23rd February 2010, 14:52 | #402 | Link | |
retired developer
There is a "DRC" filter in HandBrake:
Detritus Software |
11th May 2010, 03:39 | #403 | Link |
Hi Sirber and was the only way to talk to the forum ticle is my first time and I'm dizatualizado about the information just to tell I wonder when will tar ready the new version of the Realanime Realanime7 that version 6 ja ta giving problem in almost all the videos from which fansub by ta dizatulizado when you will launch your website Detritus Software? And a site I used google to translate from Portuguese into English so that ja ta in English only to warn
11th May 2010, 12:32 | #404 | Link |
retired developer
ok... I barely understood but I'm not currently working actively on bencos and realanime.
best to post here what issues you're having as it may not be the softwares but the sources themselves or your system.
Detritus Software |
11th May 2010, 16:28 | #405 | Link |
The Sirber ta so is not having problem when I encode with realanime6 softsub videos with subtitles and I think so entrenched with hardsub videos in not getting so right ends encode encode video and leave all bad sound out of sync with the video and other problems and the size is also 50 mb out there is not why the fansub of them have updated their programs and realanime6 dizatualizado ta? one of the fansub that I can not encode the right is just to Anime no Sekai and before you know it was one that did not give me any trouble and realanime6 know when I encode the bar is like the% purcentos is get down on all issues 2, 3 sec every hour until the end of the encoder and I can only encode those videos with realanime6 now so after a time in the MeGUI encode! These are my problems. and I used the program to translate on google and you will not make a version of realanime7 not know when it will be ready?
11th May 2010, 16:54 | #406 | Link |
retired developer
please, the translation through google is barely readable and gives me headaches.
this thread is about bencos, not realanime 6. you aren't supposed to get delays using the old realanime 6 or bencos. what is your source? in Bencos 20100130, load the problematic source in the "Files" tab, right click on it, select "Info", then paste here the content of the Info popup.
Detritus Software |
11th May 2010, 23:39 | #407 | Link |
General
Complete name : F:\Videos de Fansubb\[#AnimeNSK]_Kiss_X_Sis_TV_-_05_[848x480_H264+AAC]_(03142E54).mkv Format : Matroska File size : 134 MiB Duration : 24mn 27s Overall bit rate : 765 Kbps Encoded date : UTC 2010-05-10 18:59:06 Writing application : mkvmerge v2.9.8 ('C'est le bon') built on Aug 13 2009 12:49:06 Writing library : libebml v0.7.7 + libmatroska v0.8.1 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.1 Format settings, CABAC : Yes Format settings, ReFrames : 8 frames Muxing mode : Container profile=Unknown@3.1 Codec ID : V_MPEG4/ISO/AVC Duration : 24mn 25s Width : 848 pixels Height : 480 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Resolution : 8 bits Colorimetry : 4:2:0 Scan type : Progressive Writing library : x264 core 94 r1583 7608d73 Encoding settings : cabac=1 / ref=8 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=0.00:0.00 / mixed_ref=1 / me_range=8 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / weightp=2 / keyint=300 / keyint_min=30 / scenecut=40 / intra_refresh=0 / rc_lookahead=80 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.80 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:0.00 Language : English Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format version : Version 4 Format profile : LC Format settings, SBR : Yes Format settings, PS : No Codec ID : A_AAC Duration : 24mn 27s Channel(s) : 2 channels Channel positions : L R Sampling rate : 48.0 KHz Menu 00:00:00.097 : en:00:00:00.097 |
11th May 2010, 23:43 | #408 | Link |
It was this source that you always tava contends that the error in audio with Benco else cool comes out and I'll tell you how I clean the configuration of Benco audio, 32 + sterio | Full Flitering, resize 848x480, IVTC and everything High, 44kHz, | Qualiti Video: High, bitrate 380,
