#602 | Link |
January 15, 2025 release version 3.3.7. ---------------------------------------------------------------------------------- Added: Keep all cuts until joined or deleted in join grid. Cut times info in join grid. Add files button allows add multiple files now. Check in reading BT_open.txt if the file exists. Custom setting in audio length & pitch change presets. File exists check for source video in main page grid. Reading title from handler_name tag and delete it with muxing. Drag video to program icon to start with it. Attachment info in mux grid (with mkv container). Multichannels extract/join from 2ch to 8ch (to/from pcm files). Chapters are shown as stream now. Video play button in chapters allows searching for chapter times. Endtime reset to duration with endtime > duration in cut grid. Fixed: Bug with simple remux. Bug in automatic output file renamer. Bug with changing index in join grid. Bug in sample multiplex. Bug with crop (metadata only); only even values are admitted now. Bug with missing success message after source-/added streams are muxed. Bug with missing streams selection, opening mux grid. Bug with double message in mux grid. Bug with container selected and pcm codec with output file name. Bug with progressbar in join grid (only ffmpeg line now). Bug with chapters unchecked, opening extraction grid. Bug with range setting with ffplay (search/preview) in cut section. Bug in file naming with extract font. Bug with missing success message in main page grid. Bug in add chapters with starttime 0 (main page grid). Bug with buttons locations in many help windows. Bug with mux aborting. Bug with single chunks duration in join grid. Bug with chapters creation (wrong times) in join grid. Bug with missing temp file deletion in join grid. Improved: Join grid. Many little cosmetics and code improvements. Changed: Update check moved to settings. No drag & drop in batch grid with more than 1 entry. Fast start checked by default for mp4 and mov in mux grid. Audio length & pitch change from textbox to presets. Columns alignment to fit content in all grids. Multiplex grid remains open as long as streams exists. Muxed streams are removed from grid (from source and added too). Mux attachments settings. Select/deselect all streams behavior in various grids. Batch/multiplex grid shows filnames without path now. Default tag behavior in mux grid (unselected now). Muxed streams label behavior in mux grid. Removed: Update reminder. ---------------------------------------------------------------------------------- |
