20th September 2021, 13:54 | #161 | Link |
Version 16.5 release candidate 2 has been released
Version 16.5 release candidate 2 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! - Bug fixes. Previous beta changes since the release of version 16: http://inmatrix.com/files/zoomplayer...new_beta.shtml |
6th October 2021, 08:00 | #162 | Link |
Zoom Player v16.5 final has been released
Zoom Player v16.5 final has been released:
Highlights:
What's new in Zoom Player v16.5: * Introducing Charcoal, Zoom Player's new default skin! Charcoal includes the same layout and functionality as the previous Onyx default skin but uses more subtle shading and cleaner elements to better fit with Windows 10's look and feel. The onyx skin is still included with Zoom Player, you can switch by opening the skin selection dialog using the "N" keyboard macro or through the right-click menu. * New interface Sound-FX system that triggers sounds when certain actions are triggered (Adv. Options / Interface / Sounds) : 1. Zoom Player Startup. 2. Navigation motion (left/right/up/down). 3. Navigation actions (enter/back/esc). 4. Seeking (forward/backward/tracks). 5. Edge-Bump (media library). You can pick the volume level and the output sound device and limit some of the sounds if a video is currently playing or when using the mouse to perform actions. * The media library can now display a media file's approximate bitrate (e.g. 9.2 Mpbs). You will need to re-scrape old media to see this update. * It is now possible to play videos from Twitch.tv. * New "Confirm when resuming playback from previous position" setting (Adv. Options / Interface / Fullscreen Navigation / Settings) to request confirmation before resuming playback from the last saved position when playing media from a TV or Movie media library category. Please note, this setting is on by default and requires play history enabled to function. * New "Mark as Seen" media library feature accessible through the functions menu (toggle the cogwheel, or right-arrow in list mode). When marking media or entire folders as seen, you will be prompted to "Mark as seen now" or "Mark as seen archive". Depending on your choice the marked entries will appear at the start or end of your play history. * New "Select all Unseen" media library feature that selects every media or folder containing media that was seen (listed in your play history). * New "Select all Seen" media library feature that selects every media or folder containing media that is not listed in your play history. * You can now perform subtitle searches on movie folders, Zoom Player will automatically use the first video file within the folder to find matching subtitle tracks. * New Setting (Adv. Options / Interface / Fullscreen Navigation / Settings) that controls whether the Media Library's media scraping indicator and counter are visible within the path area. * New "Thumbnail icon size" setting (Adv. Options / Playback / Fullscreen Navigation / Customization) that controls the icon sizes in thumbnail view mode. * New "Prevent mouse actions from moving or resizing the main window" setting (Adv. Options / Interface / Position & Size" that blocks the mouse from being able to resize or move the main player window. * New "Skip requesting confirmation to erase file" setting (Adv. Options / Interface) used to skip the confirmation request dialog when erasing the playing media to the recycle bin. * New "Do not use scraped image as thumbnail" media library category setting. When enabled, Zoom Player ignores any thumbnail downloaded using a scraping plugin and depending on other category settings, Zoom Player will try to extract a thumbnail from the video file itself. * New "Do not use MediaInfo.dll to extract file metadata" media library category setting. When enabled, Zoom Player will not try to use MediaInfo.dll to extract metadata from files such as file format, codec, audio channels, etc. This can speed up scraping operation, but it also means the metadata displayed in the media library will be limited. * New "exPLSortOrder" extended function capable of choosing the playlist sorting order (ascending, descending). A value of "0" sets ascending and a value of "1" sets descending. Please note that this function doesn't actually sort the list. * New "exPLSort" extended function to sort the current playlist. Possible values are: 0 : Sort by Name 1 : Sort by File Type (file extension) 2 : Sort by File Date 3 : Sort by File Size 4 : Sort by File Path (folder) 5 : Sort by Media Duration (in seconds) 6 : Sort Randomly (random order) * New "exPLRemoveItem" extended function that allows you to directly remove a playlist item. Please note that the first playlist item has an index of "0" and not "1". + A major redesign of the media library's scraping operation. Scraping of new content should no longer block thumbnail and meta-data updates for previously scraped content. The redesign should make Zoom Player feel more responsive. + Rewrote the audio TAG/ID3 scraping code for enhanced