Old 19th January 2020, 09:58   #281  |  Link
staina
Originally Posted by a5180007 View Post
@staina it's already been entered as issue #126. We just need somebody to work on it.
Have you had time to test whether the 3D-plane bug has been solved with the latest bintray build ?
Here described progress is same as while using BDEdit either it is impossible immediately from tsMuxer create Bluray ISO. Issue #126 is old already 10 days and yet no work
Test 3D-plane - keep on don't work right.
Will added and support for Dolby Atmos without core used in the MKV?
Always test with latest available version. Thank for answer Staina
staina is offline   Reply With Quote
Old 19th January 2020, 11:14   #282  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
What BD3D do you use for your tests ?
r0lZ
Old 19th January 2020, 21:41   #283  |  Link
staina
Use The Hobbit: The Battle of the Five Armies and The Hobbit: The Desolation of Smaug
Old 19th January 2020, 23:05   #284  |  Link
a5180007
@staina This commit should hopefully solve the bug -waiting for merge.
Lots of code to write. Maybe there will be some good wills to do it, but it is above my c++ and Qt5 abilities.
a5180007 is offline   Reply With Quote
Old 20th January 2020, 06:02   #285  |  Link
a5180007
@staina @r0lZ could you please test the latest nightly bintray build.
Old 20th January 2020, 09:30   #286  |  Link
staina
Test 3D-plane - keep on don't work right. Testing The Hobbit: The Desolation of Smaug - red is different.
LOG from BD3D2MK3D
Streams of 00100.mpls, 1:36:05, 24 chapters, 00049.ssif :
Video : Und AVC, 1080p, 23.976 fps, right-eye
Video : Und MVC, 1080p, 23.976 fps, left-eye (32 3D-Planes)
Audio : Eng DTS-HD-Master, Multi-channel, 48 Khz
Audio : Ces AC3, Multi-channel, 48 Khz
Audio : Hun AC3, Multi-channel, 48 Khz
Audio : Pol AC3, Multi-channel, 48 Khz
Audio : Rus AC3, Multi-channel, 48 Khz
Subtitle: Eng PGS, 3D-plane: 1
Subtitle: Ara PGS, 3D-plane: 2
Subtitle: Ces PGS, 3D-plane: 3
Subtitle: Dan PGS, 3D-plane: 4
Subtitle: Est PGS, 3D-plane: 5
Subtitle: Fin PGS, 3D-plane: 6
Subtitle: Heb PGS, 3D-plane: 7
Subtitle: Hun PGS, 3D-plane: 8
Subtitle: Isl PGS, 3D-plane: 9
Subtitle: Nor PGS, 3D-plane: 10
Subtitle: Pol PGS, 3D-plane: 11
Subtitle: Por PGS, 3D-plane: 12
Subtitle: Ron PGS, 3D-plane: 12
Subtitle: Rus PGS, 3D-plane: 13
Subtitle: Swe PGS, 3D-plane: 14
LOG from tsMuxeR
V_MPEG4/ISO/MVC, "H:\BDMV\PLAYLIST\00100.mpls", insertSEI, contSPS, track=4114
V_MPEG4/ISO/AVC, "H:\BDMV\PLAYLIST\00100.mpls", insertSEI, contSPS, track=4113
A_DTS, "H:\BDMV\PLAYLIST\00100.mpls", track=4352, lang=eng
A_AC3, "H:\BDMV\PLAYLIST\00100.mpls", track=4353, lang=ces
A_AC3, "H:\BDMV\PLAYLIST\00100.mpls", track=4354, lang=hun
A_AC3, "H:\BDMV\PLAYLIST\00100.mpls", track=4355, lang=pol
A_AC3, "H:\BDMV\PLAYLIST\00100.mpls", track=4356, lang=rus
S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=1, track=4608, lang=eng
S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=2, track=4609, lang=ces
S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=3, track=4610, lang=ara
S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=4, track=4611, lang=dan
S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=5, track=4612, lang=est
S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=6, track=4613, lang=fin
S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=7, track=4614, lang=heb
S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=8, track=4615, lang=hun
S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=9, track=4616, lang=isl
S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=10, track=4617, lang=nor
S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=11, track=4618, lang=pol
S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=12, track=4619, lang=por
S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=12, track=4620, lang=ron
S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=13, track=4621, lang=rus
S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=14, track=4622, lang=swe
S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=3, track=4623, lang=ces
S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=8, track=4624, lang=hun
S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=11, track=4625, lang=pol
S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=13, track=4626, lang=rus
Old 20th January 2020, 22:27   #287  |  Link
a5180007
@staina thanks for the details, I have reproduced the bug with Hobbit Smaug and this patch should definitely correct it.
