android, that would be great, but probably for this I have to ask them directly. Keep up the good work, and I'm looking forward to the next release! And a big thank you for keeping up the development! |
9th August 2017, 14:54 | #28 | Link |
I went ahead and made a pull request that allows sanear to support Windows Sonic/Dolby Atmos. Allows me to finally ditch the DirectSound/WaveOut renderers, and with the master branch it even supports enabling/disabling spatial sound during playback with live feedback.
https://github.com/alexmarsev/sanear/pull/19 I made a pull request here as well for MPC-HC's fork. It works for my stereo 24bit 44.1khz device, with surround sound output for surround content when Dolby Atmos is enabled, and stereo output when Dolby Atmos is disabled, stereo content is playing or if 'Exclusive mode' is enabled. The only thing I haven't tested is 'Exclusive mode' native surround output (such as a HDMI 7.1 output). Easy to test, just need to enable 'Exclusive mode' on a 5.1/7.1 native device and test that sanear plays and outputs 5.1/7.1 Also quick note, 'ignoreSystemChannelMixer' option should be set to false, else it will not output surround sound with Windows Sonic/Dolby Atmos. Last edited by ShadyCrab; 9th August 2017 at 15:17. |
15th August 2017, 12:44 | #29 | Link | |
For Android remote, the best is Remoti-co (I use it for about 4-5 years), I mentioned the modified version in mpc-hc main thread, search fort it. It also works with MPC-BE.
15th August 2017, 16:44 | #30 | Link | |
The integrated Sanear in MPC-HC is currently missing some options compared to standalone version. Maybe you are interested in adding those to settings window in MPC-HC? |
10th September 2017, 11:26 | #31 | Link | |
I created an issue half a year ago, I hope somebody (@kasper93) likes the idea. Thanks!
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config Last edited by chros; 15th November 2017 at 11:16. |
15th November 2017, 11:16 | #33 | Link |
17th November 2017, 20:34 | #35 | Link |
I don't think that will be any major update soon, probably only including newer LAVfilters, but we can do this manually if we want.
29th August 2021, 22:03 | #38 | Link |
Hey all, sorry for bumping an old thread. Is there a fix or workaround to get MPC-HC to output surround sound for Spatial Audio API's (sonic, dts headphone x and atmos for headphones) to virtualize? Currently it only outputs stereo if any spatial audio is enabled. LAV Audio codec is set not to mix anything, of course.
Thanks |
