Old 14th December 2001, 15:36   #1  |  Link
loopidz
Newbie Stoopid Help me Im an idiot
I have been fiddling arround with the new xmpeg 4.2 ... and everytime i set it up to convert i receive this silley error ... " cannot generate outpout file" this is very anoying ... i have no clue what to do from here .. please help this hapless hopless brain dead old fart ...
thanks
loopidz is offline   Reply With Quote
Old 14th December 2001, 20:00   #2  |  Link
formentz
formentz's Avatar
What about the Guides?
Look in The Guides section, there is a full explanation on how to use XMpeg
Ciao
Formentz
formentz is offline   Reply With Quote
Old 15th December 2001, 00:29   #3  |  Link
poydog
i had the same problem. i think the in one of the previous posts it was mentioned that there was a problem with the proper audio codec not being copied.
Get divx 3.11alpha (at doom9.org) and uninstall the 4.11 codec first.
Install 3.11 alpha and execute the run me first.
then install 4.11 over the 3.11 codec and overwrite the files. You should be able to encode properly.
someone also mentioned installing the Avireg file too. try that also.
poydog is offline   Reply With Quote
