#681 | Link |
Big Bit Savings Now !
Wow. That is awesome. Just tried it here. Deep respect, VoodooFX.
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're working on that issue. Synce invntoin uf lingöage..." |
#682 | Link |
Now go do, that Voodoo, that you do so well:- https://www.youtube.com/watch?v=jS_Shu8y0sI
He/She/It does do so well ![]()
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 31st December 2022 at 10:21. |
#684 | Link |
Banana User
# Version 3.6 : 2023/01/12. New conditional: Auto max "Interp" for frames where logo is in ~solid background. # "Optimize" is split to "Optimize1" & "Optimize2". # Burnin version number into ebmp ["Ver-", positive analyze only]. ![]() ![]() ![]() |
#687 | Link | |||
Registered Amatuer
The video I'm working with:
https://drive.google.com/file/d/1B2m...ew?usp=sharing I'm getting a Avisynth Open Failure: Quote:
Usually I get a "Integer Divide by Zero" when there's a color space issue - it appears that might be the case here? Appreciate any help. Last edited by RidgeShark; 2nd March 2023 at 04:09. |
#689 | Link | ||
Registered Amatuer
https://drive.google.com/file/d/1jE-...usp=share_link The video's original form is a longer DVD VOB file. I converted it to Lagarith and kept the original YUV420 colorspace. But, I just tried to see if I could do a lossless MPEG2-only extraction of the needed footage using Mpg2Cut2, and it appears to have worked, so here's that if it can be helpful: https://drive.google.com/file/d/1vPY...usp=share_link And the full script: Quote:
#690 | Link |
Banana User
No issues here on your files.
Try to run your script without InpaintDelogo, see if you get no error. Then run script with only "Version()" in it and post its output. Then share the output of "AVSMeter.exe -avsinfo". [ https://forum.doom9.org/showthread.php?t=174797 ] |
#691 | Link | |
Registered Amatuer
Running Version(): ![]() AVSMeter Info: https://drive.google.com/file/d/1RF4...ew?usp=sharing |
#692 | Link | |
Banana User
![]() I see five masktools, two QTGMC, lots of other dupes... zillion random files there. For example: Code:
C:\Program Files (x86)\AviSynth+\plugins\MaskTools.dll [1.5.1.0, 2021-10-27] C:\Program Files (x86)\AviSynth+\plugins\masktools2-25.dll [2.1.0.0, 2021-10-27] C:\Program Files (x86)\AviSynth+\plugins\mt_masktools-25.dll [2.0.36.0, 2021-10-27] C:\Program Files (x86)\AviSynth+\plugins\mt_masktools-26.dll [2.0.36.0, 2021-10-27] C:\Program Files (x86)\AviSynth+\plugins\masktools2.dll [2.2.18.0, 2021-10-27] EDIT: Is it this DVD? -> https://www.amazon.com/Festival-of-3.../dp/B01GWCQA4O I didn't knew you could sell trailers for $129.99. ![]() Does the logo in those trailers go ON and OFF in every trailer like in your sample video? Last edited by VoodooFX; 4th March 2023 at 00:02. |
#693 | Link |
Hi, I'm trying to do my first delogo on a short anime episode from a Japanese TV channel.
I tried many settings, and I seem to have settled with these ones: Code:
LWLibAVVideoSource("D:\delogo.mkv") #InpaintDelogo(mask="D:\mask.bmp", Automask=1, aMix=2, Loc="1124,24,-52,-636", Analyze=2) InpaintDelogo(mask="D:\mask.bmp", Loc="1124,24,-52,-636", mode="both", Analyze=1, Inflate=2, Interp=2, IntSpd=4, oTune=3, optimize2=3, dpp=-3) ![]() Here is a before and after pic of frame 144: ![]() ![]() Unfortunately on some frames, the logo is still visible. Frame 1279 ![]() Is there anything I can do to improve it or is this the best I can achieve? I'll leave the drive link with the video and masks. Thanks in advance |
#694 | Link | ||
Banana User
Mode="Both" is wrong here, it's for semi-transparent logos, this logo is just transparent. You analyzed frames at the end with no logo + fade-out animation, trim out those parts for analysis. For settings like "IntSpd=4" leave 20px from the logo edges. Quote:
Trim(0,6960) InpaintDelogo(mask="D:\mask.bmp", Show=2, Loc="1114,14,-42,-626", mode="Deblend", Inflate=2, IntSpd=4, Optimize2=2, dPP=-5) ![]() |
#695 | Link | |
#696 | Link |
Deep respect, VoodooFX!!!
When using InpaintDelogo( mask="D:\003.png", Loc="0,0,0,0", Inflate=0 ) The color space is changing. see pictures 1. What should be changed in the script so that the color space does not change? 2. Is it possible to reduce the blur a little? Used version v3.6 and AviSynth+3.7.2 ![]() ![]() |
#698 | Link |
After processing
FFmpegSource2("X:\002.mp4") InpaintDelogo( mask="X:\002.png", Loc="0,0,0,0", Inflate=0 ) Files 1.002.mp4 https://drive.google.com/file/d/1Mku...usp=share_link 2.002.png https://drive.google.com/file/d/1KxJ...usp=share_link Loaded into DaVinci Resolve and compared the original file and the file processed by InpaintDelogo. |
#699 | Link |
Banana User
Color doesn't change for me, and it can't change because there is no colorspace conversion here.
Look at screenshots [001.mp4, frame 20]: Original: ![]() After inpainting: ![]() Your problem I guess is in the encoding settings. Share MediaInfo of your encoded file. For less blur try: Code:
InpaintDelogo( mask="X:\002.png", Loc="0,0,0,0", Inflate=0, oPPm=1, oPP=3) Last edited by VoodooFX; 3rd April 2023 at 02:16. |
delogo, hardsubs, ocr, remove, watermark |
