Old 5th October 2023, 14:01   #1  |  Link
ClubM
W10 Avisynth Zoom Plugin access violation
Dear forum.doom9 members.
I have question. I was trying to fix a older avs script that i made in the past.
It uses some older Avisynth plugins, which i've mostly replaced with modern ones.
However the plugin "zoom" created by WarpEnterprises:
http://avisynth.nl/index.php/Zoom
uses a certain animation i would like to keep indentical.
Unfortunately i can't see the animation sins it throws the following error
Error requestion frame 204 WindowsError: exception: access violation 0x10421FF4
So i was hoping someone could help me find a new solution to replace the older code but keep the zoom animation indentical.
Or if someone is able to recompile a new 64bit dll file compatible with the latest avisynth that would be most ideal.
Here is the original code:
ConverttoRGB32(matrix="Rec601", interlaced=false).zoom(factorX="n>20 ? pow(n-20, (0.02*(n/16))) : 1", factorY="n>20 ? pow(n-20, (0.02*(n/16))) : 1")
ConverttoRGB32(matrix="Rec601", interlaced=false).zoom(factorX="n>0 ? pow(n, (0.02*(n/13))) : 1", factorY="n>0 ? pow(n, (0.02*(n/13))) : 1")
Some additional information:
I'm running
AviSynth+ 3.7.2 (r3661, 3.7, i386)
in conjunction with
AvsPmod_v2.7.5.4_.Windows_x86-32
OS: Windows 10 Pro Version: 22H2 64-bit
I even tried to install the 64-bit compiled version by Paser
https://forum.doom9.org/showthread.p...48#post1668648
However it's probably just too old at this point in time.
ClubM is offline   Reply With Quote
Old 5th October 2023, 14:19   #2  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Here the test script worked OOTB with Zoom 64bit (15.02.2014):
Version().ConverttoRGB32().zoom(dstx="n", angle="n/10")
AviSynth+ 3.7.3 (r4003, 3.7, x86_64)
in conjunction with
AvsPmod_v2.7.5.4_.Windows_x86-64
OS: Windows 10 Pro Version: 21H2 64-bit
The other example and your 2 scripts do run as well.
Old 5th October 2023, 14:35   #3  |  Link
ClubM
Hi Emulgator,
That's interesting you don't seem to have any issues?
Hmm that's strange i tried running the version code to see if that worked.
But instantly avspmod returns a error message.
https://i.postimg.cc/G3D1dbqs/zoom-error.png
Perhaps updating my AviSynth+ will fix it?
Thanks for checking i'm gonna try to update to the latest version.
I'll be sure to give a update here it that solves my issue.
Old 5th October 2023, 15:04   #4  |  Link
kedautinh12
Try with latest vcredist
https://github.com/abbodi1406/vcredist/releases
Old 5th October 2023, 15:28   #5  |  Link
ClubM
I think i found the issue.
I was testing the code in the 32bit AvsPmod editor sins i still have some older plugins that only work in 32 bit.
However by using the 32bit AvsPmod editor the software is excessing the older "[x86] - zoom_dll_20050122.zip" zoom plugin.
Which seems to have the "WindowsError: exception: access violations" issues.
Most likely the older 32bit dll needs to be recompiled with a new header and maybe requires some small changes to the original code.
A workaround is to use 64bit AvsPmod which will call the [x64] - Zoom.7z plugin instead.
That's probably why Emulgator didn't have any issues calling the plugin.
Now i wonder do you guys know if it's possible to fix the older 32 bit dll?
I don't know if the original source code is available.
And i'm not a programmer so i would have to rely on a kind soul who wants to do it.
But if it's something really easy i would love if someone could update the older dll file.
But than again maybe that's asking too much.
The only reason why i would like a 32bit version is to combine it with older plugins that haven't been ported to 64 bit.
Old 5th October 2023, 15:32   #6  |  Link
ClubM
Originally Posted by kedautinh12 View Post
Oh btw thanks kedautinh12 for thinking along
I already installed the latest vcredist.
But it's a good tip because in the past i did have some issues with that on Windows 7. Appreciate it.
Old 6th October 2023, 03:00   #7  |  Link
kedautinh12
Maybe you can ask Asd-g add support latest avs+, high bit depth, more colors space from here (create issue):
https://github.com/Asd-g/AviSynthPlus-Scripts/issues
plugin, warpenterprises, zoom
