Old 24th July 2012, 22:42   #1  |  Link
JELSTUDIO
how to zoom in on a single pixel without blurring?
I'm trying to figure out how to make a video where there's a zoom going on from the full image and into a single pixel WITHOUT the pixels being blurred during zooming.
I've tried 'animate' but that won't allow the use of PointResize as argument, and BicubicResize does the blur-thing I'm trying to avoid.
I also tried using 'zoom.dll', but couldn't avoid the blurring there either.
Anyone with an idea on how to do this?
JELSTUDIO is offline   Reply With Quote
Old 25th July 2012, 00:04   #2  |  Link
Didée
Animating PointResize does work for me. Are you sure you don't have an error in syntax or parameters?
vid
animate(1,100,"pointresize",  width(vid),height(vid), 0,0,width(vid),height(vid),  width(vid),height(vid), 100,150,1,1)
Destination pixel is located at x=100,y=150 , obviously.
Old 25th July 2012, 00:53   #3  |  Link
JELSTUDIO
Apparently I did have something wrong with the line I was attempting to use.
I was using this line (which works until I replace BicubicResize with pointresize):
clip=last
Animate(10,400,"BicubicResize", clip,1920,1080,1.0/3,1.0/3,0,0,1920.0,1080.0,
 \ clip,1920,1080,1.0/3,1.0/3,960.0,540.0,1.0,1.0)
Your code-snippet works
Thanks a lot
Ahhhhhh, figured out the error now. This line works:
Animate(0,2000,"pointresize", clip,1920,1080,960.0,540.0,1.0,1.0, clip,1920,1080,0,0,1920.0,1080.0)
It's the little things that does it sometimes
Old 25th July 2012, 03:11   #4  |  Link
*.mp4 guy
*.mp4 guy's Avatar
For a second there I thought that someone had just gotten done watching an episode of CSI...
*.mp4 guy is offline   Reply With Quote
blur, pixel, pixelated, zoom
