Old 10th March 2010, 18:32   #1  |  Link
teeman
TEEMAN
Coded avs file errors
Can anybody help me with this error I get when trying to open the avs file in Virtual dub.
I have pasted my error below. I am not familiar with coding I believe I typed everything as it should if not could you please advise or send me to the proper help link
I run Win 7 64 bit
Adobe premier cs3
virtual dub
dbug frame server
aviSource("tomspractice.avi")
FlipHorizontal
greyscale
I get the following error
Virtual Dub Error
Avisynth open failure
avisource autodetect: couldn't open file "tomspractice.avi"
error code 2
(F:\manitougreenscreen\VIDEO\tomspractise.avs, line 1)
The beginning lesson would not open in wmp following your script
Teeman
teeman is offline   Reply With Quote
Old 10th March 2010, 19:35   #2  |  Link
osgZach
Never seen this error before, so just a stab in the dark:
Do you know what codec the video is encoded in? (AVI is a container, it could be Xvid, DivX, etc)
If you know what codec the video is encoded in, then you should find out whether or not you have the proper codec tools installed so you can decode it.
osgZach is offline   Reply With Quote
Old 10th March 2010, 21:33   #3  |  Link
IanB
Avisynth Developer
error code 2 = ERROR_FILE_NOT_FOUND
"tomspractice.avi" is not found in the same directory as "F:\manitougreenscreen\VIDEO\tomspractise.avs"
IanB is offline   Reply With Quote
Old 10th March 2010, 23:49   #4  |  Link
osgZach
haha wow.. how did I even miss that
Old 11th March 2010, 01:30   #5  |  Link
teeman
TEEMAN
I feel so stupid I will retry and again I apologize, I never noticed it.
Thanks Teeman
Old 11th March 2010, 01:44   #6  |  Link
osgZach
Don't sweat it, we all goof up on silly stuff sometimes
Old 11th March 2010, 05:06   #7  |  Link
teeman
TEEMAN
Same Error correct spelling
I redid and got the same error, any ideas
Teeman
Old 11th March 2010, 12:00   #8  |  Link
Gavino
Avisynth language lover
Is the avi file in the same directory (folder) as the script file? If not, you will need to use the full path name.
Old 12th March 2010, 22:10   #9  |  Link
rkalwaitis
Robert
Your not telling avisynth where the file is.
rkalwaitis is offline   Reply With Quote
avisynth, editing, errors, script, video
