Old 8th May 2010, 19:39   #1  |  Link
Chupo
Chupo's Avatar
Gspot says Packed - MPEG4 Modifier says NO
I have an XviD video that caused troubles (stalling&freezing of picture) to my standalone player so I examined it with Gspot and (among the others) the result was:
DivX Style "packed bitstream" AVI
As soon as I saw the info I decided to use MPEG4 Modifier to unpack the video but I was surprised seeing:
Packed Bitstream: No
What should I do to unpack the 'nonexistent' packed bitstream?
Chupo
Chupo is offline
Old 8th May 2010, 20:03   #2  |  Link
Where did you get the Xvid video?
Guest is offline
Old 9th May 2010, 11:12   #3  |  Link
Chupo
Chupo's Avatar
Solved. My mistake, packed bitstream has nothing to do with the problem - the real problem was VBR audio. After demultiplexing it and inserting back as CBR everything is OK.
Chupo
Chupo is offline
Old 9th May 2010, 14:02   #4  |  Link
Please answer my question to avoid a rule 6 presumption and consequent strike.
Guest is offline
Old 10th May 2010, 09:56   #5  |  Link
Chupo
Chupo's Avatar
It's a wedding video. In fact wedding highlights :-))
Chupo
Chupo is offline
choppy, freeze, mpeg4 modifier, packed bitstream, unpack
