Old 8th November 2010, 13:30   #1  |  Link
mastrboy
How can i display only the chroma plane?
I'm looking for a function to display only the chroma plane, similar to histogram(mode="luma")
Does such a function exist?
mastrboy is offline   Reply With Quote
Old 8th November 2010, 13:49   #2  |  Link
Gavino
Avisynth language lover
UToY, VToY
Old 8th November 2010, 14:02   #3  |  Link
mastrboy
almost what i was looking for, but you put me on the right track, doing this: YToUV(UTOY(),VTOY()) i got the output i was looking for...
Thank you
Old 8th November 2010, 14:43   #4  |  Link
Didée
In case you've loaded mt_masktools anyway, shorter command:
mt_lut(Y=-128,U=2,V=2)
Though, displaying a YV12 (or YUY2) clip "without luma" is basically not possible. You always have to use some luma.
Old 8th November 2010, 17:06   #5  |  Link
mastrboy
thanks for the info Didée, some luma is okay, i needed this command to see how much a denoiser blurred the chroma plane vs another denoiser.
chroma plane, histogram
