Old 29th April 2024, 06:57   #41  |  Link
simple_simon
Originally Posted by Boulder View Post
I think it's not changed much. What errors do you get?
I think I got it figured out. I changed "sstr" to "str" in line 65. I was also getting an error saying it didn't know what "limit" meant or something before but now I can't reproduce that again.
I'm still not sure how you use the debug switches to figure out the values to use? Do I just use the settings listed on screen? And debug=1 doesn't seem to do anything. How does it help determine the prefilter version to use?
simple_simon is offline   Reply With Quote
Old 29th April 2024, 07:08   #42  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Yes, use the values shown in debug=6 to see if thscd1 and thscd2 are set correctly in your script and adjust based on if there are clear missed scene changes or false detections. Nowadays I usually adjust thscd1 unless it gets insanely high, but the range can easily be 300-700 depending on the source and prefiltering.
Debug=1 interleaves the original and prefiltered video so you need to step back and forth in the video in VDub to see the effect.
Looking at the code more thoroughly, I do have a more recent version of the script on my system. I can post it if you want to try it out. There's at least more prefiltering options and some more debug options for determining what the script does to the video.
Old 1st May 2024, 16:30   #43  |  Link
simple_simon
Ok, I understand debug=1 now. But I don't know what's going on in debug=6. It's probably because I'm not familiar with mvtools. Do I just copy the thscd1 & thscd2 from the stats listed in yellow? Or how do I determine if they are correct or need adjustment? And what are the stats in grey that change every frame that are above the yellow stats that never change? Also really not sure how to determine limit and blurlimit using debug=2.
And sure, please post newer script when you get a chance.
Old 1st May 2024, 18:14   #44  |  Link
Boulder
Pig on the wing
Boulder's Avatar
In debug=6, the yellow values are the function parameters currently in use. Then at the top, the first grey value tells you the average SAD of the blocks in the frame. The second value tells you how many blocks are over the limit set by the thscd1 parameter. The thscd2 parameter is used to tell how many blocks can be over the limit before the frame is considered to be a scene change. So in this debug mode, you should find some good representative range of the source (which includes scene changes) and check what values the average SAD shows and if there are false scene changes detected or clear ones missed. In a scene change frame, the first grey value usually shows a quite high value and also the dots and lines representing the motion vectors are gone. Usually with clean sources, you can lower thscd1 while a very grainy source requires a higher value. The prefiltering you select affects this part as well.
Here's the latest version. I'm not entirely sure if the dependecies are the exact same as I have all Dogway's packages in my Avisynth autoload folder. It should work fine with the latest versions.
https://pastebin.com/TX2g5E2m
Debug=7 now shows you interleaved comparison of the original frame, original vs. the blurred frame (used in MDegrain for bigger weight on areas which have more motion), original vs. MDegrain and finally original vs. filtered. Debug=8 shows the same but with a more pronounced effect.
I always use debug=7 to adjust the settings; the blurred frame for adjusting blurlimit and bias and the MDegrain frame for thsad and limit. Quite often I try to set limit so that the MDegrain frame starts showing a slight difference. With a low value, the frame might just look all black. The PlaneMDSI value is a metric which tells how big the change is. I've noticed that in the MDegrain frame, it usually needs to be over 0.1 in order to see any real effect in the final result.
After adjusting the parameters, use debug=2 to see how it looks in "real life", it interleaves the original and filtered frame. Change those values a lot and you can see the effect quite easily.
There's also five different prefilters with prefilter=1..5 with increasing strength.
Old 11th May 2024, 09:18   #45  |  Link
tormento
Acid fr0g
tormento's Avatar
I am getting good results with what I listed above
Can you give us some numbers that you proved to be ok?
@turment on Telegram
grain, x265
