Old 28th October 2009, 13:35   #561  |  Link
kypec
User of free A/V tools
kypec's Avatar
Hi Zenitram,
could you please add to supported file extensions (which get associated with MediaInfo upon installation) also .264 besides .h264?
I ask for this because 264 is the default extension used by x264 encoder when desired output should be raw H264 stream.
Thank you very much.
kypec is offline   Reply With Quote
Old 28th October 2009, 13:41   #562  |  Link
Zenitram
Originally Posted by kypec View Post
could you please add to supported file extensions (which get associated with MediaInfo upon installation) also .264 besides .h264?.
Done. For next version (Friday)
Want to know all about your media files? http://mediaarea.net/MediaInfo
Zenitram is offline   Reply With Quote
Old 28th October 2009, 13:49   #563  |  Link
kypec
kypec's Avatar
Wow Feature implemented 6 minutes after request was made, that's what I call a support!
Old 28th October 2009, 19:33   #564  |  Link
b66pak
b66pak's Avatar
hi, can you add support for apple subtitles (sbtl) in .mp4, .m4v and .mov? here is a sample:
http://www.megaupload.com/?d=3Y3T1YQH
General
Complete name                    : sample.mov
Format                           : MPEG-4
Format profile                   : QuickTime
Codec ID                         : qt
File size                        : 13.2 MiB
Duration                         : 3mn 40s
Overall bit rate                 : 502 Kbps
Encoded date                     : UTC 2009-09-01 19:02:14
Tagged date                      : UTC 2009-09-01 19:02:16
com.apple.quicktime.player.movie : (Binary)
Video
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : Baseline@L3.0
Format settings, CABAC           : No
Format settings, ReFrames        : 5 frames
Codec ID                         : avc1
Codec ID/Info                    : Advanced Video Coding
Duration                         : 3mn 40s
Bit rate mode                    : Variable
Bit rate                         : 300 Kbps
Maximum bit rate                 : 751 Kbps
Width                            : 480 pixels
Height                           : 368 pixels
Display aspect ratio             : 4:3
Frame rate mode                  : Constant
Frame rate                       : 25.000 fps
Resolution                       : 24 bits
Colorimetry                      : 4:2:0
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.068
Stream size                      : 7.87 MiB (60%)
Writing library                  : x264 core 58 svn-735
Encoding settings                : cabac=0 / ref=5 / deblock=1:-2:-1 / analyse=0x1:0x111 / me=umh / subme=7 / brdo=0 / mixed_ref=1 / me_range=12 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=0 / mbaff=0 / bframes=0 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=300 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=16 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40
Encoded date                     : UTC 2009-08-31 17:58:23
Audio #1
Format                           : AAC
Format/Info                      : Advanced Audio Codec
Format version                   : Version 4
Format profile                   : LC
Format settings, SBR             : No
Codec ID                         : 40
Duration                         : 3mn 40s
Bit rate                         : 96.0 Kbps
Maximum bit rate                 : 103 Kbps
Channel(s)                       : 2 channels
Channel positions                : L R
Sampling rate                    : 48.0 KHz
Resolution                       : 16 bits
Stream size                      : 2.56 MiB (19%)
Encoded date                     : UTC 2009-08-31 17:58:24
Audio #2
Format                           : AAC
Format profile                   : LC
Codec ID                         : 40
Duration                         : 3mn 40s
Bit rate                         : 98.1 Kbps
Maximum bit rate                 : 102 Kbps
Stream size                      : 2.57 MiB (20%)
Text #1
Format                           : Timed text
Codec ID                         : tx3g
Duration                         : 2mn 0s
Bit rate                         : 71 bps
Stream size                      : 1.05 KiB (0%)
Text #2
Format                           : Timed text
Codec ID                         : tx3g
Duration                         : 2mn 0s
Bit rate                         : 71 bps
Text #3
Format                           : Timed text
Codec ID                         : tx3g
Duration                         : 2mn 0s
Bit rate                         : 63 bps
Stream size                      : 944 Bytes (0%)
Text #4
Format                           : Timed text
Codec ID                         : tx3g
Duration                         : 2mn 0s
Bit rate                         : 63 bps
Text #5
Format                           : Apple text
Codec ID                         : text
Duration                         : 3mn 40s
Bit rate                         : 10 bps
Stream size                      : 262 Bytes (0%)
Encoded date                     : UTC 2009-09-01 19:00:46
Text #6
Format                           : Apple text
Codec ID                         : text
Duration                         : 3mn 40s
Bit rate                         : 10 bps
Encoded date                     : UTC 2009-09-01 19:01:03
notice that track ID 4 to 7 are missing...the difference between a "tx3g" subtitle track and an "apple" subtitle track is "text" in first one and "sbtl" in second one in "moov\trak\mdia\hdls\componet subtype" atom...
