Old 12th December 2001, 22:32   #1  |  Link
ReFuGeE
File Splitter Mpegs, what proggy do i use?
I have converted my .avi file to mpeg and now I need to split it into 2 files to fit onto a cd. Which program should i be using and how do i go about doing so? THANKS!
ReFuGeE is offline   Reply With Quote
Old 12th December 2001, 23:41   #2  |  Link
pacohaas
Audio Moderator
clearly you didn't take the time to look for a guide, or even try anything, so i'm giving you just a program name, there may be more, try looking for yourself:
TMPGEnc
{-n24-}
The Old Fair Use Homepage
pacohaas is offline   Reply With Quote