efficiency and reliability. + When reaching the top/bottom position in the media library's thumbnail view, Zoom Player now tries to maintain the current column when the top/bottom bump bar is triggered twice to perform a scroll to top/bottom action. + Improved support for long paths (over 250 characters) in the media library and file browsing fullscreen navigation interfaces (especially over network shared paths). + The file meta-data edit window's title now features only the file name and not the full path. + The media library's YouTube Playlist plugin is now more flexible when parsing YouTube playlist URL structures. YouTube uses multiple URL structures to present playlists and now the plugin should support all of them. + The "Force the navigation list or thumb view display to full width" and "Force the navigation list or thumb view to maximum width" settings now apply to the path area and not only to the media area. + The minimum number of media library category columns has been changed from 3 to 2. + The "erase playing media" and "fullscreen navigation erase" dialogs now display the media's title alongside the file name. + Double-clicking the media library's category entries in list-view mode now performs an "Enter" navigation action instead of "Right". + Replaced the "Right arrow" icon with an "Enter" icon on the mini color control interface. - Fixed a hidden crash that destabilized Zoom Player when closing the media library while the thumb view was in the process of smooth scrolling. - You can no longer open the windowed go to time/chapter editor if no media is currently playing. - YouTube has a bug in it's API that can cause duplicate entries to show when loading more entries. Previously in such cases, Zoom Player didn't show a thumbnail for a duplicate entry, at least this bug is fixed, can't do much about YouTube's API bugs. - The media library's scraping counter did not update if you exited the folder currently scraping until some action updated the screen. - Stopped the Create Ringtone function from attempting to work with network streams (it never worked with URLs, but still allowed you to select the position and fill in details into the save dialog). - Fixed a rare case where the media library would not respond to input correctly when playing a movie and then exiting to the main navigation interface and then returning back to the media library. - With the "opening media library always selects the playing media" setting enabled, renaming a file or creating a new folder could change the active path. - Fixed high-DPI issues with unskinned confirmation dialogs. - Fixed an erroneous OSD notification when using the media library's mini-menu to add a category "refresh" or "append" entries to the playlist. - Fixed an issue that caused the media library to freeze if there were missing bitmap files in the navigation skin folder. - While in fullscreen mode, clicking on the playlist editor or equalizer windows when positioned over a hot-corner would activate the hot-corner action. - Opening a streaming YouTube URL using DirectShow would not show the video's title in the play history until after the video was closed. - Showing the control bar for the very first time showed a black rectangle in the top left corner of the screen for a split second. - Fixed a crash in the Media Library's playlist category plugin when parsing certain ".m3u" playlists. - When using the media library's refresh button on a plugin based category, it accidentally cleared the media's titles. - The advanced option dialog audio visualization configuration options were completely broken. - The "fnRestart" and "fnRestartWithParam" functions restarted Zoom Player without first saving settings, which caused the restarted copy to revert some settings. - Playing a network shared file from command line would miss an external subtitle file in the same folder and no subtitles were shown. - With the "Disable the Control Bar in Window Mode" setting enabled, exiting fullscreen briefly showed the control bar. - When Two movie folders shared a similar base name (e.g. "Men in Black" and "Men in Black 2"), the wrong progress bar position would show for the first folder. - Fixed a cosmetic glitch in the media scanner that caused paths to draw over icons. - Setting the image slideshow duration for loaded images to "0" would show an incorrect "remaining time" value on the timeline. - Fixed a few small memory leaks. Download : What's new |
29th November 2021, 12:34 | #163 | Link |
Version 16.6 beta 1 has been released
