Old 9th December 2001, 17:15   #1  |  Link
rpratt
Flask Audio Decoding Problem
I used CladDVD 2.0 to rip a dvd. Afterwards I am trying to use flask to make them into an mpeg file. I'm using a program that tells me step by step how to do all this. In the program it says that decode audio must be marked. But it is greyed out. Please tell me how to fix this problem.
rpratt is offline   Reply With Quote
Old 14th December 2001, 09:59   #2  |  Link
Znarf
Why don't you use XMPEG or Flask
I can't help you, because I don't know which software you used.
But why don't you you Flask Mpeg, or XMpeg (better). There is a good guide on Doom9 site !
And if you need some help on this soft, you can ask help to everyone here !
Good luck
Divx ?? You said Divx ??
Znarf is offline   Reply With Quote
Old 14th December 2001, 10:21   #3  |  Link
hakko504
Remember Rule One
hakko504's Avatar
You have an audio track that doesn't have DolbyDigital audio. See if there is another track that can be used. Otherwise you just have to extract the audio with another program. Doom9 has some good guides on the subject...
/hakko
http://www.boardgamegeek.com
hakko504 is offline   Reply With Quote
Old 14th December 2001, 12:12   #4  |  Link
Captain_Nipple
Captain_Nipple's Avatar
Vob2Audio
Vob2Audio is a great little program. It will convert the sound to VBR mp3 in one pass for ya. Lame is a better option for VBR, but Vob2Audio is good because of it's ease of use (Vob -> mp3). Lame has to have a WAV made first. Check it out in the download section.
Captain
Captain_Nipple is offline   Reply With Quote