Edit: you can test the build on my fork https://github.com/jcdr428/tsMuxer/actions
Old 21st January 2020, 14:42   #288  |  Link
staina
3D-plane is OK.
Old 21st January 2020, 20:45   #289  |  Link
BloodyRipper
tsMuxeR developer(-ish)
BloodyRipper's Avatar
Originally Posted by imhh11 View Post
yep commas. changed that and now its working properly. thank you
You shouldn't need to change locale settings - fix for this issue was merged a dozen commits back, and it shouldn't occur with the latest nightly builds.
Nie poganiaj mnie, bo tracę oddech.
BloodyRipper is offline   Reply With Quote
Old 22nd January 2020, 11:01   #290  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
I can confirm that there are no 3D-Planes bugs any more in your fork.
And the "phantom streams" (present in the M2TS but unreferenced in the MPLS) are now clearly identified as such with "(PID not in MPLS)" instead of the confusing "3D-Plane: zero".
Great work ! Thanks !
r0lZ
Old 22nd January 2020, 20:53   #291  |  Link
a5180007
''Ability to detect audio delay for TS/M2TS/MPG/VOB/EVO sources;''
Could it be possible to add support to this ability for MKV sources as well ?
@imhh11 Please try last build 8052afb on my fork https://github.com/jcdr428/tsMuxer/actions .
I will push the patch when it is confirmed it is working well.
Old 22nd January 2020, 21:09   #292  |  Link
imhh11
Yes, it's working.
Awesome work, thank you !
imhh11 is offline   Reply With Quote
Old 23rd January 2020, 06:20   #293  |  Link
a5180007
Yes, it's working.
Good ! The patch has been merged and is in the nightly-2020-01-23--01-09-23.
Old 23rd January 2020, 18:21   #294  |  Link
manolito
manolito's Avatar
Thanks very much a5180007 for this latest nightly...
On my ancient computer (P3 without SSE2, WinXP) the last working tsMuxeR version used to be 2.6.12 from 2014.
Your builds are different. The GUI does not work (as expected), but the CLI executable works like a charm. And it runs beautifully under the old GUI, I have not found any issues so far.
Thanks again
manolito
Old 23rd January 2020, 18:30   #295  |  Link
FilipeAmadeuO
Thanks again
manolito
Have you tried the latest versions from here:
https://www.videohelp.com/software/tsMuxeR
FilipeAmadeuO is offline   Reply With Quote
Old 23rd January 2020, 20:32   #296  |  Link
manolito
manolito's Avatar
These versions are identical.
Old 23rd January 2020, 20:40   #297  |  Link
BloodyRipper
The GUI will keep on working as long as the "protocol" used to communicate between the CLI and the GUI isn't changed. This isn't planned so far, but keep in mind that it might change without notice. Any new features also *might* impact the "protocol" so that something stops working suddenly when using the old GUI.
Unfortunately, I'm afraid I don't have good news for you regarding the GUI : Qt has required SSE2 support in all builds since version 5.3.0. As for the CLI, it's a consequence of building the Windows versions with MinGW, which uses legacy x87 instructions by default. MSVC, on the other hand, has enabled SSE2 by default since Visual Studio 2012 or so. Roman's own tsMuxeR builds were most possibly made with MSVC.
