Old 16th January 2014, 08:55   #1  |  Link
Gaby83
言承旭...我爱你!
Gaby83's Avatar
Avisinth error loading a script with TempGaussMC_beta2
Hi, I've used this script many times and it worked pretty well, but I had to format my computer and stop encoding from some months, now that I want to keep encoding, the script doesn't work, I don't know what's happening, I tried redownloading all the plugins (because maybe one of them was corrupt or something) but it doesn't work, can you guys please help me?
This is the error I'm getting:
This is my script:
LoadPlugin("DGDecode.dll")
LoadPlugin("Decomb.dll")
LoadPlugin("nnedi3.dll")
LoadPlugin("mt_masktools-26.dll")
LoadPlugin("mvtools2.dll")
LoadPlugin("RepairSSE3.dll")
LoadPlugin("RemoveGrainSSE3.dll")
LoadPlugin("VerticalCleanerSSE2.dll")
LoadPlugin("vinverse.dll")
Import("TempGaussMC_beta2.avsi")
MPEG2Source("video.d2v")
LanczosResize(656,height)
AssumeTFF()
TempGaussMC_beta2(1,1,2,EdiMode="NNEDI3")
selecteven()
vinverse()
Tweak(bright=-5, sat=1.1)
Thank you in advance!
Gaby83 is offline   Reply With Quote
Old 16th January 2014, 09:13   #2  |  Link
feisty2
I'm Siri
feisty2's Avatar
"merge" is an internal avisynth filter, check your avisynth version
feisty2 is offline   Reply With Quote
Old 16th January 2014, 10:06   #3  |  Link
Gaby83
言承旭...我爱你!
Gaby83's Avatar
Hello, thanks for your answer.
I use the latest version of avisynth, Avisynth 2.5.8 that I downloaded it from here:http://sourceforge.net/projects/avisynth2/
Old 16th January 2014, 10:25   #4  |  Link
Gavino
Avisynth language lover
In that case, you should be using mt_masktools-25.dll, not mt_masktools-26.dll.
Old 16th January 2014, 10:41   #5  |  Link
Gaby83
言承旭...我爱你!
Gaby83's Avatar
Thank you! Maybe I downloaded a different version of avisynth last time, now I changed mt_masktools-26.dll for mt_masktools-25.dll and i think it worked, but now it gives me another error...
It seems it's time for RemoveGrain to give me a headache, lol, any ideas?
Old 16th January 2014, 12:24   #6  |  Link
Taurus
Taurus's Avatar
Dont use the SSE3 versions for:
Take the SSE2 instead.
Or take the package from the QTGMC thread.
Try the basic package and/or the modded one.
Not the experimental one. Might give you headache .
It's all explained very well over there.
Taurus is offline   Reply With Quote
Old 16th January 2014, 13:58   #7  |  Link
Gaby83
言承旭...我爱你!
Gaby83's Avatar
Thank you but it keeps giving me the same error even with SSE2
LoadPlugin("mt_masktools-25.dll")
LoadPlugin("RepairSSE2.dll")
LoadPlugin("RemoveGrainSSE2.dll")
AssumeTFF()
selecteven()
vinverse()
Old 16th January 2014, 14:09   #8  |  Link
Reel.Deel
It sounds like you're using an older version, use RemoveGrain v1.0b.
Old 16th January 2014, 14:27   #9  |  Link
Gaby83
言承旭...我爱你!
Gaby83's Avatar
Yay! That definitely solved the problem! Thank you very much for your help guys!
error, merge, tempgaussmc_beta2
