Old 1st May 2021, 18:23   #1021  |  Link
trevorjharris
Originally Posted by trevorjharris View Post
I have updated to Frim 1.31 64 bit and installed the example frim project into premiere pro cs6. When I try to export I get an empty file. The log is
Media SDK impl SOFTWARE (c:\UTL\FRIM\libmfxsw64.dll)
Media SDK version 1.28
Memory type System
Async depth 4
Input format I420
Encoder AVC
Input picture:
Resolution 1920x1088
PAR 1:1
Structure Progressive
Crop X,Y,W,H 0,0,1920,1080
Frame rate 23.976
Output picture:
PAR 1:1
Frame rate 23.976
Bitrate control VBR
avg,maximum 28000,40000
GOP structure:
GOP length 24
I-/P-frame distance 4
IDR-frame interval 0
GOP type Opened
Num of slices 6
Target usage 4 (balanced)
Encoded frames: 720
Processing finished in 0.20 seconds
As you can see it process the correct number of frames but the .h264 file is empty.
Please can someone help.
I tried this in Windows 7 so I think it might have something to do with Windows 10. Please can anyone help.
trevorjharris is offline   Reply With Quote
Old 1st May 2021, 23:20   #1022  |  Link
trevorjharris
What I meant to say was that it worker in windows 7. So I think that windows 10 broke it.
Old 2nd May 2021, 13:57   #1023  |  Link
trevorjharris
OK I solved it. I reinstalled premiere pro and all was well. The i420 problem using avisynth still does not work but at least I can use premiere. Thanks
Old 3rd May 2021, 15:16   #1024  |  Link
trevorjharris
Found a way to speedup frimencode
In premiere pro I tried rendering the first sequence with 2 video tracks to an intermediate using cineform. I then imported this back into Premiere and then exported it with Frimencode This was alot faster than exporting a sequence with a sequence in it. Frim encoding was about 14 times faster but encoding to an intermediate does take time.
Old 31st May 2022, 09:15   #1025  |  Link
3DJ
SBS MP4 to MVC 3D?
Howdy folks!
I've been trying to convert an NVIDIA 3D Vision 1080p60 gameplay recording in full-resolution SBS MP4 format to a single MVC 3D MKV (like BD3D MakeMKV rips) with the hopes of saving HDD space by encoding redundant data efficiently without losing significant quality.
But so far, I've only gotten errors and corrupted (colored static) video files and I'm not sure what I'm missing/doing wrong.
Input: https://www.dropbox.com/sh/nzdws2k4c...T0KH8wHxa?dl=0
Format                      : MPEG-4
Format profile              : Base Media
Codec ID                    : isom (isom/iso2/avc1/mp41)
File size                   : 69.0 MiB
Duration                    : 6 s 681 ms
Overall bit rate            : 86.7 Mb/s
encoder                     : Lavf58.76.100
Video
Format                      : AVC
Format/Info                 : Advanced Video Codec
Format profile              : High@L5.1
Format settings             : CABAC / 1 Ref Frames
Format settings, CABAC      : Yes
Format settings, Reference  : 1 frame
Format settings, GOP        : M=1, N=30
Codec ID                    : avc1
Codec ID/Info               : Advanced Video Coding
Source duration             : 6 s 714 ms
Bit rate                    : 85.6 Mb/s
Maximum bit rate            : 96.7 Mb/s
Width                       : 3 840 pixels
Height                      : 1 080 pixels
Display aspect ratio        : 3.556
Frame rate mode             : Variable
Frame rate                  : 59.724 FPS
Minimum frame rate          : 16.129 FPS
Maximum frame rate          : 620.690 FPS
Original frame rate         : 60.000 FPS
Standard                    : PAL
Color space                 : YUV
Chroma subsampling          : 4:2:0
Bit depth                   : 8 bits
Scan type                   : Progressive
Bits/(Pixel*Frame)          : 0.345
Stream size                 : 68.8 MiB (100%)
Source stream size          : 68.8 MiB (100%)
Title                       : VideoHandle
Writing library             : x264 core 164
Encoding settings           : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=85567 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Color range                 : Limited
Color primaries             : BT.601 NTSC
Transfer characteristics    : BT.601
Matrix coefficients         : BT.601
mdhd_Duration               : 6681
Codec configuration box     : avcC
Audio #1
Format                      : AAC LC
Format/Info                 : Advanced Audio Codec Low Complexity
Codec ID                    : mp4a-40-2
Source duration             : 6 s 664 ms
Bit rate mode               : Constant
Bit rate                    : 192 kb/s
Channel(s)                  : 2 channels