Old 24th January 2020, 08:22   #298  |  Link
maxibon
Could someone check please?, TSMuxer hide subtitles when I try to replace the spa (latin) with spa (spain). For instance:
Source:
PLAYLIST REPORT:
Length:                 2:13:04.976 (h:m:s.ms)
Total Bitrate:          55.30 Mbps
VIDEO:
Codec                   Bitrate             Description
MPEG-H HEVC Video       46163 kbps          2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 10 bits / HDR10 / BT.2020
AUDIO:
Codec                           Language        Bitrate         Description
DTS-HD Master Audio             English         4545 kbps       7.1 / 48 kHz /  4545 kbps / 24-bit (DTS Core: 5.1 / 48 kHz /  1509 kbps / 24-bit)
Dolby Digital Audio             English         448 kbps        5.1 / 48 kHz /   448 kbps / DN -31dB
Dolby Digital Audio             Spanish         448 kbps        5.1 / 48 kHz /   448 kbps / DN -31dB
Dolby Digital Audio             French          448 kbps        5.1 / 48 kHz /   448 kbps / DN -31dB
Dolby Digital Audio             English         224 kbps        2.0 / 48 kHz /   224 kbps / DN -31dB
SUBTITLES:
Presentation Graphics           English         53.456 kbps
Presentation Graphics           Spanish         38.371 kbps
Presentation Graphics           French          41.440 kbps
Presentation Graphics           English         81.546 kbps
Presentation Graphics           Spanish         71.088 kbps
Presentation Graphics           French          76.848 kbps
After replace clpi, m2ts and preserving the mpls the result is:
Disc Title: XXXXXXXX
Disc Label:XXXXXXXXXXXX
Disc Size: 57,680,873,663 bytes
Protection: AACS2
Playlist: 00800.MPLS
Length: 2:13:04.976
Total Bitrate: 0.00 Mbps
Video: MPEG-H HEVC Video / 0 kbps / 2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 10 bits / HDR10 / BT.2020
Audio: English / DTS-HD Master Audio / 7.1 / 48 kHz / 24-bit (DTS Core: 5.1 / 48 kHz /  1509 kbps / 24-bit)
Audio: English / Dolby Digital Audio / 5.1 / 48 kHz /   448 kbps / DN -31dB
Audio: Spanish / DTS Audio / 5.1 / 48 kHz /   768 kbps / 24-bit
Audio: French / Dolby Digital Audio / 5.1 / 48 kHz /   448 kbps / DN -31dB
Audio: English / Dolby Digital Audio / 2.0 / 48 kHz /   224 kbps / DN -31dB
* Subtitle: English / 0.000 kbps
* Subtitle: Spanish / 0.000 kbps
* Subtitle: French / 0.000 kbps
So subtitles doesn't work
Am I doing something wrong?
Regards
maxibon is offline   Reply With Quote
Old 24th January 2020, 16:14   #299  |  Link
Hart2hart
Quick status that is now old news but Iíve ripped and remuxed 4 movie only from UHD disks with Dolby Vision. They all play with audio video and subtitles in sync for at least 10-30 minutes that I watched.
Donít have a DV player or TV so canít comment on that but itís is in the stream.
Fantastic!
Hart2hart is offline   Reply With Quote
Old 24th January 2020, 18:05   #300  |  Link
filler56789
SuperVirus
filler56789's Avatar
The Windows binaries of tsMuxeR, you meant.
Yes, you can be sure they were made with MSVC, not with MinGW-w64&&MSYS. The original source-code was messy as Hell, but at least it didn't require a posix-threaded compiler without a very-good reason.
Last edited by filler56789; 24th January 2020 at 18:11. Reason: wrong link removed
filler56789 is offline   Reply With Quote
