Old 5th September 2005, 14:00   #41  |  Link
nm
Since you also list decoders, perhaps libavcodec (used in ffmpeg, ffdshow, MPlayer etc.) should be mentioned. After all, it contains the only usable open source H.264 decoder.
Old 5th September 2005, 15:00   #42  |  Link
DmitriyV2
MSU G&M Lab
DmitriyV2's Avatar
Yes, I know this lib. When I see it last time - there was big problems with code.
But ok, it's updated permanently as I see:
http://www1.mplayerhq.hu/cgi-bin/cvs...cvsroot=FFMpeg
Added!
Thanks!
With regards
Dmitriy Vatolin
www.compression.ru/video/ (Last updates: MSU Video Quality Metric 10.1 - faster&more useful)
DmitriyV2 is offline   Reply With Quote
Old 5th September 2005, 21:30   #43  |  Link
bond
btw you should also add the nero avc decoder, cause the decoder used in nero's products was developed by nero themselves, not ateme
Ogg Theora | Ogg Vorbis
Old 6th September 2005, 20:48   #44  |  Link
DmitriyV2
MSU G&M Lab
DmitriyV2's Avatar
I found only http://www.nerodigital.com/enu/PR_2004_05_27.html and several places, where Nero + Ateme was declared. What link can be used for
themselves Nero AVC Decoder?
With regards
Dmitriy Vatolin
Old 8th September 2005, 21:36   #45  |  Link
DmitriyV2
MSU G&M Lab
DmitriyV2's Avatar
List update:
+ KDDI R&D Labs
+ Hughes Network Systems, LLC
+ Conexant Systems, Inc.
+ some fixes
direct link: http://forum.doom9.org/showthread.ph...420#post673420
53 list items now.
Enjoy!
With regards
Dmitriy Vatolin
Old 8th September 2005, 21:55   #46  |  Link
DmitriyV2
MSU G&M Lab
DmitriyV2's Avatar
+ Sigma Designs
54 list items now!
Old 18th September 2005, 02:19   #47  |  Link
DmitriyV2
MSU G&M Lab
DmitriyV2's Avatar
List update:
+ Cradle Technologies, Inc.
+ STMicroelectronics
+ PacketVideo Corp.
+ some fixes
57 list items now.
Enjoy!
With regards
Dmitriy Vatolin
Old 8th October 2005, 10:47   #48  |  Link
hpn
Not sure if this one is already in the list:
http://www.imagicity.com/products/products.htm
hpn is offline   Reply With Quote
Old 8th October 2005, 10:52   #49  |  Link
baer999
When does the new comparision of all these codecs start ?
baer999 is offline   Reply With Quote
Old 23rd October 2005, 03:38   #50  |  Link
qyqgpower
SONY have released their AVC encoder when PSP 2.0 FW was available.
Image Converter 2 Plus
can buy it online from here
http://www.jp.sonystyle.com/Nws/Soft...710489100.html
and also an AVC encoder is provided in SONY's NLE Vegas 6c(30days free trial available).
http://www.sonymediasoftware.com/pro...ct.asp?PID=965
have discussed in this thread: http://forum.doom9.org/showthread.php?t=100418
qyqgpower is offline   Reply With Quote
Old 10th November 2005, 11:19   #51  |  Link
dragongodz
dragongodz's Avatar
Cyberlink also have an AVC encoder aswell
http://www.cyberlink.com/multi/produ...in_43_ENU.html
mpeg4 SP and AAC appear to have been introduced in version 1.5 according to 1 of their press releases, which are online there. however only version 1.0 appears to be available for download for a 30 day trial.
also the JM reference is up to version 10.1 by the way.
Narrator: And of course, with the birth of the artist came the inevitable afterbirth - the critic. (History of the World part 1)
dragongodz is offline   Reply With Quote
Old 10th November 2005, 22:53   #52  |  Link
DmitriyV2
MSU G&M Lab
DmitriyV2's Avatar
Included, thanks!
Originally Posted by qyqgpower
SONY have released their AVC encoder when PSP 2.0 FW was available. Image Converter 2 Plus ....
