Old 3rd August 2011, 15:52   #1  |  Link
Analytic
MPC-HC: How to use Jump functions on a remote control?
I use MPC-HC all the time to play on my HDTV and want to invoke the MPC-HC Jump functions via the fast forward/reverse or even next/prev track buttons on the Windows Media remote control that came with my HP notebook. It's not clear which if any of the dozens of keybindings will work for this and I've tried some obvious ones like VK_MEDIA_PREV_TRACK and VK_PRIOR without success.
If anybody can use the MPC-HC Jump functions on a remote control, please tell how you got it to work. Thanks!
Analytic is offline   Reply With Quote
Old 3rd August 2011, 19:27   #2  |  Link
JanWillem32
JanWillem32's Avatar
I've been using LM Remote KeyMap for my remote for some time, as it allows you to view any default or set a custom key binding for any button on the remote.
development folder, containing MPC-HC experimental tester builds, pixel shaders and more: http://www.mediafire.com/?xwsoo403c53hv
JanWillem32 is offline   Reply With Quote
Old 5th August 2011, 22:44   #3  |  Link
Analytic
Excellent! Works just great. Problem totally solved. Thanks so much for that tip.
jump, mpc-hc, remote control