_
Old 28th October 2009, 22:54   #565  |  Link
Zenitram
I added detection of "sbtl" subtype.
Note: subtype is for defining the kind of stream (Video, Audio, Text...), but what I saw is "tx3g" format in both cases ("text" or "sbtl" subtype). What I understood is that "text" in stsd is for "Apple Text" (the last 2 text tracks). In the case of "sbtl" subtype, I fill the "Muxing Mode" field with "sbtl", so you can detect if this is tx3g with "text" subtype (no Muxing mode info, this is the "default" muxing mode), tx3g with "sbtl" subtype (Muxing Mode info, this is not the "default" muxing mode), and text (Apple Text?) in "text" subtype.
Too much identifiers in MPEG-4!!!
Note about languages: I added language support for this kind of index ("old" Apple method, was implemented but deactivated because I had no file for it, now I have a file )
Note about text streams: VLC displays only 9 text streams, 1 less than me; Text #9 (Track #12) is not handled, this is the same format definition as Text #10 (Track #13), if you have an idea of the reason...
Below the output from the next version of MediaInfo:
General
Complete name                    : D:\Download\sample.mov
Format                           : MPEG-4
Codec ID                         : qt
Duration                         : 3mn 40s
Video
Format                           : AVC
Codec ID                         : avc1
Duration                         : 3mn 40s
Bit rate                         : 300 Kbps
Width                            : 480 pixels
Height                           : 368 pixels
Colorimetry                      : 4:2:0
Encoding settings                : (...)
Language                         : English
Audio #1
Format                           : AAC
Format profile                   : LC
Codec ID                         : 40
Duration                         : 3mn 40s
Language                         : English
Audio #2
Format                           : AAC
Format profile                   : LC
Codec ID                         : 40
Duration                         : 3mn 40s
Language                         : Spanish
Text #1
Format                           : Timed text
Muxing mode                      : sbtl
Codec ID                         : tx3g
Duration                         : 2mn 0s
Bit rate                         : 71 bps
Language                         : English
Text #2
Format                           : Timed text
Muxing mode                      : sbtl
Codec ID                         : tx3g
Duration                         : 2mn 0s
Bit rate                         : 71 bps
Language                         : Spanish
Text #3
Format                           : Timed text
Muxing mode                      : sbtl
Codec ID                         : tx3g
Duration                         : 2mn 0s
Bit rate                         : 63 bps
Language                         : French
Text #4
Format                           : Timed text
Muxing mode                      : sbtl
Codec ID                         : tx3g
Duration                         : 2mn 0s
Bit rate                         : 63 bps
Language                         : German
Text #5
Format                           : Timed text
Codec ID                         : tx3g
Duration                         : 2mn 0s
Bit rate                         : 71 bps
Language                         : English
Text #6
Format                           : Timed text
Codec ID                         : tx3g
Duration                         : 2mn 0s
Bit rate                         : 71 bps
Language                         : Spanish
Text #7
Format                           : Timed text
Codec ID                         : tx3g
Duration                         : 2mn 0s
Bit rate                         : 63 bps
Language                         : French
Text #8
Format                           : Timed text
Codec ID                         : tx3g
Duration                         : 2mn 0s
Bit rate                         : 63 bps
Language                         : German
Text #9
Format                           : Apple text
Codec ID                         : text
Duration                         : 3mn 40s
Bit rate                         : 10 bps
Language                         : English
Text #10
Format                           : Apple text
Codec ID                         : text
Duration                         : 3mn 40s
Bit rate                         : 10 bps
Language                         : Spanish
Old 29th October 2009, 10:04   #566  |  Link
Zenitram
Brazil2,
Originally Posted by Brazil2 View Post
I'm getting strange results with a MTS file recorded with a Panasonic TZ7:
And also MPC-HC, TsMuxer and MP4Box are all saying that the file is 50 FPS.