Version 16.6 beta 1 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! * New Smart Play profile for the Apple ProRes codecs. * New setting (Adv. Options / Playback) to select the web engine used to render the YouTube IFRAME player, either the old Edge Chakra engine or the newer (and much better quality) Edge Chromium. Please note that that Edge Chromium requires the WebView2 component installed. WebView2 comes pre-installed in Windows 11 and is an optional download for Windows 10. The WebView2 component is available for download directly from Microsoft or using Zoom Player's install center application. + The YouTube IFRAME player's preferred video quality setting has been removed as YouTube depreciated this feature. - The YouTube IFRAME player did not function properly in regions using the "," character as a decimal separator. - Pressing "Stop" twice to perform a Stop/Resume action did not work when using the YouTube IFRAME player. - When customizing the media library to use full height in combination with the category display set to list mode, using the Up/Down arrows at the Start/End of the category list would not roll-over to the Start/End of the list correctly. Previous beta changes since the release of version 16.5: http://inmatrix.com/files/zoomplayer...new_beta.shtml |
27th January 2022, 14:52 | #164 | Link |
Version 16.6 beta 2 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! * New ".ISO" drive mounting and playback settings to help automate the process of mounting ISO images and playing their content. An external mounting tool (such as Virtual CloneDrive) is required. Accessible under "Adv. Options / File Format Assocation / File Extensions." Please note that with this change, it is no longer possible to extract and play ISO files as if they were archives. * The ".WEBP" image format is now supported when using the internal image decoder. * New feature that replaces the TV Jukebox thumbnail for the currently playing media with the currently displayed image. This feature is limited to "TV Shows" media library categories and can be triggered through the Alt+Ctrl+"F" keyboard macro and the "fnCaptureScrapedImage" function. * New Media Library feature to sort categories by Play Date. When enabled the most recently played files (or folders containing files that have been played) will be listed first. * New Setting (Adv. Options / Interface / Playlist) to automatically hide the Playlist editor when entering fullscreen mode. + When using the Media Library's Cut/Copy/Paste functionality, Performing a "Paste" operation in the root virtual folder of a category containing multiple folders, ZP will now try to paste the file(s) to a folder on the same drive when possible and only use the folder of the currently highlighted entry if no folders in the pasted category are on the same drive. + ISO files are now always visible in media library video categories. - When the setting to show file extensions in the navigation interfaces was disabled, URLs appeared cropped in the play history fullscreen navigation interface. - Opening a subtitle file for a playing video when using MadVR as the video renderer could cause the video to appear in a new window. - Fixed a bug in TV jukebox mode that prevented some file meta-data from displaying when the file name contained unicode characters. Previous beta changes since the release of version 16.5: http://inmatrix.com/files/zoomplayer...new_beta.shtml |
9th April 2022, 13:17 | #165 | Link |
Version 17 beta 3 has been released
Version 17 beta 3 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! * New Setting (Adv. Options / Playback / Video / Subtitles) that limits the "next subtitle" feature to specified languages. For example to limit the subtitle tracks to Spanish, English and Directory Commentary, you only need to specify "spa;eng;dir" and any subtitle track not containing these values will by skipped when switching to the next subtitle track. * New "exSetAudioSync" extended function that allows you to set a positive or negative millisecond accurate audio synchronization offset. * Added support for YouTube Shorts URL parsing and playback, for example: https://www.youtube.com/shorts/5TTNpKFy_10 + YouTube media library plugins no longer return a star rating or dislike count since YouTube removed public dislike data. + The "Pause playback when minimizing the player window while playing video content" setting is now ignored for live streams with no duration specified as it just caused the stream to close. + Disabled the Startup sound if a media was already in the process of loading. + The Media Library's function page is now more dynamic, removing entries that may not be useful in some contexts (e.g. using plugins). + TheMovieDB scraper plugin will now download movie poster images at full resolution (previously limited to 500x750px). This change means you will see sharper looking posters on 4K displays. This fix requires that you re-scrape movies to download the higher resolution poster images. - Seeking Ahead/Back on YouTube streams using the IFRAME player would reset the play position to 0 if the windows decimal separator was set to something other than ".". - Restoring last play position for YouTube videos played using the IFRAME player did not function currently on some PCs with a slower internet connection. - Displaying the current video resolution on the timeline while using the YouTube IFRAME playback engine displayed a fixed value instead of the value returned by the