Old 24th September 2014, 14:58   #21  |  Link
Reel.Deel
A while back I did some speed test with different versions of MVTools. Results were similar to Keiyakusha's; MVTools from SVP is faster than the rest. On their website they claim MAnalyze to be faster. Maybe jackoneill can include this difference?
Originally Posted by SVP Team
MAnalyse
Can be faster than original version (with chroma=true) by 20-40%, look at PlaneOfBlocks.h for changes.
Old 24th September 2014, 15:55   #22  |  Link
Bloax
The speed of stupid
Bloax's Avatar
Mmm, sounds like I'll have to replace Avisynth soon.
Great news!
Bloax is offline   Reply With Quote
Old 24th September 2014, 21:58   #23  |  Link
Are_
Some more test, mvdegrain2 script above:
### 1 thread ###
## 720x480p ##
# AVISYNTH 2.6 Beta 5 - vanilla mvtools :: 7.21 fps
# VAPOURSYNTH WINDOWS 32bit :: 6.46 fps
# VAPOURSYNTH WINDOWS 64bit :: 7.99 fps
# VAPOURSYNTH LINUX 64bit :: 7.92 fps
## 1920x1080p ##
# AVISYNTH 2.6 Beta 5 - vanilla mvtools :: 1.09 fps
# VAPOURSYNTH WINDOWS 32bit :: 0.93 fps
# VAPOURSYNTH WINDOWS 64bit :: 1.09 fps
# VAPOURSYNTH LINUX 64bit :: 1.18 fps
### 8 threads ###
## 720x480p ##
# AVISYNTH 2.6 MT - vanilla mvtools :: 40.38 fps
# VAPOURSYNTH WINDOWS 32bit :: 37.24 fps
# VAPOURSYNTH WINDOWS 64bit :: 45.66 fps
# VAPOURSYNTH LINUX 64bit :: 47.06 fps
## 1920x1080p ##
# AVISYNTH 2.6 Beta 5 - vanilla mvtools :: 6.08 fps
# VAPOURSYNTH WINDOWS 32bit :: 4.95 fps
# VAPOURSYNTH WINDOWS 64bit :: 5.78 fps
# VAPOURSYNTH LINUX 64bit :: 6.53 fps
Are_ is offline   Reply With Quote
Old 25th September 2014, 08:51   #24  |  Link
Groucho2004
Originally Posted by Keiyakusha View Post
Even with avs 2.6 MT avsmeter displays more threads than the number we set in "setmtmode". For whatever reason.
But yeah, I wondered why I have the whole 20+ threads. This explains it!
AVSMeter displays the the number of threads spawned by avisynth and all loaded modules (DLLs). If a module spawns multiple threads itself (in combination with AVSTP, for example), they will of course be added to the thread count.
Old 25th September 2014, 11:05   #25  |  Link
Mystery Keeper
Beyond Kawaii
Mystery Keeper's Avatar
Concerning the speed: building it with MSVC would probably help.
...desu!
Mystery Keeper is offline   Reply With Quote
Old 28th September 2014, 12:31   #26  |  Link
jackoneill
unsigned int
jackoneill's Avatar
v2.0 is out.
The last two filters used by QTGMC are now available. I'm curious how these two perform compared to the original Avisynth plugin, because I replaced some inline asm with C code.
If you're feeling grateful for this and other VapourSynth ports, maybe buy me an ebook.
Buy me a "coffee" and/or hire me to write code!
jackoneill is offline   Reply With Quote
Old 28th September 2014, 13:39   #27  |  Link
Mystery Keeper
Beyond Kawaii
What a glorious day! Thank you very much for your hard work!
...desu!
Old 28th September 2014, 15:48   #28  |  Link
Reel.Deel
Good day indeed . Is there an accurate way to measure speed/performance in VS?
Old 28th September 2014, 16:01   #29  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
vspipe?
BTW, with the script posted on the 1st page, speed is about the same for 2.0 build. But I it doesn't uses "last two filters". Still QTGMC overall was slower with vapour-mvtools so with these filters speed will probably be same as before at best. This means we're still somehow dependent on avisynth plugin in case of x86 architecture.
Old 28th September 2014, 22:37   #30  |  Link
Are_
Here we go.
Source was 720x480p. MPEG2Source for avisynth, d2vsource for vapoursynth.
super = core.mv.Super(src)
mvbw = core.mv.Analyse(super, isb=True, delta=1, overlap=4)
mvfw = core.mv.Analyse(super, isb=False, delta=1, overlap=4)
out = core.mv.FlowBlur(clip=src, super=super, mvbw=mvbw, mvfw=mvfw, blur=100)
1 thread
11.60 fps
9.92 fps
11.80 fps
12.00 fps
8 threads
57.76 fps
55.96 fps
65.95 fps
69.11 fps
vectors = core.mv.Analyse(super, isb=False, delta=1, overlap=4)
out = core.mv.Mask(src, vectors)
1 thread
27.81 fps
24.22
28.46 fps
31.01 fps
8 threads
108.77 fps
130.80 fps
151.90 fps
168.53 fps
Old 28th September 2014, 23:20   #31  |  Link
Revgen
Thank you jackoneill!
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake?
Curly: Burned at the stake!
Moe: Why?
Curly: A hot steak is always better than a cold chop.
Revgen is offline   Reply With Quote
Old 1st October 2014, 16:53   #32  |  Link
jackoneill
unsigned int
jackoneill's Avatar
Originally Posted by HolyWu View Post
May I request that MFlowInter be ported as well, which is used by Firesledge's ivtc_txt60mc function.
ivtc_txt60mc is a useful function.
Old 3rd October 2014, 15:11   #33  |  Link
jackoneill
unsigned int
jackoneill's Avatar
v3 is out. It includes FlowInter and fixes for two problems.
I realised that a single version number is sufficient.
Old 3rd October 2014, 16:47   #34  |  Link
feisty2
I'm Siri
feisty2's Avatar
add mdegrainN and multivectors functions maybe?
large time radius could be kinda useful along with dct=1 to those "shivering" kinda clips
feisty2 is offline   Reply With Quote
Old 3rd October 2014, 17:48   #35  |  Link
jackoneill
unsigned int
jackoneill's Avatar
Maybe. What are these multivector functions?
Old 3rd October 2014, 18:08   #36  |  Link
feisty2
I'm Siri
feisty2's Avatar
they are from the modified version in ditherpackage
with "multi=true" in manalyse, a common vector clip will turn into multivectors clips
and the special multivectors clips can be passed to special functions like mdegrainN or mcompensate via "tr" parameter
Old 3rd October 2014, 18:17   #37  |  Link
feisty2
I'm Siri
feisty2's Avatar
vmulti=super.manalyse (delta=6,multi=true) is simply identical to
bv6=super.manalyse (delta=6,isb=true)
bv5
bv4
fv4
fv5
fv6
Old 3rd October 2014, 18:22   #38  |  Link
Mystery Keeper
Beyond Kawaii
feisty2, here is how I do it.
...desu!
Old 3rd October 2014, 18:30   #39  |  Link
feisty2
I'm Siri
feisty2's Avatar
wow, cool, thank you, Mystery Keeper
Old 3rd October 2014, 18:58   #40  |  Link
feisty2
I'm Siri
feisty2's Avatar
little pickle here, Mystery Keeper, what should I do if I want mdegrainn (tr=6) instead of mcompensate