Example from MPC-HC:
Video: MPEG4 Video (H264) 1280x720 50.00fps [Video]
Audio: Dolby AC3 48000Hz stereo 192Kbps [Audio]
Theses tools are actually wrong.
After the release of the version with the patch for your file, I had feedback with fps problem.
I investigated a bit more, and I see my error now: raw stream (AVC) indication and timestamp are at 50 fps, container (PES level) timestamp is at 25 fps (crazy, but real)
Someone else sent me Panasonic SZ3 and HMC150 (like the TZ7, but from USA) records with the same problem (and the NTSC flag is present too, but this normal for them, so I iamgine Panasonic didn't remove the flag for Europe)
So I display both values:
Original frame rate              : 50.000 fps
(yes, SeeMoreDigital will not like it, I still use "original" word, I know :-D )
You can test the latest development snapshot (at least version 200910229):
http://sourceforge.net/projects/medi...t%20snapshots/
Old 29th October 2009, 19:22   #567  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
LOL.... You're right I don't.
Given that these "AVC-Lite" compatible cameras are generating AVC video streams with "repeat frames", I'd much prefer something like: -
Encoded Frame Rate        : 25.000 fps
Flagged Frame Rate        : 50.000 fps
Cheers
Old 29th October 2009, 20:38   #568  |  Link
b66pak
b66pak's Avatar
the last two text tracks are chapter tracks...the english one (text #9) contains chapters in english and is assigned to the english audio track...the spanish one (text #10) contains chapters in spanish and is assigned to the spanish audio track...play the file with Apple QuickTime and when you change the audio track the chapter language is changed accordingly...
Text #9
Format                           : Apple text
Codec ID                         : text
Duration                         : 3mn 40s
Bit rate                         : 10 bps
Language                         : English
Text #10
Format                           : Apple text
Codec ID                         : text
Duration                         : 3mn 40s
Bit rate                         : 10 bps
Language                         : Spanish
_
Old 1st November 2009, 12:07   #569  |  Link
Toddler Naruto
Playful Explorer
Toddler Naruto's Avatar
Thanks alot for releasing & maintaining MediaInfo, I think it's a very awesome tool !
Toddler Naruto is offline   Reply With Quote
Old 1st November 2009, 12:13   #570  |  Link
Zenitram
Spread the word ;-)
Old 9th November 2009, 17:28   #571  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Hi. Mediainfo shows that wavpack stream has 2 channels when actually its 5.1
Sample
Old 9th November 2009, 21:03   #572  |  Link
vlada
I have a problem with ffmpeg and I'm wondering if MediaInfo can help me. I always thought that for ffmpeg the first stream is video and next streams are audio. Now I have a MP4 file, which according to ffmpeg has stream #0 audio and stream #1 video. Can MediaInfo help me to detect such video files? How is the order of streams that ffmpeg uses defined?
vlada is offline   Reply With Quote
Old 9th November 2009, 21:14   #573  |  Link
Zenitram
First stream can be video, audio, text, timecode... There are no order policy in specifications, in MP4 or AVI or any format I know.
MediaInfo does not provide the order (why would it useful?), but provides the ID of a stream (in all views except "Easy View").
And usualy, first stream has ID 1, second stream has ID 2 and so on... I have many samples with Video ID = 2 and Audio ID = 1...
Old 9th November 2009, 21:46   #574  |  Link
vlada
Thank you for the quick reply. I checked the ID of audio stream and it was "1". So I thought the video stream will be 0 and didn't check it. Now I double checked and the IDs are exactly as you said. So I can use ID-1 as stream number for ffmpeg, that's perfect! Sorry for such a stupid question, I should have checked the IDs better.