General: anime / toons, Container MPEG-4 Video Codec MPEG4 AVC Audio Codec AAC HE + PS And it also happens with videos softsub and scored once encode law so that it had no sound and I do not use Track ID: Benco's got a problem and sorry for using the google translator it should not cause trouble and thanks for helping me e ai mostra como foi o video quando deu erro C:\Arquivos de programas\Bencos\mplayer.exe "F:\Videos de Fansubb\[#AnimeNSK]_Kiss_X_Sis_TV_-_05_[848x480_H264+AAC]_(03142E54).mkv" -ass -font "C:\Arquivos de programas\Bencos\Arial.ttf" -subfont-text-scale 5 MPlayer Sherpya-SVN-r30075-4.2.5 (C) 2000-2009 MPlayer Team getch2: 6 can't get number of input events [disabling console input] Playing F:\Videos de Fansubb\[#AnimeNSK]_Kiss_X_Sis_TV_-_05_[848x480_H264+AAC]_(03142E54).mkv. Matroska file format detected. VIDEO: [avc1] 848x480 24bpp 23.976 fps 0.0 kbps ( 0.0 kbyte/s) ========================================================================== Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family Fontconfig error: Cannot load default config file Unsupported PixelFormat -1 Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264) ========================================================================== ========================================================================== Opening audio decoder: [faad] AAC (MPEG2/4 Advanced Audio Coding) FAAD: compressed input bitrate missing, assuming 128kbit/s! AUDIO: 48000 Hz, 2 ch, s16le, 128.0 kbit/8.33% (ratio: 16000->192000) Selected audio codec: [faad] afm: faad (FAAD AAC (MPEG-2/MPEG-4 Audio)) ========================================================================== AO: [dsound] 48000Hz 2ch s16le (2 bytes per sample) Starting playback... Movie-Aspect is 1.77:1 - prescaling to correct movie aspect. VO: [directx] 848x480 => 848x480 Planar YV12 Fontconfig failed to select a font. Trying without fontconfig... New_Face failed. Maybe the font path is wrong. Please supply the text font file (~/.mplayer/subfont.ttf). subtitle font: load_sub_face failed. Fontconfig failed to select a font. Trying without fontconfig... New_Face failed. Maybe the font path is wrong. Please supply the text font file (~/.mplayer/subfont.ttf). subtitle font: load_sub_face failed. Exiting... (Quit) |
12th May 2010, 12:20 | #411 | Link |
retired developer
I can't say... I haven't played with Bencos2 for months (and longer for RA7). There's a lot going in my personal life and now the summer is here!
Detritus Software |
13th May 2010, 19:21 | #412 | Link |
Sirber Hi I am having problem to encode the Benco and you told me to use the latest version of Bence 20100130 I put the version I was using was from 2009 but I switched and am having trouble to encode after analyzing the part of encode the error dis me the settings to encode in 2010 Benco what I have to change to get good quality equal to the realanime6 and you will not launch this year's version realanime to 7?
21st May 2010, 04:54 | #413 | Link |
Sirber Hi I was wondering how to do one thing at Benco, I'm not getting that when I encode a video with subtitles softsub entrenched it encode the video and fas vicar in hardsub I wanted him to so encode the video and not also the captions to put together After the video the captions you know how I do it?
21st May 2010, 12:34 | #414 | Link |
retired developer
per moderator request, I cannot help you with these issues. sorry.
Detritus Software |
21st May 2010, 21:35 | #416 | Link |
retired developer
Bencos 2 will be ready before RealAnime 7, but since I'm not actively working on them....
Detritus Software |
23rd May 2010, 09:58 | #419 | Link |
And I really like the program realanime so I was wondering when the new version comes out in July I found very useful the realanime Benco but I did not like very few have problems with the video in softsub that transforms the caption with the video and changes the shape of encode with subtitles when it will be for video and softsub why my operating systems and Windons in Sirber and it seems that is not the same picture quality when it leaves the video encode compared to realanime or print it so? I use the version of Benco 2010 would not have this problem if I USACE 2009 version of the problem together encode the caption if softsub a video?
24th May 2010, 02:55 | #420 | Link |
Sirber Hi I was wondering when the Realanime version will be ready in July will tar tar that will ready this year though I have not got on with the Benco please answer my question of when the program Realanime Version 7 will tar prompt that I found realanime6 very useful to me! Please Respond
aac, bencos, gui, webm, x264 |
