18th February 2014, 08:15 | #1302 | Link | |
Added to the list of known extensions.
Want to know all about your media files? http://mediaarea.net/MediaInfo |
16th April 2014, 14:11 | #1304 | Link | |
Swallowed in the Sea
From which tool you're using the last release ?
coz, it works fine for me using my own build : Quote:
19th April 2014, 19:38 | #1306 | Link | |
I don't try to understand, I actually switched to MSVC 2010 (I hop there is no more Win95 users in 2014!). Here is a Development snapshot
26th April 2014, 16:19 | #1308 | Link |
Software Developer
FWIW, here's a set of fresh MediaInfo v0.7.69 builds, all fully static:
http://sourceforge.net/projects/muld...8CLI%2BGUI%29/
19th June 2014, 16:55 | #1309 | Link |
While playing around with an MPEG2 HD test clip I got a little disturbed because MediaInfo and DGIndex cannot agree on the audio delay...
DGIndex reports 12ms while MediaInfo insists on -53ms. Which one is correct? The file is here: http://www.w6rz.net/1080p30.zip Visually testing lip sync doesn't work here because the audio is silent. Cheers manolito |
19th June 2014, 17:08 | #1310 | Link |
It's hard to say which is "correct" without specifying how the demuxing is done, and where the video will start.
For example, if both apps demux the audio the same but one discards leading B frames while the other does not, then the delay will be different. I'll have a look at your stream and see if I have any comment to make about it. |
25th June 2014, 07:22 | #1312 | Link | |
Frame 0 (2 in presentation order): PTS 1.768, DTS 1.668 Frame 1 (0 in presentation order): PTS/DTS 1.702 Audio: Frame 0 : PTS 1.715 There is a bug somewhere in MediaInfo (it takes the PTS of the frame 2 in presentation order, not good). DGIndex is right.
25th June 2014, 07:24 | #1313 | Link | |
GUI work is still something I would like to create again from scratch, but sponsored features have still the priority.
14th July 2014, 11:58 | #1315 | Link |
I'm running a bach script for MediaInfo CLI
template="file:///volumes/video/Temp/MediaInfoPara.txt" output="/volumes/video/Temp/MediaInfoOut.txt" mediainfo --Version totfiles=$(find . -name "*.mkv" -o -name "*.m4v" -o -name "*.avi" | wc -l) echo "Number of movies to check: " $totfiles [[ -f "$output" ]] && rm -f "$output" find . -name "*.mkv" -o -name "*.m4v" -o -name "*.avi" | while read movie do counter=$((counter+1)) echo -n "$((${counter}*100/${totfiles})) % " echo -n R | tr 'R' '\r' mediainfo --Inform=$template "$movie" >> $output done Everything is imported to Excel and works great except i have problems if there are many audio tracks leading to that subtitle 1 is not always in column XYZ. Any advice how to fix my script so the result is always zyx columns and first subtitle is find in column ccc. It's ok to maximize numbers of audio tracks like max 3 or 5. |
14th July 2014, 12:06 | #1316 | Link | |
For the moment, I coded something in the Windows GUI for having a fixed count of tracks (e.g. 5 audio tracks), but it is not yet moved to the CLI. I have no idea about when I'll have time to work on such extra feature on my side (not a priority of my sponsors), you are on your own (find another tool which can transform XML to CSV?)
25th July 2014, 08:48 | #1318 | Link |
1) What is the parameter to get color primaries, this doesn't work
mediainfo --inform="Video;%Color_Primaries%" filename 2) Is it possible to separate a BluRay Remux (no encoding settings) made with eac3to from a encoded mkv with stripped/missing encoding settings useing mediainfo Last edited by RandomDude; 25th July 2014 at 10:04. Reason: typo |
25th July 2014, 08:54 | #1319 | Link | |
do mediainfo -f --Language=Raw in order to get the list of internal names you need for the template.
25th July 2014, 09:42 | #1320 | Link |
The support of templates is currently very limited, you need to use the library directly in order to do exactly what you want.
