Old 20th September 2024, 04:42   #1  |  Link
jay123210599
vspreview: Wrong Length in Time
I got a problem. When I entered a video in vspreview, it lasted for 18 minutes, but when I played it in a regular video player, it lasted for 23 minutes. How do I fix it do get the correct length of time?
jay123210599 is offline   Reply With Quote
Old 20th September 2024, 14:05   #2  |  Link
Selur
Selur's Avatar
1. try a different source filter
2. try (re-)muxing the video with mkvoolnix to mkv
Old 21st September 2024, 04:17   #3  |  Link
jay123210599
1. I am currently using core.lsmas.LWLibavSource. What other sources should I use?
2. The video is already a mkv file.
Old 21st September 2024, 08:42   #4  |  Link
Selur
Selur's Avatar
FFMS2, BestSource depending on the content and your GPU DGSource.
Does not matter, unless you already used mkvtoolnix/mkvmerge to create the file.
Cu Selur
Old 21st September 2024, 13:17   #5  |  Link
jay123210599
Cu Selur
Here's the information of my video. Which source should I use?
Format                                   : Matroska
Format version                           : Version 1
File size                                : 160 MiB
Duration                                 : 23 min 3 s
Overall bit rate                         : 973 kb/s
Frame rate                               : 23.976 FPS
Encoded date                             : 2008-10-08 17:28:25 UTC
Writing application                      : mkvmerge v2.2.0 ('Turn It On Again') built on Mar  4 2008 12:58:26
Writing library                          : libebml v0.7.7 + libmatroska v0.8.1
Video
Format                                   : MPEG-4 Visual
Format profile                           : Advanced Simple@L5
Format settings                          : BVOP2
Format settings, BVOP                    : 2
Format settings, QPel                    : No
Format settings, GMC                     : No warppoints
Format settings, Matrix                  : Default (H.263)
Codec ID                                 : V_MS/VFW/FOURCC / XVID
Codec ID/Hint                            : XviD
Bit rate                                 : 634 kb/s
Width                                    : 640 pixels
Height                                   : 480 pixels
Display aspect ratio                     : 4:3
Frame rate mode                          : Constant
Frame rate                               : 23.976 (23976/1000) FPS
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.086
Stream size                              : 105 MiB (65%)
Writing library                          : XviD 1.1.0 Beta1 (2005-01-16)
Language                                 : Japanese
Default                                  : Yes
Forced                                   : No
BPS                                      : 23.9762
Old 21st September 2024, 14:27   #6  |  Link
Selur
Selur's Avatar
Try both FFMS2 and BestSource.
Old 21st September 2024, 15:55   #7  |  Link
jay123210599
How do I try both at the same time with Vapoursynth?
Old 21st September 2024, 16:02   #8  |  Link
poisondeathray
You try one at time . If the first one works ok, there is no need to try the other
Old 21st September 2024, 18:34   #9  |  Link
jay123210599
It said: AttributeError: There is no function named FFMS2. Same goes for Best Source.
clip = core.lsmas.FFMS2(path to video)
clip = core.lsmas.BestSource(path to video)
Old 21st September 2024, 23:59   #10  |  Link
poisondeathray
Load the plugins(s)
Either put ffms2.dll / BestSource.dll in the plugins64 directory to autoload, or load them in the script with core.std.LoadPlugin
http://www.vapoursynth.com/doc/funct...std.LoadPlugin
Old 22nd September 2024, 00:06   #11  |  Link
jay123210599
Load the plugins(s)
There are already in the directory, now how do I autoload them? If not, how do I load them with my video?
Old 22nd September 2024, 00:51   #12  |  Link
poisondeathray
It should be
core.ffms2.Source
not "core.lsmas.FFMS2" ; lsmas is the namespace for L-Smash
Old 22nd September 2024, 00:51   #13  |  Link
Are_
Those lines are wrong, you are either trying to use one of these.
core.ffms2.Source()
core.bs.VideoSource()
core.lsmas.LibavSMASHSource()
Are_ is offline   Reply With Quote
Old 22nd September 2024, 01:40   #14  |  Link
jay123210599
@Are_ @poisondeathray @Selur Neither sources worked. I still haven't reach the full 23 minutes with the video. I also keep getting this:
"WARNING: Video Node 1: Had to assume these props which were unspecified or non-valid for preview <"_Matrix, _Primaries, _Transfer>"
Old 22nd September 2024, 02:05   #15  |  Link
_Al_
That is vspreview warning most likely because like any other previewer, it has to change vs.VideoNode (your clip) into rgb. So if those values are not in props (they were not read from a source plugin) it has to guess and default. To default, understand, means it might be wrong. Like in your case, where resolution is 640x480, it might guess matrix as BT601. To get rid of this warning set manually in your scirpts those props:
clip = clip.std.SetFrameProps(_Matrix=6, _Primaries=6, _Transfer=6)
or if your video is BT709 then:
clip = clip.std.SetFrameProps(_Matrix=1, _Primaries=1, _Transfer=1)
Also a previewer might have a choice to set a delay between frames or hard code fps for preview, look for it if it is there.
_Al_ is offline   Reply With Quote
Old 22nd September 2024, 13:27   #16  |  Link
jay123210599
It got rid of the warning, but it still doesn't fix the length.
Old 22nd September 2024, 15:58   #17  |  Link
Selur
Selur's Avatar
Did you try to remux the file?
'mkvmerge v2.2.0 ('Turn It On Again') built on Mar 4 2008 12:58:26', maybe current source filters have some issues with how 'mkvmerge v2.2.0' muxed stuff back then.
Old 22nd September 2024, 18:56   #18  |  Link
poisondeathray
What does
clip = core.text.ClipInfo(clip)
say about the length (frame count), and fps ?
Old 26th September 2024, 13:53   #19  |  Link
jay123210599
How do I remux a mkv file?
Old 26th September 2024, 14:18   #20  |  Link
jay123210599
What does
How do I use that for my vspreview script?
vapoursynth, video comparison, video player
