Old 13th September 2016, 14:49   #1  |  Link
tsk1979
Transition effects from one clip to another
Hello
I am a photographer who assembles timelapse videos using virtualdub and avisynth.
I create individual frames from RAW files, and then use Imagesource.
I have been using "Dissolve" function with 10 frames to transition.
However, I see other photographers use some funky transition effects in aftereffects and other WYSIWYG editors where the current frames moves out upwards, and the next frame moves in from below(kind of like old TV V.hold error), and some more.
I am wondering, if there are other functions like Dissolve to create transition effects between clips.
tsk1979 is offline   Reply With Quote
Old 13th September 2016, 14:52   #2  |  Link
BakaProxy
Well you can do a lot with animate() and/or overlay() to make frames move and such. But that's gonna be a bit more difficult than just inputting 2 video streams into a function.
I'm sure someone here already made some fun wrapper functions for effects like these.
Verstuurd vanaf mijn SM-A500FU met Tapatalk
BakaProxy is offline   Reply With Quote
Old 13th September 2016, 15:49   #3  |  Link
See Transall by V.C Mohan:- http://www.avisynth.nl/users/vcmohan...ocs/index.html
V.C. Has lots of good stuff:- http://www.avisynth.nl/users/vcmohan/
EDIT: You might also find some stuff of interest amonst DavidHorman threads, eg
http://forum.doom9.org/showthread.php?t=152860
http://forum.doom9.org/showthread.php?t=166087
http://forum.doom9.org/showthread.php?t=165978
http://forum.doom9.org/showthread.php?t=172601
You can also go to David's Profile/Statistics and click on 'Threads started by DavidHorman' to see some other gems.
Old 14th September 2016, 08:37   #4  |  Link
tsk1979
Thank you. V.Cs stuff is what I need.
Old 14th September 2016, 21:34   #5  |  Link
rvs75
You can install DVD Slide GUI (http://download.videohelp.com/tin2tin/index.html), uncheck all additionals programs.
In "C:\Program Files (x86)\DVD slideshow GUI\Transitions" or equivalent, you can see some example with plugins and other files used by the scripts.
rvs75 is offline   Reply With Quote
dissolve, timelapse
