Old 14th September 2008, 00:37   #101  |  Link
Ranguvar
Ranguvar's Avatar
Did you see my long post right before you announced a2? Just making sure, since you posted right after me and may not have seen it
And what do you mean? Just demux with MP4Box/mkvextract, which is what I did
Ranguvar is offline
Old 14th September 2008, 00:38   #102  |  Link
Originally Posted by Ranguvar View Post
I used the demuxed .h264 stream.
I tried your MP4 after demuxing with Yamb. I don't see any artifacts.
I'm not interested in installing any MKV demuxers.
Guest is offline
Old 14th September 2008, 00:43   #103  |  Link
Ranguvar
Ranguvar's Avatar
Must be my system then? I am definitely getting artifacts. Unfortunately, I can't show you a screenshot, as DGAVCIndexNV doesn't feel like detecting my card right now. Maybe later
Try the lossless one, though - the video is basically unwatchable for me at least.
EDIT: What?? Why? So you want me to demux the stream and then give it to you?
Ranguvar is offline
Old 14th September 2008, 00:51   #104  |  Link
Did you try demuxing with Yamb? I've heard of issues with MP4Box.
As I said, I'm not interested in installing any MKV tools.
If you have RAW or TS streams that play fine with CoreAVC and don't with DGAVCIndexNV, then I am interested, else not.
Guest is offline
Old 14th September 2008, 00:53   #105  |  Link
I have Windows XP Pro SP2 x64
You need to check whether CUDA video decoding is supported on 64-bit windows.
Guest is offline
Old 14th September 2008, 00:54   #106  |  Link
Ranguvar
Ranguvar's Avatar
YAMB is MP4Box. It's just a GUI for it. And actually, I did use YAMB.
You said you didn't want MKV tools after I suggested it (you edited).
And it should be, considering NVIDIA offers a CUDA driver specially for x64, which I am using.
Ranguvar is offline
Old 14th September 2008, 00:56   #107  |  Link
Ranguvar
Ranguvar's Avatar
Your attitude is in danger of turning me off.
I'm just confused as to why you have such an aversion to MKV. I'll upload the raw stream, if that's what it takes.
Ranguvar is offline
Old 14th September 2008, 00:56   #108  |  Link
Did I understand you correctly and you have 64-bit Windows?
Guest is offline
Old 14th September 2008, 00:57   #109  |  Link
Ranguvar
Ranguvar's Avatar
Yes
Ranguvar is offline
Old 14th September 2008, 00:58   #110  |  Link
I don't want to clutter my system with things I don't need or want.
I already demuxed it and played it with no problems, but if you'd like me to try your raw, we can rule out demuxing as the problem for you.
Guest is offline
Old 14th September 2008, 01:01   #111  |  Link
Did you install the 64-bit CUDA driver and toolkit from the Nvidia CUDA download site? Did you say yes to overwrite your current driver?
Guest is offline
Old 14th September 2008, 01:02   #112  |  Link
Ranguvar
Ranguvar's Avatar
Originally Posted by http://www.manifold.net/doc/nvidia_cuda.htm
We can get the most out of CUDA if the rest of our machine does not slow down the ability to feed the insatiable power of NVIDIA stream processors. For maximum speed we should use 64-bit Windows on at least a quad core machine with lots of RAM and large, fast disk drives. Before configuring a new 64-bit system, check the NVIDIA web site to make sure that 64-bit drivers are available for the Windows operating system you plan to install. At the present writing, Windows XP x64 has been used for development of x64 support by manifold.net.
blahblahforfivecharacterlimit
EDIT: Yes, I did
Ranguvar is offline
Old 14th September 2008, 01:07   #113  |  Link
Sagekilla
x264aholic
neuron2, I'll post the raw H.264 file demuxed from the mkv if you'd like. I believe I have a copy of it on my system somewhere.
Sagekilla is offline
Old 14th September 2008, 01:08   #114  |  Link
Sure, go ahead. Thank you.
Guest is offline
Old 14th September 2008, 01:08   #115  |  Link
@Ranguvar
Are you able to run the samples in the CUDA SDK?
Guest is offline
Old 14th September 2008, 01:17   #116  |  Link
Ranguvar
Ranguvar's Avatar
Uninstalled driver, rebooted, installed driver (CUDA WinXP x64), rebooted - exact same problems.
I will try, one second please.
Ranguvar is offline
Old 14th September 2008, 01:18   #117  |  Link
Sagekilla
x264aholic
Here's the Lossless Touhou sample, I wasn't able to get the other (mp4) one because I don't have a mp4 demuxer on my system at the moment. Still, this should be very helpful.
It'll be here: http://www.mediafire.com/?sharekey=5...db6fb9a8902bda, upload finishes in ~3 mins. They're 7zipped, if you're unable to extract 7z I'll see if I can cut a sample in half for you in a second.
Edit: What's the ETA on the decoder for Avisynth? I'd love to get a jump on it and try it on a blu-ray.
Old 14th September 2008, 01:25   #118  |  Link
Ranguvar
Ranguvar's Avatar
Yes, I can run the sample CUDA apps from the SDK (x64 SDK). (yes, it's XP, just skinned)
(I am using CUDA 2.0, for sure, don't know why it says 1.1)
Ranguvar is offline
Old 14th September 2008, 01:35   #119  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
Reboot.
yeah yeah, finally did the M$ Winblows fixall
working again on my XP x64.
also installed the cuda toolkit and sdk
custom x264 builds & patches | F@H | My Specs
kemuri-_9 is offline
Old 14th September 2008, 01:37   #120  |  Link
"It" means what? Sounds like you have a munged up install.
Guest is offline
