Old 29th March 2011, 12:43   #6181  |  Link
desta
Originally Posted by BetaBoy View Post
You are the only report that it still has issue.s Please confirm your running 2.5.1 and have even tried a reboot.
Sample: http://www.mediafire.com/?n4rlu8qja6b7ldd
desta is offline   Reply With Quote
Old 29th March 2011, 16:47   #6182  |  Link
Twingo
Thank you for the sample.... What are you using for a renderer? We are seeing mixed results here, it plays properly with most renderers but not all.
I'm using vmr9-renderless for it's required by MPC-HC to load the subtitle itself, so I don't know exactly which renderer it is, though I see coreavc decoder showing up in the filters section togerther with vmr9 renderless.
Twingo is offline   Reply With Quote
Old 29th March 2011, 18:35   #6183  |  Link
dead_screem
betaboy, I can't login to the core account portal. I forgot my password and I can't receive the reset emails, aol seems to be blocking them (and comcast as well, as I tried changing to a comcast email last time I had account access and they were blocking your emails too.)
I already have a support ticket open at http://support.corecodec.com/ open since the 24th but so far nobodys responed. Please look into it. The ticket number is #WMO-768-18430. Thanks.
dead_screem is offline   Reply With Quote
Old 29th March 2011, 20:39   #6184  |  Link
Ice =A=
Just tested 2.5.1 and it works well and seems to be a few percent faster (on a SandyBridge 2600) as well.
I'll test it on an Atom processor sometime where speed is more important than on a "real" cpu...
Also a bug in 2.0 which caused stuttering in some videos seems gone.
Good work as far as I can tell!
Ice =A= is offline   Reply With Quote
Old 29th March 2011, 20:42   #6185  |  Link
BetaBoy
CoreCodec Founder
BetaBoy's Avatar
Reports so far point are close to a 4-5% increase in speed.
Dan "BetaBoy" Marlin
Ubiquitous Multimedia Technologies and Developer Tools
http://corecodec.com
BetaBoy is offline   Reply With Quote
Old 29th March 2011, 20:44   #6186  |  Link
BetaBoy
CoreCodec Founder
BetaBoy's Avatar
PM me your info.... i'll look into it.
Old 29th March 2011, 20:59   #6187  |  Link
dead_screem
pm sent. thanks.
Old 29th March 2011, 21:11   #6188  |  Link
BetaBoy
CoreCodec Founder
BetaBoy's Avatar
Originally Posted by desta View Post
Im not seeing anything wrong with that clip here on my 3 systems.
Are you using Haali's splitter? or any custom renderer?
Old 30th March 2011, 01:35   #6189  |  Link
Chumbo
Chumbo's Avatar
@BetaBoy,
I just installed 2.5.1 and wanted to follow up on the two issues I reported earlier.
Regarding the smooth playback issue, still broken in software decoding and worse in DXVA as no video is rendered at all (MPC-HC using EVR Custom Pres). When it worked earlier via software and was smooth, it was because I forgot I had used the Haali Renderer temporarily.
Regarding the corruption issue, no video is rendered using MPC-HC EVR Custom Pres. With Haali Renderer, corruption still there and no DXVA which is expected.
Chumbo
Chumbo is offline   Reply With Quote
Old 30th March 2011, 09:00   #6190  |  Link
BetaBoy
CoreCodec Founder
BetaBoy's Avatar
Originally Posted by CiNcH View Post
CoreAVC pretty much relies on the source filter's information. Thought this was once fixed already. Most other decoders detect the format on their own without relying on the source filter's information.
They are doing it wrong. CoreAVC 'has to' propose an output format before it even sees any of the stream info, so it has no choice but to rely on the info from the source filter.
Old 30th March 2011, 09:06   #6191  |  Link
madshi
True, but once you start to receive bitstream and detect that the bitstream contradicts the source filter's information, it might make sense to do a dynamic format change. At least if there'd be corruption or crashes otherwise.
Old 30th March 2011, 11:08   #6192  |  Link
CiNcH
CiNcH's Avatar
Well it works correctly with the SW path of your decoder. Which means that even if the source filter propagates the wrong parameters the output is correct. Different story with the DXVA path as mentioned.
Other decoders work properly with wrong information too, even with DXVA.
Bye
CiNcH is offline   Reply With Quote
Old 30th March 2011, 13:24   #6193  |  Link
desta
I used Haali's splitter along with every renderer available in MPC-HC (x86 and x64).
update: Just downgraded my nvidia drivers from 266.58 to 258.96 and CoreAVC 2.5.1 now works with cuda enabled. Nvidia broke something?
Old 30th March 2011, 17:23   #6194  |  Link
dead_screem
betaboy, any news on getting my password changed?
Old 30th March 2011, 17:54   #6195  |  Link
BetaBoy
CoreCodec Founder
BetaBoy's Avatar
True, but once you start to receive bitstream and detect that the bitstream contradicts the source filter's information, it might make sense to do a....
Thanks madshi.... we are taking a look.
Old 30th March 2011, 18:48   #6196  |  Link
BetaBoy
CoreCodec Founder
BetaBoy's Avatar
PM sent with a new one.
Old 30th March 2011, 18:50   #6197  |  Link
BetaBoy
CoreCodec Founder
BetaBoy's Avatar
ok for the info... we are gonna look into it more.
Old 30th March 2011, 19:55   #6198  |  Link
dead_screem
Thanks much! I also sent a new PM with additional info, be sure to read it.
Old 30th March 2011, 21:38   #6199  |  Link
desta
Any news on this or do I need to keep my nvidia drivers out of date to use CoreAVC now?
Old 31st March 2011, 01:19   #6200  |  Link
thewebchat
Advanced Blogging
Just tested Core 2.5.
About performance: exactly the same as 2.0 (lol @ "faster overall" --> 139.5 fps vs 139.2 fps)
About 64-bit support: still slower than 32-bit version (133 fps vs 139 fps)
I think this release is pretty much the definition of underwhelming. Unless there's something magical about Core DXVA that's not already in 9001 other decoders (frame read-back to system memory?), I'm struggling to find a reason for anyone to get this.
Pretty much every niche that Core tries to cover is already occupied by free software:
Software decoding: DivX H264, ffmpeg-mt
DXVA: Windows 7, MPC-HC
CUDA: nevcairel's CUVID decoder
Too bad, too sad. It's too late for CoreCodec to try to remain relevant with their sub-standard products.
thewebchat is offline   Reply With Quote
codec, coreavc, corecodec, coremvc, cuda, decoder, dxva, h.264, mvc, scam