Channel layout              : L R
Sampling rate               : 48.0 kHz
Frame rate                  : 46.875 FPS (1024 SPF)
Compression mode            : Lossy
Stream size                 : 159 KiB (0%)
Source stream size          : 159 KiB (0%)
Title                       : SoundHandle
Default                     : Yes
Alternate group             : 1
Audio #2
Format                      : AAC LC
Duration                    : 6 s 680 ms
Source duration             : 6 s 674 ms
Bit rate                    : 117 kb/s
Stream size                 : 95.7 KiB (0%)
Source stream size          : 95.7 KiB (0%)
Title                       : SoundHandle
Default                     : Yes
Alternate group             : 2
mdhd_Duration               : 6680
Command:
FRIMEncode64 -i i1.mp4 -sbs 2 -o:mvc o1.mkv -size 1920 1080 -dstsize 1920 1080 -f 60 -dar 16:9
Output: https://www.dropbox.com/sh/845ikih2n...qbT9CVOqa?dl=0
FRIM Encoder version 1.31 - Win64 (build: Mar  8 2020)
 - based on Intel(R) Media SDK
Media SDK impl          HARDWARE (2) - D3D11 (C:\Windows\SYSTEM32\libmfxhw64.dll)
Media SDK version       1.34
Memory type             System
Async depth             4
Input  format           I420
Encoder                 AVC
Input picture:
  PAR                   1:1
  Frame rate            60.000
Output picture:
  PAR                   1:1
  Frame rate            60.000
Bitrate control         CBR
  bitrate               4717
GOP structure:
  GOP length            60
  GOP type              Opened
Num of slices           6
Processing started
Frame number: 11
Processing finished in 0.15 seconds
Not sure why it insists on 1920x1088 resolution even tho I already set
Here's how the output file looks:
3DJ is offline   Reply With Quote
Old 4th June 2022, 07:27   #1026  |  Link
videofan3d
[QUOTE=3DJ;1969736]Howdy folks!
FRIMEncode input must be planar YUV (more precisely yv12 pixel format) - not any kind of compressed container.
Also output is elementary stream .h264/.mvc which need to be multiplexed using tsMuxer.
Finally, I'm worried that 1080p60 is not standard for 3D-Bluray.
I always used only 1080p24 with my videos.
videofan3d is offline   Reply With Quote
Old 12th June 2022, 10:38   #1027  |  Link
3DJ
Woah, so the input must be a raw video? That sounds quite impractical, unless there's a way to pipe an ffmpeg uncompressed stream to avoid having to waste hundreds if not thousands of GBs?
The full video is like ~6hrs of 1080p60 3D (Side by Side so 2160 horizontal pixels).
I usually just upload my 3D videos onto YouTube but the quality drops noticeably even at "4K" resolution so I just wanted a more efficient method to store my 3D videos locally.
Old 12th June 2022, 17:06   #1028  |  Link
videofan3d
Certainly you can connect using pipes.
Check the FRIMEncode_readme.pdf document in the package and make few experiments - I'm sure you will find how to use it.
Old 20th June 2022, 17:12   #1029  |  Link
Cedvano
I would like to know if it's possible to create mkv with the combined output h264/mvc ?
When I use MkvToolNix, impossible to read with Sterescopic Player.
Thanks in advance.
Cedvano is offline   Reply With Quote
Old 20th June 2022, 20:29   #1030  |  Link
videofan3d
Originally Posted by Cedvano View Post
Thanks in advance.
Combined h264/mvc is specific elementary stream containing frames of both main-view and dependent-view, suitably multiplexed.
It is (probably) rarely used part of h264 MVC standard. As such, I doubt there is any available decoder who can even read it.
Furthermore to my knowledge, dependent view MVC elementary stream is not supported by MKVToolNix.
Author said in past that he will implement it if there will be demand but he wants to do it right.
Nowadays with decline of 3D I'd say there won't be any demand anymore. There are also no more mediaplayers capable of 3D.
Pity...
Old 22nd June 2022, 16:19   #1031  |  Link
Cedvano
Pity...
Thanks for your answer.
Old 9th January 2023, 08:53   #1032  |  Link
KSSW
FRIM_ x64_ version_ 1.31 Whether MVC can conform to Blu ray 3D
Scenarist BD V8 MUI Tips
Media SDK impl HARDWARE (2) - D3D11 (C:\windows\SYSTEM32\libmfxhw64.dll)
Media SDK version 1.35
Memory type System
Async depth 4
Input format I420
Encoder AVC
Input picture:
PAR 1:1
Frame rate 23.976
Output picture:
PAR 1:1
Frame rate 23.976
Bitrate control VBR
avg,maximum 35000,38000
GOP structure:
GOP length 24
I-/P-frame distance 3
GOP type Opened
Num of slices 6
Target usage 1 (quality)
Processing started
Frame number: 1438
Processing finished in 174.68 seconds
KSSW is offline   Reply With Quote
encoders, mvc