YouTube IFRAME engine. - The "Open Media Library" button on the Media Library category editor did not function if the category mode was set to view all (prism). - YouTube channels containing the "&" character in the name would not show the correct channel name under some conditions. - Fixed a cosmetic bug in the play history dialog that would show the current position with a negative value. - Edits to the playlist using the playlist editor should now be reflected in the advanced playlist control interface. - The playing information fullscreen navigation interface was not updating in real time and didn't update at all when playing new SHOUTcast content. - The "Open Drive" feature broke down for multiple use cases, including using Zoom Player to auto-play a drive. - The Media Library's "mark as seen:archive" option will now close the currently playing media if it's being archived. Previous beta changes since the release of version 16.5: http://inmatrix.com/files/zoomplayer...new_beta.shtml |
29th May 2022, 08:14 | #166 | Link |
Version 17 beta 4 has been released
Version 17 beta 4 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! * New metadata editor accessible by right-clicking TV or Movie entries in the media library. The metadata editor allows you to replace thumbnails and backdrops along with editing the Title, Release date, Overview, Genre, Tags and Collections. * New media library filtering by Genre, Tags and Collections. Accessible through the functions menu or by clicking the new "funnel shape" filter icon in the path area. Filtering is remembered on a per-category basis and is stored across sessions (even after exiting Zoom Player). * The media library mini-menu has been extended with two new functions you can select : "Filter list" and "Edit metadata". - Under some conditions, pressing the ESC/Menu keys to close the right-click context menu would break some keyboard functionality. Previous beta changes since the release of version 16.5: http://inmatrix.com/files/zoomplayer...new_beta.shtml |
15th June 2022, 09:53 | #167 | Link |
Version 17 release candidate 1 has been released
Version 17 release candidate 1 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! * The mouse's backward and forward button can now be assigned custom functionality when a navigation interface is visible. * YouTube kids URLs should now work with the IFRAME player. * New "Sort by Release Date" media library sort option (Only works on scraped media [TV & Movies]). * New "Sort by Sort Title" media library sort option (Only works on scraped media [TV & Movies]). This sorting mode allows you to use the meta-data editor to specify an "invisible" custom title that Zoom Player will use for sorting. When no sorting title is specified, Zoom Player automatically uses the media'a title (if one exists) or file name. * New Setting (Adv. Options / Interface / Fullscreen Navigation / Settings) that controls whether filtering lists in the media library can use multiple parameters (e.g. "Genre" and "Tag") at the same time. * New "9:16" thumbnail aspect ratio option for media library thumbnails suitable to vertical videos. * New configuration option for TheMovieDB scraping plugin that allows you to select the poster/backdrop/still image sizes. * New "Edit Metadata" option in the media library's functions page for TV and Movie categories. - Play history features such as "resume playback" and "previous play position on thumbnails" did not function on files with over 128 characters. - Playing files with over 128 characters in their name created duplicate play history entries. - You could actually click on media library path icons even when they were invisible in the category list. - When viewing the media library's categories page, you could click above/below the scroll-bar area and it would still affect the scroll position. Previous beta changes since the release of version 16.5: http://inmatrix.com/files/zoomplayer...new_beta.shtml |
16th June 2022, 06:43 | #168 | Link |
Version 17 release candidate 2 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! * New "Sort by Star Rating" media library sort option (Only works on scraped media [TV & Movies]). You can adjust the Movie/TV Show's star rating using the metadata editor. - There was a bug in v17 RC1 that caused play history to break when playing streaming content and possibly in other cases. Previous beta changes since the release of version 16.5: http://inmatrix.com/files/zoomplayer...new_beta.shtml |
24th June 2022, 12:44 | #169 | Link |
Zoom Player v17 final has been released
Zoom Player v17 final has been released:
Highlights:
