12th March 2013, 12:03 | #21 | Link |
i and j are clips not frames. (EDIT: The frame being worked on is current_frame)
It should work similarly to the previous script, you are just swapping apples for oranges. Both AverageLuma() and AudioMax() are just functions returning a float used in the conditional part of WriteFileIf(). EDIT: Instead of this: Code:
#This is the line that actually writes the frame number of the FIRST frame that falls below the threshold WriteFileIf(last, filename, "(AverageLuma(i)<blankthreshold)&&AverageLuma(j)>blankthreshold", "current_frame+1", append = false) Code:
#This is the line that actually writes the frame number of the FIRST frame that falls below the threshold WriteFileIf(last, filename, "(AudioMax(i,0) < -100) && AudioMax(j,0) > -100", "current_frame+1", append = false)
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 12th March 2013 at 12:13. |
12th March 2013, 12:20 | #22 | Link |
Avisynth language lover
However, I think johnmeyer's example is incorrect.
j=trim(i,1,0) #Previous frame Code:
j = SelectEvery(i,-1) |
12th March 2013, 12:29 | #23 | Link |
Have to admit to a little head scratching when I saw that and the current_frame+1 bit.
(guess I just thought 'must be right' and moved on). Would I be right in thinking that the output should then be on current_frame rather than current_frame+1. ? EDIT: on looking again, looks to me like the JM example outputs the frame number of the 1st frame after black frames, perhaps just labeled wrongly. EDIT: Below looks correct to me (not checked) Code:
j = SelectEvery(i,-1) # Previous frame #This is the line that actually writes the frame number of the FIRST frame that falls below the threshold WriteFileIf(last, filename, "(AverageLuma(i)<blankthreshold)&&AverageLuma(j)>blankthreshold", "current_frame", append = false) Code:
j = SelectEvery(i,-1) # Previous frame #This is the line that actually writes the frame number of the FIRST frame that falls below the threshold WriteFileIf(last, filename, "(AudioMax(i,0) < -100) && AudioMax(j,0) > -100", "current_frame", append = false)
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 12th March 2013 at 13:20. |
12th March 2013, 12:36 | #24 | Link | |
(I was assuming he used current_frame+1 to get frames numbered from 1 instead of 0, but it may just be a mistake.) |
12th March 2013, 18:04 | #25 | Link | |
As for the trim function, my comment was an error, and I modified my post to add to that comment to explain the error. |
avisynth, black, detection, frames |
