16th November 2022, 14:03 | #19721 | Link | |
I have always considered doom9 a bible of useful encoding information and many good users available.
I think tmpgenc changes and adjusts the colorimetry automatically from the resolution of the input video. Edit: rec 709 use full range (0-255), not limited like mpeg2 range (16-255). Quote:
16th November 2022, 17:32 | #19722 | Link |
Try this for now...
1) Add --colorprim bt709 --transfer bt709 --colormatrix bt709 to your encoding profile 2) Download ColorMatrix Plugin https://www.mediafire.com/file/aj88v...trix26.7z/file 3) extract to Tools\AviSynth plugins folder 4) Add following lines to your script under #ColorSpace Code:
#ColorSpace LoadPlugin("C:\RipBot264\Tools\AviSynth plugins\ColorMatrix26\ColorMatrix64.dll") ColorMatrix(mode="Rec.601->Rec.709")
16th November 2022, 17:41 | #19723 | Link |
Hi atak,
thanks for you reply. As mentioned before, I've already edited my profile box with --colorprim bt709 --transfer bt709 --colormatrix bt709. The main problem after conversion are over satured colours (especially red). I hope to see little enanchement with color matrix conversion from bt 601/bt 709 and viceversa or other color space in the next update. I will try to use exteenal plugin too. Last edited by darkio; 16th November 2022 at 17:46. |
16th November 2022, 17:58 | #19724 | Link |
You must use colormatrix as well not only switches for an encoder.
16th November 2022, 18:12 | #19725 | Link | |
testing better later Last edited by darkio; 16th November 2022 at 18:17. |
16th November 2022, 18:17 | #19726 | Link |
Limited is correct. HD footage always uses limited.
17th November 2022, 03:49 | #19728 | Link | |
Formally known as .......
requirements: YV12 & YUY2 Colorspace And I was also having a problem with this call:- ColorMatrix(mode="Rec.601->Rec.709") shouldn't it be video=ColorMatrix(video,mode="Rec.601->Rec.709") like ALL the other RipBot scripts/calls ?? Last edited by TDS; 17th November 2022 at 03:58. |
17th November 2022, 12:53 | #19729 | Link |
Feature Request - Batch Cover
Hi Atak,
I'd like to submit a feature request for the batch processing. I use the batch a lot to pull in TV Episodes that I've used MakeMKV to rip the episodes from disks. I'd like to attach a cover to a batch import. I'd run one batch for season 1 and attach one cover to that, another batch and another cover, etc. Thanks Atak. |
17th November 2022, 15:43 | #19730 | Link | |
I'm running Windows 7. I'm using AnyDVD to rip the disks. I don't know if I copied the eac3to properly so I'm going to give that a try. Thanks |
17th November 2022, 19:17 | #19731 | Link |
Can you upload whole blu-ray folder somewhere? Obviously you would have to manually losslessly reduce size of each .m2ts file to something around 50-100MiB. You may try DGSplit of something similar.
18th November 2022, 01:20 | #19732 | Link | |
So before you do what Atak has suggested, I'd like to suggest that you use a different app to rip your disk's, just to be sure. Also, is your Bluray optical drive in good condition, newish & "clean" inside ?? I would suggest that you try MakeMKV to rip your disc's...another user I know uses MakeMKV, and he hasn't reported any issues, and I know he's ripped 100's, if not 1,000's of Bluray's. Maybe there's something about the newer disc's that AnyDVD is having a problem with, if as you say, the older disc's seem to be fine. If you're interested in using MakeMKV, (latest build with registration) https://www.mediafire.com/file/nq9e1...1.17.2.7z/file Anyway, that's my 2 cents....I hated ripping Bluray's !!!! Last edited by TDS; 19th November 2022 at 14:09. |
18th November 2022, 13:14 | #19733 | Link | |
I do remember a few times with a few ripped discs, that they must have mastered it wrong in some manner, as RB (eac3to) could not demux it properly and RB always gave an error when it had finished ripping the disc. The way around this was to use MakeMVK to convert the main feature (or episodes) into mkv files which RB imported without issue. You can use MakeMVK for free if you don't mind updating each 30 days with the key he provides. Though the software is so inexpensive, I would buy it as well. Both AnyDVD and MakeMKV have their places. MakeMKV can't do DVD backups, but AnyDVD can. MakeMKV can rip the files into mkvs, but AnyDVD cannot. There are a few other differences between them that make owning both of them essential if you use optical media. |
18th November 2022, 13:24 | #19734 | Link | |
and it's always good to have a couple of different ways of doing the same process. Last edited by TDS; 19th November 2022 at 14:08. |
21st November 2022, 05:08 | #19736 | Link |
there certainly is
overwrite this field in RipBot264.ini if you want to use FFMS2 instead of L-Smash Note that IF you do any changes within RipBot, and press APPLY, this will be overwritten, but all you'll need to do is copy it back Code:
[DefaultVideoDecoder] MPEG-2=FFMS2 VC-1=FFMS2 AVC=FFMS2 HEVC=FFMS2 OTHER=FFMS2 |
25th November 2022, 20:41 | #19737 | Link |
Crop command in ripbot profile ?