What's new in Zoom Player v17: * New metadata editor accessible by right-clicking TV and Movie entries in the media library (also available through the functions page and as a mini-menu option). The metadata editor allows you to replace thumbnails and backdrops along with editing the Title, Sort Title, Release date, Rating, Overview, Genre, Tags and Collections. * New media library filtering by Genre, Tags and Collections. Accessible through the functions menu or by clicking the new "funnel shape" filter icon in the path area. Your filtering choice is remembered on a per-category basis and is stored across sessions (even after exiting Zoom Player). * New "Sort by Release Date" media library sort option (Only works on scraped media [TV & Movies]). * New "Sort by Play Date" media library sort option to sort your categories by the most recently played files (or folders containing files that have been played). * New "Sort by Sort Title" media library sort option (Only works on scraped media [TV & Movies]). This sorting mode allows you to use the meta-data editor to specify an "invisible" custom title that Zoom Player will use for sorting while still displaying the original title. When no sorting title is specified, Zoom Player automatically uses the media's title (if one exists) or file name. * New "Sort by Star Rating" media library sort option (Only works on scraped media [TV & Movies]). Initially populated with scraped data, you can adjust the Movie/TV Show's star rating using the metadata editor. * The media library mini-menu has been extended with two new functions you can select : "Filter list" and "Edit metadata". * The mouse's backward and forward button can now be assigned custom functionality when a navigation interface is visible. * New ".ISO" drive mounting and playback settings to help automate the process of mounting ISO images and playing their content. An external mounting tool (such as Virtual CloneDrive) is required. Accessible under "Adv. Options / File Format Association / File Extensions." Please note that with this change, it is no longer possible to extract and play ISO files as if they were archives. * New setting (Adv. Options / Playback) to select the web engine used to render the YouTube IFRAME player, either the old Edge Chakra engine or the newer (and much better quality) Edge Chromium. Please note that that Edge Chromium requires the WebView2 component installed. WebView2 comes pre-installed in Windows 11 and is an optional download for Windows 10. The WebView2 component is available for download directly from Microsoft or using Zoom Player's install center application. * New Setting (Adv. Options / Interface / Fullscreen Navigation / Settings) that controls whether filtering lists in the media library can use multiple parameters (e.g. "Genre" and "Tag") at the same time. * YouTube kids URLs should now work with the IFRAME player. * Added support for YouTube Shorts URL parsing and playback, for example: https://www.youtube.com/shorts/5TTNpKFy_10 * New Setting (Adv. Options / Interface / Playlist) to automatically hide the Playlist editor when entering fullscreen mode. * New Setting (Adv. Options / Playback / Video / Subtitles) that limits the "next subtitle" feature to specified languages. For example to limit the subtitle tracks to Spanish, English and Directory Commentary, you only need to specify "spa;eng;dir" and any subtitle track not containing these values will by skipped when switching to the next subtitle track. * New "9:16" thumbnail aspect ratio option for media library thumbnails suitable to vertical videos. * The ".WEBP" image format is now supported when using the internal image decoder. * New feature that replaces the TV Jukebox thumbnail for the currently playing media with the currently displayed image. This feature is limited to "TV Shows" media library categories and can be triggered through the Alt+Ctrl+"F" keyboard macro and the "fnCaptureScrapedImage" function. * New "Edit Metadata" option in the media library's functions page for TV and Movie categories. * New configuration option for TheMovieDB scraping plugin that allows you to select the poster/backdrop/still image sizes. * New Smart Play profile for the Apple ProRes codecs. * New "exSetAudioSync" extended function that allows you to set a positive or negative millisecond accurate audio synchronization offset. + YouTube media library plugins no longer return a star rating or dislike count since YouTube removed public dislike data. + The "Pause playback when minimizing the player window while playing video content" setting is now ignored for live streams with no duration specified as it just caused the stream to close. + Disabled the Startup sound if a media was already in the process of loading. + The Media Library's function page is now more dynamic, removing entries that may not be useful in some contexts (e.g. using plugins). + TheMovieDB scraper plugin will now download movie poster images at full resolution (previously limited to 500x750px). This change means you will see sharper looking posters on 4K displays. This fix requires that you re-scrape movies to download the higher resolution poster images. + To prevent longer copy times, when using the Media Library's Cut/Copy/Paste functionality, Performing a "Paste" operation in the root virtual folder of a category containing multiple folders, ZP will now try to paste the