Old 13th February 2023, 22:59   #1  |  Link
xiaNaix
Noisy Nose in VHS Capture
I have a tape circa 1985 that I believe is a 2nd gen transfer from a VHS camcorder. I have been able to clean it up somewhat but there is some weird noise around this individual's nose that I can't seem to get rid of. I'm not sure if it's a field issue, motion blur from the camera moving or what.
The clip is a few seconds of unprocessed Lagarith avi...
https://www.mediafire.com/file/k0r8w...NOSEY.avi/file
The issue is present before deinterlacing with QTGMC so it may have just been baked into the tape. If anyone has any ideas I'd appreciate it.
xiaNaix is offline   Reply With Quote
Old 14th February 2023, 01:09   #2  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Looks like a CCD bleeding fault, triggered by brighter parts, propagating in scan direction.
Here the nose is brightest, pulling brightness from the following contents for a few Ás.
Can be mended by a 1-dimensional (x-axis only) convolution filter which got to be made absolute and differential sensitive.
"Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf ling÷age..."
Emulgator is online now   Reply With Quote
Old 19th March 2023, 07:15   #3  |  Link
Mounir
Try with Spotless that should get rid off most of it
https://imgsli.com/MTYzMTQ3
AVISource("NOSEY.avi")
assumetff()
assumetff()
ConvertToYV16(interlaced=true)
orig=last
ev=orig.assumetff().separatefields().selecteven()
od=orig.assumetff().separatefields().selectodd()
ev
ue_chroma = UToY(ev)
ve_chroma = VToY(ev)
YToUV(ue_chroma, ve_chroma)
MergeLuma(ev)
ev_filtered=last
od
uo_chroma = UToY(od)
vo_chroma = VToY(od)
YToUV(uo_chroma, vo_chroma)
MergeLuma(od)
od_filtered=last
interleave(ev_filtered,od_filtered).SpotLess()
assumefieldbased().assumetff().weave()
qtgmc(Preset="fast",edithreads=3)
SelectEven()
Mounir is offline   Reply With Quote
avisynth, capture, noise, vhs
