Old 29th October 2021, 00:07   #4561  |  Link
lansing
Originally Posted by Myrsloik View Post
Use createVideoFilter2() and then simply call invoke on the node returned from there. Same idea.
Not the best example but few places do this in the VS code (see unpackRGB32Create):
https://github.com/vapoursynth/vapou...ompat.cpp#L897
So the structure would be like this?
static const VSFrame *VS_CC firstGetFrame() {}
static const VSFrame *VS_CC finalGetFrame() {
    return frame;
void VS_CC filterCreate() {
    d.node = vsapi->mapGetNode(in, "clip", 0, 0);
    // call invoke on node
    VSNode * node2 = vsapi->createVideoFilter2(firstGetFrame, freeFunc1, data);
    // call invoke on node2
    d.node = node2;
    vsapi->createVideoFilter(finalGetFrame, freeFunc2, data);
Old 29th October 2021, 00:20   #4562  |  Link
Yomiko
from boxblur
https://github.com/vapoursynth/vapou....cpp#L294-L307
Yomiko is offline   Reply With Quote
Old 29th October 2021, 04:44   #4563  |  Link
lansing
I'm seeing two patterns from the examples above about chaining invoke, it got me confused:
invmap2 = vsapi->invoke(stdplugin, "Trim", invmap);
vsapi->mapConsumeNode(invmap, "clipb", vsapi->mapGetNode(invmap2, "clip", 0, nullptr), maAppend);
invmap2 = vsapi->invoke(stdplugin, "PlaneStats", invmap);
#2
vsapi->createVideoFilter(vtmp2, "BoxBlur", xxx);
vtmp1 = vsapi->invoke(stdplugin, "Transpose", vtmp2);
In the first example, after the first invoke, the resulting node has to be consumed into a new map before pluging it into another invoke.
But in the second example, the resulting map just go straight to an invoke without the node consume?
Old 29th October 2021, 09:41   #4564  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Sometimes thebmap returned from invoke has the right contents and then it can be passed to invoke immediately. If it doesn't you have have to do more map manipulation.
Myrsloik is offline   Reply With Quote
Old 30th October 2021, 05:17   #4565  |  Link
lansing
Originally Posted by feisty2 View Post
ShufflePlanes should automatically strip the "_Matrix" property if the target color family is vs.GRAY. otherwise an error message pops up bitchin' about "no _Matrix stuff allowed for GRAY" or whatever and you have to manually remove the "_Matrix" thingy before ShufflePlanes which is very annoying.
I just encountered this annoyance, is there a better solution now?
Old 30th October 2021, 06:40   #4566  |  Link
lansing
Format conversion from a Shuffleplanes causes a shift in chroma?
clip = yuv_clip
clip = core.std.ShufflePlanes(clip, 0, colorfamily=vs.YUV)
#clip = core.resize.Point(clip, format=vs.YUV444P8)    // no shift
clip = core.resize.Point(clip, format=vs.YUV420P8)    // chroma shift
Old 30th October 2021, 14:51   #4567  |  Link
Yomiko
Point (nearest neighbor) is supposed to be like that. It never blends neighboring pixels.
Old 30th October 2021, 15:32   #4568  |  Link
lansing
There's a shift with all other resizers too. And I thought for format conversion purpose, all the resizers should be the same?
Old 30th October 2021, 17:20   #4569  |  Link
Selur
Selur's Avatar
An option to disable auto loading is probably coming soon. With more exciting things as well.
Any news in this regard?
Cu Selur
Old 30th October 2021, 23:04   #4570  |  Link
lansing
When extracting RGB planes from a RGB clip, Shuffleplanes is outputting the wrong clip if I set the "colorfamily" to YUV
rgb_clip = core.resize.Point(clip, matrix_in_s="709", format=vs.RGB24)
clip = core.std.ShufflePlanes(rgb_clip, 0, colorfamily=vs.YUV)
I was expecting to get a yuv clip of a grayscale, but this output a yuv clip of green and pink.
Old 31st October 2021, 12:27   #4571  |  Link
ChaosKing
Is there a replacement for https://github.com/AmusementClub/VapourSynth-EEDI2CUDA ? ( repo was deleted)
If not then I will remove it from vsrepo.
Old 31st October 2021, 12:39   #4572  |  Link
sl1pkn07
Pajas Mentales...
https://github.com/kedaitinh12/VapourSynth-EEDI2CUDA
but i'm not sure if is updated
[AUR] Vapoursynth Stuff
[AUR] Avisynth Stuff
sl1pkn07 is offline   Reply With Quote
Old 31st October 2021, 13:10   #4573  |  Link
ChaosKing
No releases
Old 31st October 2021, 13:46   #4574  |  Link
kedautinh12
Here: https://github.com/kedaitinh12/Vapou...2CUDA/releases
And i ain't a developer, if anyone have attention that project can folk them
Old 1st November 2021, 10:08   #4575  |  Link
LigH
LigH's Avatar
I guess that means: If anyone wants to maintain this project, please fork it.
New German Gleitz board
Old 1st November 2021, 11:43   #4576  |  Link
kedautinh12
Yes, sr for my bad English
Old 1st November 2021, 20:46   #4577  |  Link
Selur
Selur's Avatar
Did something change with vs-imwri?
I'm using R1 from https://github.com/vapoursynth/vs-imwri/releases/tag/R1 with Vapoursynth R57 and this code:
[logo, alpha] = core.imwri.Read(filename="C:/Users/Selur/smallLogo.png", alpha=True)
but get "Python exception: not enough values to unpack (expected 2, got 1)" same code worked fine (with the same logo) with R54 and the old plugin.
Tested on MacOS and Windows 10.
Cu Selur
Old 1st November 2021, 22:00   #4578  |  Link
Myrsloik
Myrsloik's Avatar
Cu Selur
logo = core.imwri.Read(filename="C:/Users/Selur/smallLogo.png", alpha=True)
alpha = core.std.PropToClip(logo)
Old 3rd November 2021, 05:46   #4579  |  Link
Selur
Selur's Avatar
Thanks that works!
Any news on an option to disable auto loading ?
Old 3rd November 2021, 08:15   #4580  |  Link
ChaosKing
Thanks that works!
I'm also waiting for it since 2018 now
speed, vaporware, vapoursynth