file(s) to a folder on the same drive when possible and only use the folder of the currently highlighted entry if no folders in the pasted category are on the same drive. + In combination with the new ISO mounting feature, ISO files are now always visible in media library video categories. + The YouTube IFRAME player's preferred video quality setting has been removed as YouTube depreciated this feature. - The YouTube IFRAME player did not function properly in regions using the "," character as a decimal separator. - Play history features such as "resume playback" and "previous play position on thumbnails" did not function on files with over 128 characters. - Playing files with over 128 characters in their name created duplicate play history entries. - Pressing "Stop" twice to perform a Stop/Resume action did not work when using the YouTube IFRAME player. - When customizing the media library to use full height in combination with the category display set to list mode, using the Up/Down arrows at the Start/End of the category list would not roll-over to the Start/End of the list correctly. - When the setting to show file extensions in the navigation interfaces was disabled, URLs appeared cropped in the play history fullscreen navigation interface. - Opening a subtitle file for a playing video when using MadVR as the video renderer could cause the video to appear in a new window. - Fixed a bug in TV jukebox mode that prevented some file meta-data from displaying when the file name contained Unicode characters. - Seeking Ahead/Back on YouTube streams using the IFRAME player would reset the play position to 0 if the windows decimal separator was set to something other than ".". - Restoring last play position for YouTube videos played using the IFRAME player did not function currently on some PCs with a slower internet connection. - Displaying the current video resolution on the timeline while using the YouTube IFRAME playback engine displayed a fixed value instead of the value returned by the YouTube IFRAME engine. - The "Open Media Library" button on the Media Library category editor did not function if the category mode was set to view all (prism). - YouTube channels containing the "&" character in the name would not show the correct channel name under some conditions. - Fixed a cosmetic bug in the play history dialog that would show the current position with a negative value. - Edits to the playlist using the playlist editor should now be reflected in the advanced playlist control interface. - The playing information fullscreen navigation interface was not updating in real time and didn't update at all when playing new SHOUTcast content. - The "Open Drive" feature broke down for multiple use cases, including using Zoom Player to auto-play a drive. - The Media Library's "mark as seen:archive" option will now close the currently playing media if it's being archived. - Under some conditions, pressing the ESC/Menu keys to close the right-click context menu would break some keyboard functionality. - You could actually click on media library path icons even when they were invisible in the category list. - When viewing the media library's categories page, you could click above/below the scroll-bar area and it would still affect the scroll position. Download : What's new |
13th September 2022, 09:08 | #170 | Link |
Version 17.1 beta 1 has been released
Version 17.1 beta 1 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! * New "Display unwatched counter on TV Show category folders" setting (Adv. Options / Interface / Fullscreen Navigation / Thumbnail Cust.) that counts the number of unwatched episodes in "TV Show" categories and displays the count in a corner on the folder's thumbnail. * Full customization for the TV Show unwatched counter: 1. Size (relative to thumbnail) 2. Margins (relative to Size) 3. Font Color 4. Background Color + If you previously used a download tracking plugin, you must now re-enable it. Plugins were previously enabled by default which could have caused delays when exiting Zoom Player. + Having ZP set to automatically show the media library when opening will no longer show the media library if a media was set to load using the command line. + Zoom Player will no longer display the default background image if a media is set to load via command line, removing the slight flicker of the image and slightly speeding up load time. - Setting Zoom Player to pre-load fullscreen navigation graphics while trying to play a media from command line could cause ZP to freeze. - When taking a screenshot of the playing video (Alt+F), the generated filename included a wrong position value (just the file name, the image was taken from the correct position). - The "Stop function closes streaming media (instead of just stopping)" setting was accidentally applied to every playing media and not only live streams. - Fixed a bug that would break URL links in the active playlist when closing and then re-opening Zoom Player. Previous beta changes since the release of version 17: http://inmatrix.com/files/zoomplayer...new_beta.shtml |
