Old 17th September 2023, 08:44   #81  |  Link
ksec
Originally Posted by hajj_3 View Post
there's no point in AV1 encode. It won't be much better than the h265 encoder but will take up die space.
Well yes but I cant say that out loud since this is an AV1 section.
Previously iwod
ksec is offline   Reply With Quote
Old 18th September 2023, 20:56   #82  |  Link
birdie
Artem S. Tashkinov
birdie's Avatar
Google's Tensor G3 SoC is rumored to support AV1 encode at up to 4K at 30fps.
We'll find out soon enough.
birdie is offline   Reply With Quote
Old 20th September 2023, 19:04   #83  |  Link
hajj_3
Amazon Fire TV Stick 4K (2nd generation) was announced today, it supports AV1 decoding. It is out on October 18th in uk, not sure about other countries.
Old 30th September 2023, 02:08   #84  |  Link
quietvoid
Dolby will make licensing revenue with VVC, and VVC is technically superior to AV1, so I can see lots of reasons they'd prefer to skip over AV1.
Dolby recently re-added AV1 profiles in their public spec, so it's not dead yet.
Also, I've received my new FireTV Stick 4K Max 2nd gen (2023) and it still has no FGS with AV1 in Dolby Vision mode.
Still works fine in HDR10.
LG C2 OLED | GitHub Projects
quietvoid is offline   Reply With Quote
Old 4th October 2023, 18:48   #85  |  Link
benwaggoner
DoVi Profile 5 takes a lot more compute/pixel than HDR-10; max fps has typically been half (still better than dual-layer). It wouldn't be entirely surprising if there wasn't enough GPU compute left for FGS.
Just speculation on my part; I have now direct knowledge. There haven't been AV1 DoVi test streams, so it just may have never been turned on in SoC OEM drivers. The default is to no turn on features you can't test, for obvious reasons.
Ben Waggoner
My Compression Book
Old 4th October 2023, 19:30   #86  |  Link
quietvoid
I would assume it probably has more to do with missing AV1 Dolby Vision streams, but if vendors could implement it I assume they had access to some.
Or maybe just regular non-FGS streams, I don't know.
Anyways, it might take a while for it to be fixed since nobody is distributing it.
Old 4th October 2023, 20:05   #87  |  Link
ChaosKing
Film Grain Synthesis works in FireTV Max V1. I have tested this in Kodi with different video files.
VapourSynth Portable FATPACK || VapourSynth Database || https://github.com/avisynth-repository
Old 4th October 2023, 21:17   #88  |  Link
quietvoid
Yes, I know.
I'm talking specifically about AV1 Dolby Vision videos, FGS doesn't work with those only.
Old 4th October 2023, 21:43   #89  |  Link
ChaosKing
Yes, I know.
Is there a video online which I could test?
Old 4th October 2023, 22:07   #90  |  Link
quietvoid
Sure, here's one: https://0x0.st/HWpI.mp4
Old 4th October 2023, 23:08   #91  |  Link
ChaosKing
Thx. Indeed no grain. But it works with Chromecast 4K [the white stick](not 100% realtime playback)
Old 1st November 2023, 13:14   #92  |  Link
oibaf
Apple M3 adds AV1 hardware decoder: https://www.apple.com/newsroom/2023/...onal-computer/
oibaf is offline   Reply With Quote
av1, av1 hardware decode, hardware decoders