Good links! Thanks!
http://www.cyberlink.com/multi/prod...ain_43_ENU.html
Ok! Hope 1.5 version will appear.
well!
List update:
+ SONY Video Editor Vegas 6c with H.264/AVC support
+ PowerEncoder MPEG-4 AVC
+ Imagicity optimised H.264/AVC codec
+ Image Converter 2 Plus
+ some fixes (remove some comments to fit in 16K)
60 list items now.
Enjoy!
Old 10th November 2005, 22:55   #53  |  Link
DmitriyV2
MSU G&M Lab
DmitriyV2's Avatar
Originally Posted by baer999
When does the new comparision of all these codecs start?
See http://forum.doom9.org/showthread.ph...020#post730020
Old 11th November 2005, 00:06   #54  |  Link
bond
guys check the details plz!!!
its known cyberlink doesnt have an own encoder! they till now used the one from moonlight!
so cyberlink is not an own avc encoder! its a wrapper tool for the moonlight encoder and shouldnt be listed as on own codec, but rather be totally removed or listed under moonlight
the same way mainconcept should be either removed or listed under elecard, as mainconcept uses elecards encoder
Old 26th November 2005, 20:25   #55  |  Link
Hyper Shinchan
In the hardware list you could include the (useless imo) I-Pod 5th generation. It supports AVC baseline @L1.3, right?
Hyper Shinchan is offline   Reply With Quote
Old 30th November 2005, 23:22   #56  |  Link
DmitriyV2
MSU G&M Lab
DmitriyV2's Avatar
List update:
+ t264 - Open Source "Chinese" H.264 version
Bond, I check your info - MainConcept till now have there own H.264, but current developed version is updated by Elecard team, you right.
62 list items now.
Enjoy!
With regards
Dmitriy Vatolin
Old 1st December 2005, 11:30   #57  |  Link
dand
Danijel.Domazet
dand's Avatar
Same codec...
Dmitriy,
As Elecard was taken over from Moonlight by MainConcept, there is no more Moonlight (they recently announced liquidation on their web site - now even the web site is gone). Moonlight probably didn't have much of a development team, all was done in Elecarard I suspect, so when they lost Elecard they lost everything.
On the other hand, Mainconcept has it's own dev team, which is now working together with Elecard's team. The H264 codec from Elecard and MainConcept is the same, and it should not be stated twice in your list.
Also from THIS thread it is obvious that Sony licensed H264 from MainConcept, so I don't see the point of listing Sony eather, it's the same codec.
I would: remove Moonlight, remove Sony, join Elecard and MainConcept - 3 entries less in the list.
Hope this helped to make things clearer.
dand is offline   Reply With Quote
Old 2nd December 2005, 13:57   #58  |  Link
bond
Originally Posted by dand
Dmitriy,
1) the moonlight avc and elecard avc encoders/decoders are totaly different ones! so moonlight shouldnt be removed
2) i am not sure that sony uses the elecard encoder too, at least i never heard a statement about that from elecard devs, which are around on doom9
Old 2nd December 2005, 15:06   #59  |  Link
dand
Danijel.Domazet
dand's Avatar
They are different - probably because Elecard's AVC evolved in the meantime. Just a guess.
Try to get the latest version of AVC from Moonlight and let us all know what's their web page.
I said Sony uses MainConcept's AVC (which is now the same as Elecard's). So it's not Sony's. Download Sony Vegas trial and you will see the AVC dll properties say "mainconcept", as the above mentioned thread stated first.
I am sure you didn't miss the info about Elecard/MainConcept joining forces.
If we are interested in the future of AVC, it all comes down to the following: we will not have Moonlight's and Sony's AVC solutions, Elecard and MainConcept will provide same thing.
Old 2nd December 2005, 15:29   #60  |  Link
bond
i am not guessing, i know that elecard and moonlight are totally different encoders/decoders, as the devs told me so
well its an indication, but might not be a 100% proove that sony uses elecards encoder
i would only say thats for sure if elecards devs confirm that its really that way