26th September 2022, 12:17 | #171 | Link |
Version 17.1 beta 2 has been released
Version 17.1 beta 2 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! * New "Display thumbnail season progression bar" setting (Adv. Options / Interface / Fullscreen Navigation / Thumbnail Cust.) that shows a season progression bar (similar to the last play position bar) in TV Show category based on the number of watched/unwatched episodes in a folder. * New "Reset" option in each individual media library filtering mode (Genre, Tag and Collection). * Two new Pixel Shader scripts you can use with MadVR as the video renderer to flip the video both horizontally and vertically. + Filtering the media library will now reset the selected entry to the first item, unless the "Auto-select last viewed file/folder on entering a folder" setting is enabled, in which case the last viewed file or folder is selected automatically. Previous beta changes since the release of version 17: http://inmatrix.com/files/zoomplayer...new_beta.shtml |
9th November 2022, 12:33 | #172 | Link |
Zoom Player v17.1 final has been released
Zoom Player v17.1 final has been released: Highlights:
15th March 2023, 11:55 | #173 | Link |
Version 17.2 beta 1 has been released
Version 17.2 beta 1 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! * New "Resume Playback" media library feature that's accessible from the media library's functions page and the media library's mini-menu (Adv. Options / Interface / Fullscreen Navigation / Thumb View). Resume playback looks for the first unwatched media in the folder and then resumes playback from that media. If no media from the folder has been previously played, it will play the first media in the folder (in alphabetical order by Title or File name). If the last played media in the folder is over the "Consider media as watched" percentage threshold, the next media will play in alphabetical order by title (if previously scraped), otherwise by file name. * Added support for new YouTube URL format when adding YouTube channels as media library categories: Example: https://www.youtube.com/@CowboyKentRollins * Double-clicking a TV show thumbnail in the media library's TV Jukebox mode will now play the episode. + Zoom Player no longer requires "freeimage.dll" to load. The library which is used to display the ".WEBP" image format is now loaded dynamically as-needed, saving a bit of RAM while allowing Zoom Player to start slightly faster. - The media library's unplayed media counter will now adjust the background box size if the unwatched media counter is 3 digits or more. - Fixed a bug that prevented the media library's right/left bump actions from working after a PC was not reset for over a month. - Some information was not displayed correctly in the media library for YouTube channels containing the "|" character in their channel name, video names or video description. - Fixed a bug causing ".df" definition files not to save properly when playing from shared network paths (e.g. "\\my_server\shared_folder\media.mkv"). Previous beta changes since the release of version 17.1: http://inmatrix.com/files/zoomplayer...new_beta.shtml |
11th April 2023, 06:49 | #174 | Link |
Version 17.2 beta 2 has been released
Version 17.2 beta 2 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! * New "Filter by Star Rating" media library feature. Filtering by Star Rating allows you to filter TV and Movie categories based on the media's Star Rating. You can easily customize each media's star rating to your own personal value using the integrated metadata editor, accessible by right-clicking a media's thumbnail or through the media library's functions page. * New "Filter by Content Rating" media library feature. Filtering by Content Rating allows you to filter TV and Movie categories based on the MPAA rating assigned to the TV Show or Movie, for example "PG-13" or "TV-MA". * New "Hide Mouse Cursor in Windowed mode" setting (Adv. Options / Interface / Mouse / Setting) that allows the mouse cursor to auto-hide even when playing in a window (disabled by default). - Wrote a work-around for a bug in Media Portal's TS File Reader filter to prevent Zoom Player from freezing on re-play. The bug prevents ZP from seeking to 0 and re-playing by returning invalid media position values, requiring the media to be fully reloaded. - Under some conditions, the media library's filter function would not highlight any of the available filtering options and would draw the scrollbar widget in the wrong position. - Under some conditions, the media library's filter function would not bring the active filtering mode into view. Previous beta changes since the release of version 17.1: http://inmatrix.com/files/zoomplayer...new_beta.shtml |
27th April 2023, 11:05 | #175 | Link |
Version 17.2 beta 3 has been released