Old 10th November 2009, 11:49   #575  |  Link
Zenitram
Thanks for the sample, corrected, will be available in the next official release.
Old 13th November 2009, 03:16   #576  |  Link
martinfrombern
how to get writing library information (e.g. encoder and version of it) in CLI version?
Tried things like --Inform=Video;%Writing_Library% and similar, but no success
martinfrombern is offline   Reply With Quote
Old 13th November 2009, 09:01   #577  |  Link
Zenitram
MediaInfo --Help for some help.
MediaInfo --Info-Parameters for the list of parameters
Encoded_Application : Software. Identifies the name of the software package used to create the file, such as Microsoft WaveEdit.
Encoded_Application/Url : Software. Identifies the name of the software package used to create the file, such as Microsoft WaveEdit.
Encoded_Library : Software used to create the file
Encoded_Library/String : Software used to create the file
Encoded_Library/Name : Info from the software
Encoded_Library/Version : Version of software
Encoded_Library/Date : Release date of software
Encoded_Library_Settings : Parameters used by the software
MediaInfo --Inform=Video;%Encoded_Library% or others depends of what is the precise field you want.
For having the "Inform" fields directly displayed, so you can see which field is interessant:
MediaInfo --Language=raw -f
Old 14th November 2009, 22:54   #578  |  Link
vlada
I thought it can't be that easy. Now I have a sample video with IDs 101 and 102 and ffmpeg refers the streams as 0 and 1. Another example is a DVD-Video I have. This is what MediaInfo tells me about the file:
Video
Format                           : MPEG Video
Format version                   : Version 2
Audio #1
Format                           : AC-3
Format/Info                      : Audio Coding 3
Audio #2
Format                           : AC-3
Audio #3
Format                           : AC-3
Audio #4
Format                           : AC-3
Text #1
Format                           : RLE
Format/Info                      : Run-length encoding
Text #2
Format                           : RLE
And now how ffmpeg sees the file:
I know this is more an ffmpeg issue, but maybe you know how to get the stream numbers that ffmpeg uses....
Old 14th November 2009, 23:49   #579  |  Link
Zenitram
Your image is not available.
So I don't understand the problem.
MediaInfo provides the ID of each stream, in the order of theses IDs, I have no idea about how FFMpeg works.
Last edited by Zenitram; 14th November 2009 at 23:50. Reason: understand --> don't understand
Old 15th November 2009, 10:47   #580  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
I think that vlada is confused by tracks numbers and tracks IDs...Here is a typical FFmpeg output from VOB file :
Duration: 00:06:37.28, start: 0.208056, bitrate: 7435 kb/s
Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 64:45 DAR 16:9]
, 9800 kb/s, 25 tbr, 90k tbn, 50 tbc
Stream #0.1[0x85]: Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s
Stream #0.2[0x84]: Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s
Stream #0.3[0x83]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
Stream #0.4[0x82]: Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s
Stream #0.5[0x81]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
Stream #0.6[0x80]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
Stream #0.7[0x2f]: Subtitle: dvdsub
Stream #0.8[0x31]: Subtitle: dvdsub
Stream #0.9[0x30]: Subtitle: dvdsub
Stream #0.10[0x2e]: Subtitle: dvdsub
Stream #0.11[0x2d]: Subtitle: dvdsub
Stream #0.12[0x2c]: Subtitle: dvdsub
Stream #0.13[0x2a]: Subtitle: dvdsub
Stream #0.14[0x29]: Subtitle: dvdsub
Stream #0.15[0x28]: Subtitle: dvdsub
Stream #0.16[0x25]: Subtitle: dvdsub
Stream #0.17[0x27]: Subtitle: dvdsub
Stream #0.18[0x26]: Subtitle: dvdsub
Stream #0.19[0x24]: Subtitle: dvdsub
In blue you have tracks IDs and in red tracks numbers...check out the FFmpeg documentation why you have 0.xx
About default's MediaInfo output : you have the track ID [ex: 0x80 (hexa) = 129 (integer)] & the track number corresponding [#1], etc...