hi
is it possible to add a crop command line in ripbot, do i don't have to go in manually for each encode if i know they will all be the same. lets say 10 left 10 right ? if so how would the command line look like, and will i add it to the profile settings? Thanks |
26th November 2022, 00:36 | #19738 | Link | |
Not in the encoding script ?? If you want x264 or x265 to do it, go here, search & read :- http://www.chaneru.com/Roku/HLS/X264_Settings.htm https://x265.readthedocs.io/en/master/cli.html eg: crop Syntax: Code:
crop:left,top,right,bottom Code:
#Crop video=Crop(video,10,0,-10,-0) You could create a custom script and add the above call, then you could access & change it to suit your needs, and leave the x264/x265 profiles alone. |
26th November 2022, 00:52 | #19739 | Link |
Hold the phone, we have a nice autoupdate
v1.26.3 Added: 7.1 AAC encoding via FFMPEG (new profile will show up after you manually delete Audio.txt file in Profile folder) Added: Cover art can be also added in BATCH MODE Added: Automatic color conversion rec.601->rec.709 when upscaling from SD to HD Fixed: Main application RipBot264.exe was launching EncodingServer.exe without proper /avisynth-prefetch-threads switch EDIT:- I have a couple of questions about this update. Added: 7.1 AAC encoding via FFMPEG (new profile will show up after you manually delete Audio.txt file in Profile folder) When I remove this, adding a new job it stalls at "Gathering Information", and any other queued Job won't open as it can't find the "audio.txt". EDIT #2:- I started from scratch with RipBot264, deleted the "Audio.txt", it created a new "Audio.txt", but it was the same settings, do I need to create a job with 7.1 audio to start with ?? EDIT #3:- It's updated now Code:
2.0 OPUS CODEC 64 kbps [abr] 2.0 OPUS CODEC 96 kbps [abr] 2.0 OPUS CODEC 128 kbps [abr] 5.1 OPUS CODEC 160 kbps [abr] 5.1 OPUS CODEC 240 kbps [abr] 5.1 OPUS CODEC 320 kbps [abr] 7.1 OPUS CODEC 224 kbps [abr] 7.1 OPUS CODEC 336 kbps [abr] 7.1 OPUS CODEC 448 kbps [abr] 2.0 FHG AAC-HE 64 kbps [abr] 2.0 FHG AAC-LC 96 kbps [abr] 2.0 FHG AAC-LC 128 kbps [abr] 5.1 FHG AAC-HE 192 kbps [abr] 5.1 FHG AAC-LC 256 kbps [abr] 5.1 FHG AAC-LC 320 kbps [abr] 7.1 FFMPEG AAC 384 kbps [abr] 7.1 FFMPEG AAC 448 kbps [abr] 7.1 FFMPEG AAC 640 kbps [abr] 2.0 FFMPEG AC3 192 kbps [cbr] 2.0 FFMPEG AC3 224 kbps [cbr] 2.0 FFMPEG AC3 256 kbps [cbr] 5.1 FFMPEG AC3 384 kbps [cbr] 5.1 FFMPEG AC3 448 kbps [cbr] 5.1 FFMPEG AC3 640 kbps [cbr] Added: Automatic color conversion rec.601->rec.709 when upscaling from SD to HD Where is this option ?? Last edited by TDS; 26th November 2022 at 02:35. |
26th November 2022, 02:58 | #19740 | Link |
Grumpy Old Man.
Latest RipBot264 v1.26.3 complete (virgin)
For those users that want a clean install of the latest build provided by Atak, without having to start from scratch with v1.26.0, and then update it.
https://www.mediafire.com/file/c1rko...n%2529.7z/file All you need to do is keep your RipBot264.ini & EncodingClient.ini from your working/current version.
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) |