Version 17.2 beta 3 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! * Support for a new YouTube LIVE URL structure, usually used when sharing a video the YouTube mobible app. Example: https://www.youtube.com/live/L5QXreqOrTA?feature=share * New "Edit Last Played" option added to the windowed play history's right-click menu, allowing you to manually edit the "Last Played" field without actually playing the media. Previous beta changes since the release of version 17.1: http://inmatrix.com/files/zoomplayer...new_beta.shtml |
21st June 2023, 13:13 | #176 | Link |
Version 17.2 release candidate 1 has been released
Version 17.2 release candidate 1 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! * The Media Library category editor has been redesigned for clarity and ease of use. * The Media Library category editor can now be used to select and re-order multiple categories in one click, making it much easier and faster to re-order categories. * The Media Library category editor has been extended with a "Move top" and "Move bottom" buttons to more easily arrange your category listing. * New "Sort by Runtime" media library feature. In TV categories it sorts by the number of episodes in a folder and in Movie categories it sorts by the Movie's specified Runtime (not the media's duration which may include additional content such as credits). - Fixed an issue in the Media Library filtering function that would allow entries with a similar enough Collection/Tag to the active filter to be listed. - Fixed a "Plugin ERROR #80004005" when trying to add a YouTube channel to the media library category editor if the channel's URL contained the "@" character, e.g. "https://www.youtube.com/@WeMightBeDrunkPod" Previous beta changes since the release of version 17.1: http://inmatrix.com/files/zoomplayer...new_beta.shtml |
12th July 2023, 10:39 | #177 | Link |
Zoom Player v17.2 final has been released
Zoom Player v17.2 final has been released:
Highlights:
30th August 2023, 13:53 | #178 | Link |
Version 17.5 beta 1 has been released
Version 17.5 beta 1 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! * Two new settings (Adv. Options / Interface / Fullscreen Navigation / Customization) that allow you to override the poster image and backdrop for Movies and TV show categories. The backdrop setting is an easy override, just place a "backdrop.jpg" or "fanart.jpg" in the same folder and Zoom Player will use it automatically. Updating a movie poster image requires you enable the "Do not use scraped image as thumbnail / backdrop" setting for each of the media library's TV or Movie categories, otherwise the poster image will still use the scraped image (due to image-caching maintaining a copy of the old image) and then re-scrape the movie folder. Previous beta changes since the release of version 17.2: http://inmatrix.com/files/zoomplayer...new_beta.shtml |
13th September 2023, 12:54 | #179 | Link |
Version 18 beta 2 has been released
Version 18 beta 2 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! * A completely new IPTV (streaming live TV and VOD) interface (Adv. Options / Playback / IPTV) with support for EPG (Electronic Program Guide), Channel Grouping and many customization options. Some features (icons, automated EPG/M3U downloads, etc) are still a work in progress and are not part of this beta. * New setting (enabled by default) to automatically hide the control bar when clicking the video area, making it much easier to quickly hide the control bar. * You can now edit the last play time and date directly from the media library meta-data editor. - Using unicode characters in the ISO Auto-Mount command would not save the path properly after restarting Zoom Player. - The Advanced Options "System Sounds" and "Audio" sections did not scroll smoothly when using the scroll bar. Previous beta changes since the release of version 17.5: http://inmatrix.com/files/zoomplayer...new_beta.shtml |
20th September 2023, 07:27 | #180 | Link |
Version 18 beta 3 has been released
Version 18 beta 3 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! * The IPTV interface now supports automatically downloading stream lists and electronic program guide URLs every specified number of days. * IPTV Stream icons are now downloaded automatically. * New Setting (Adv. Options / Playback / IPTV) allowing you to control the Stream's icon size. * New Setting (Adv. Options / Playback / IPTV) allowing you to control whether the Stream's text is resized along with the icon size. * New Setting (Adv. Options / Playback / IPTV) to ignore grouping and just display the entire stream list. * New Settings (Adv. Options / Playback / IPTV) to customize the IPTV interface with your own color scheme. + If an IPTV stream list contains mixed information with some streams lacking a group specification, all such streams will now show under an "Unspecified" group. If only one or no groups are specified, grouping is disabled automatically. Previous beta changes since the release of version 17.5: http://inmatrix.com/files/zoomplayer_whatsnew_beta.shtml |
dvd, htpc, media player, tablet, zoom player |
