#20301 | Link |
Pig on the wing
The settings in the two encodes are totally different. For example, aq-mode 1 vs 2 can make a huge difference in the final bitrate.
#20303 | Link | |
Formally known as .......
When you learn a bit more about RipBot, you will soon realise that you can change a LOT of settings, either using custom scripts, and custom x265 commands. When using Distributed Encoding, you will be able to view all the settings that the app is using to do the encode, in the Encoder Server "window". That can also be beneficial in knowing what x265 commands can be added, changed, etc, etc. Chances are, if you studied & compared the MediaInfo data, (as Boulder mentioned) and matched RB with Vidcoder (at least as far as x265 commands are concerned) you may get a LOT closer results. Also, maybe you give this a shot with the FPS issues you're having :- http://avisynth.nl/index.php/FPS#ChangeFPS ChangeFPS(25000, 1000)
This can be Very "TeDiouS".. Long term RipBot264 user. Ryzen 9 7950X Intel i9-13900KF Ryzen 9 5950X Ryzen 9 5900X Ryzen 9 3950X Link to RB v1.27.0 |
#20304 | Link |
Hello. Are there any limitations in the ripbot264 on the use of the cpu? To be specific I can't use the full power of my cpu and gpu .The cpu used during encoding is no more than 22%
![]() ![]() Edit: Second pass is no more than 46% ![]() Last edited by Yopen71; 20th September 2023 at 09:36. |
#20305 | Link |
are you using windows 10? i had a similar issue and its the way the thread scheduler works in win 10. i did fix it and post in this thread but it was a bit of fafing about so just use win 11 instead. it only affects the newer Hybrid CPU's like 12th gen+
#20307 | Link |
Workaround
1) disable fast first pass option 2) activate distributed encoding mode with 2 local active encoding servers. Chuck size set to 0. encoding servers priority set to variable. This should help with CPU usage.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 20th September 2023 at 13:49. |
#20308 | Link | |
1) disable fast first pass option -you mean to encode in one pass cbr ? 2) activate distributed encoding mode with 2 local active encoding servers. - As far as I know Ripbot264 use Distributed Encoding Mode for connection between several PCs and I have only one PC. Sorry I'm just confused. Edit:Opss Understand: ![]() Last edited by Yopen71; 20th September 2023 at 14:48. |
#20310 | Link | |
With the help of Atak_Snajpera I managed to reach the full potential of my PC. Many many Thanks! |
#20311 | Link | ||
Make sure that you put 0.0.0.0 in unused slots! ![]() Then click on wrench icon and change priority from low to variable ![]() With variable priority there is higher chance that both chunks will be encoded at the same time. Quote:
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 20th September 2023 at 17:00. |
#20312 | Link | |
![]() Edit: Second pass cpu lose 50% With next movie I will try to activate server 3 and 4. Something strange happening,but it's not a big deal. ![]() Edit2: Problem with cpu solved. Using DE with 4 servers instead of 2 solve the problem.Great application! The only downside for me is, that I can't encode the audio stream separately from the video.I mean If I have to re-encode the audio stream I must to re-encode and the video stream again Last edited by Yopen71; 22nd September 2023 at 01:33. |
#20313 | Link |
Just asking why you would want to encode the audio stream separately from the video? You can encode the audio stream to pretty much whatever you want when you do the whole video in ripbot. When you add the video, in the encoder settings window change the profile under audio from x.xcopy stream (leaves audio alone) to whatever you want. I do this to convert from dts to AC3.
if you need to do the audio separately for some other reason, suggest using mkvtoolnix gui to extract the audio, then run it through Audacity to convert it, then use mkvtoolnix gui to add the new audio back in with the video. |
#20314 | Link | |
#20315 | Link |
Still I does not look right that you need 4 x264 encoders running at the same time to fully saturate 14 core cpu(6p+8e). For example 16-core AMD CPUs do not have that problem. I'm pretty sure win11 would do much better in this matter. Clearly win10 scheduler is doing something stupid here.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 21st September 2023 at 17:39. |
#20316 | Link | |
FOR %%f IN (*.mkv) DO E:\ffmpeg\bin\ffmpeg.exe -i "%%f" -map 0 -vcodec copy -scodec copy -acodec ac3 -b:a 640k "%%~nf"-AC3.mkv |
#20317 | Link | |
when I use 2 servers: pass1 cpu at 100%, pass2 cpu at 46% when I use 3 servers: 1 and 2 pass cpu at 100% I use 4 servers, to be sure ![]() Last edited by Yopen71; 22nd September 2023 at 01:46. |
#20319 | Link | |
![]() Interesting that you don't want to use L-Smash. There is a very new L-smash update, if you want to try that, https://github.com/HomeOfAviSynthPlu...tag/1141.0.0.0 there is also a recent update for FFMS2 as well. https://forum.doom9.org/showthread.p...52#post1991852 But if you want to use FFMS2 as your "decoder / indexer", then all you need to do is this :- Code:
overwrite this field in RipBot264.ini if you want to use FFMS2 instead of L-Smash [DefaultVideoDecoder] MPEG-2=FFMS2 VC-1=FFMS2 AVC=FFMS2 HEVC=FFMS2 OTHER=FFMS2
#20320 | Link |
Now I have a problem I can't get 2 PCs to communicate on the same network. establishes the connection but immediately closes with an error. ripbtot264temp\job1\chuncks\5.cmd. does not exist!
therefore the connection is also successful but then it is unable to exploit the other CPU |
