Old 22nd December 2009, 20:42   #1  |  Link
bizz & buzz
Aliasing and stuttering issues on HD source
Hello,
My source is 1080i25 music video capture. Using Srestore() solved the interlacing and filed-blends issues, but now there's a stutter caused by what seems to be dupe frames. Worse then the stuttering, there's some very bad aliasing I couldn't get rid of, no matter what I tried.
Here are samples of aliasing and stuttering from the unprocessed source (TS files) + same samples processed with the script below and encoded to Xvid (Avi):
http://www.mediafire.com/?zugnugj3mzd (26 MB).
Script:
DSS2("D:\HDTV.ts")
AssumeTFF()
tdeint(mode=1)
srestore()
Any advice on these issues? I'm out of ideas
Last edited by bizz & buzz; 23rd December 2009 at 12:42. Reason: edit samples link
bizz & buzz is offline   Reply With Quote
Old 23rd December 2009, 10:34   #2  |  Link
bizz & buzz
Actually, this "aliasing" problem is so bad, that I'm not sure I can call it aliasing anymore. Another thing is that this artifact is not on every frame, but appears in an alternately fashion.
here it is:
Old 23rd December 2009, 12:27   #3  |  Link
RunningSkittle
Skittle
RunningSkittle's Avatar
post sample please!
RunningSkittle is offline   Reply With Quote
Old 23rd December 2009, 12:36   #4  |  Link
bizz & buzz
Link is under "Mediafire" in the first post. I'll edit it to make it more clear.
Old 23rd December 2009, 12:43   #5  |  Link
Didée
Hmh. Quickly looking at the source, you might want to ask MTV if they destroyed the clip on purpose, or if they're simply incompetent.
Old 23rd December 2009, 12:45   #6  |  Link
bizz & buzz
I know, it's a total mess
is there any way to make it better?
Old 23rd December 2009, 13:04   #7  |  Link
Didée
Off hand, I see no way.
Fact is (seems to be) that they took already-fieldblended SD crappola, and just blew it up to HD res. I'm not sure if the upscale even was done correctly. I quickly tried to re-downscale it to interlaced SD, but that still looks quite messy. Personally, I would not invest much time into that. Label it "FUBAR", and let it be.
Old 23rd December 2009, 13:25   #8  |  Link
bizz & buzz
I was afraid you were going to say that...
Anyway, is there any clue on what might have caused this "mega-aliasing"?
Old 23rd December 2009, 14:57   #9  |  Link
Lyris
Sorry I can't add a lot more other than: "UNBELIEVABLE". The most stupid part is the huge burned-in "MTV HD" ("HD"????) logo!
Lyris is offline   Reply With Quote
Old 23rd December 2009, 22:30   #10  |  Link
Didée
The actual meaning of "HD" is case dependent. It can stand for "High Definition". But it can also mean "Huge Disappointment", or "Hilarious Disaster", ...
(for the wordsmiths: any way to make "empty promises" fit to the letters h+d? Or something with "scam" or similar?)
Old 24th December 2009, 01:08   #11  |  Link
bizz & buzz
LOL... at least one good thing came out of this s***** source.
Old 24th December 2009, 02:01   #12  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
"Hollow" for "empty" comes to mind, but "promises" is a toughy...
now playing: [artist] - [track] ([album])
Leak is offline   Reply With Quote
Old 24th December 2009, 13:59   #13  |  Link
Gavino
Avisynth language lover
How about "humongous deception"?
Happy Christmas, everyone.
Old 26th December 2009, 09:37   #14  |  Link
thetoof
Sleepy overworked fellow
Nice thread
Merry Christmas!
AnimeIVTC() - v2.00
-http://boinc.berkeley.edu/-
Let all geeks use their incredibly powerful comps for the greater good (no, no, it won't slow your filtering/encoding :p)
thetoof is offline   Reply With Quote
Old 27th December 2009, 04:47   #15  |  Link
Mounir
HD stand for Highly Destructive actually
Mounir is offline   Reply With Quote
Old 27th December 2009, 05:00   #16  |  Link
Lyris
Here's another case of "Hilarious Disaster":
http://www.lyris-lite.net/2009/12/26...ray-disc-ever/
For those who don't want to hit the link: a Blu-ray Disc with an upconverted SD transfer which isn't even acceptable by SD standards.
aliasing, srestore, stuttering
