Old 24th August 2019, 02:21   #17241  |  Link
byteshare
ByteShare
byteshare's Avatar
Originally Posted by FuzzyNutz View Post
What is the latest version of the core? I have 1.25.0.0.
Core 2019.08.23 You have to look in the Settings > Tools > Installed Tools > Core
The RipBot version in the main window doesn't change with updates always, so it will still read 1.25.0
Personally the Window name should just be RipBotx264
and the version should be pulled from something else and shown in the main GUI, so that when updates are pushed out only changing the updater version or an .ini file would be required rather than recompiling GUI or something like that so even when filters are updated we'd see a version change.
Old 24th August 2019, 02:46   #17242  |  Link
FuzzyNutz
I'm up to date. Thanks.
I'll chime in once I know if the frame flickering seems resolved.
FuzzyNutz is offline   Reply With Quote
Old 24th August 2019, 04:36   #17243  |  Link
FuzzyNutz
I'm still getting the flickering with core 08-23.
Old 24th August 2019, 06:41   #17244  |  Link
byteshare
ByteShare
byteshare's Avatar
Huh...I'm not, but you can switch back to FFMS2 if you weren't having an issue with that one.
Since 8.20 I wasn't having the issues since the Encoding Servers stopped trying to recreate the index files...at least on the 6 files that I had flickering between the 2-4 encodes for each with versions since the LSmash addition but before 8.20.
Old 24th August 2019, 07:10   #17245  |  Link
FuzzyNutz
I'm not using DE. What's FFMS2?
Old 24th August 2019, 07:14   #17246  |  Link
byteshare
ByteShare
byteshare's Avatar
Using DE mode doesn't matter, since 8.20 the way indexing works is different. I confirmed the flickering in DE and non-DE and then it working in both.
FFMS2 is the way before LSmash. You can change the default decoder in the settings from LSmash to FFMS2 for all codecs or just the ones you want.
Even though LSmash is working I switched back to FFMS2 now that we have the option since creating jobs is faster and I wasn't having issues before LSmash.
Old 24th August 2019, 08:18   #17247  |  Link
FuzzyNutz
Where is the LSmash/FFMS2 setting? What did you confirm about the flickering?
Old 24th August 2019, 16:28   #17248  |  Link
byteshare
ByteShare
byteshare's Avatar
You can change the default decoder in the settings (Main) from LSmash to FFMS2 for all codecs or just the ones you want, or you can even do it after the fast if you right click on a job and select FFMS2.
I confirmed it by going through both the parts I had marked as consistently having issues and skipping through 5s at a time on 6 files that had issues on every encode I did on them (2-4 times depending on the file).
Old 24th August 2019, 16:30   #17249  |  Link
nekrosoft13
switched to FFMS2 as well, will see if it fixes the flickering.
nekrosoft13 is offline   Reply With Quote
Old 24th August 2019, 18:01   #17250  |  Link
FuzzyNutz
No LSmash/FFMS2 setting exists on my UI, "main".
What is the "fast"?
What is the "it" in "I confirmed it"?
Old 24th August 2019, 18:06   #17251  |  Link
FuzzyNutz
update log error
An error appears in every activation cycle in my update log:
2019-08-24 12:55:57 : =========================[UPDATER ACTIVATED]=========================
2019-08-24 12:55:57 : Looking for correct UUID link in
2019-08-24 12:55:57 : [ERROR] NO CONNECTION with
2019-08-24 12:55:57 : Searching for UUID link with DuckDuckGo...
2019-08-24 12:55:57 : Search results...
2019-08-24 12:55:57 : http://pastebin.com/FC9zCf0D
2019-08-24 12:55:57 : Looking for correct UUID link in http://pastebin.com/FC9zCf0D
2019-08-24 12:55:58 : [SUCCESS] http://pastebin.com/FC9zCf0D has correct UUID link 6c966b28-e0dd-48f6-b1c7-a56e8a275ec0
2019-08-24 12:55:58 : No results.
My Windows 10 (Pro) firewall includes exceptions for RipBot264 and it's updater, that I added.
Old 24th August 2019, 19:26   #17252  |  Link
slalom
slalom's Avatar
I changed everything to FFMS2 too. I hope there are no problems
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB
Xeon E5-2680 v2 @ 3.1GHz 16GB
Sony Vaio VPC-F13Z1E/B
slalom is offline   Reply With Quote
Old 24th August 2019, 19:40   #17253  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Replace old updater.exe with this
https://www.mediafire.com/file/0744w...dater.exe/file
Old 24th August 2019, 19:42   #17254  |  Link
Atak_Snajpera
FFMS2 is not perfect either
https://forum.doom9.org/showthread.p...99#post1881599
I would at least use LSMASH for MPEG-2. I have few sample where FFMS2 mpeg-2 decoder acts weird.
Old 24th August 2019, 20:21   #17255  |  Link
FuzzyNutz
Thank you.
Old 24th August 2019, 20:59   #17256  |  Link
slalom
slalom's Avatar
LSMASH takes at least twice the time. I can use it for MPEG-2, there are very few of them
Old 24th August 2019, 21:05   #17257  |  Link
byteshare
ByteShare
byteshare's Avatar
Thank you for the note on MPEG-2. I had LSmash only set for VC-1.
What is the "fast"?
You're not on the most recent version if you don't see that in the main section of your settings.
"fast"...*fact (typo)
"it" confirming the issue wasn't happening
Old 24th August 2019, 21:28   #17258  |  Link
Atak_Snajpera
Do not use lsmash for vc1!!! IT is totally broken!!!
Old 24th August 2019, 22:03   #17259  |  Link
FuzzyNutz
what to use LSMASH for
Once RB treats me to the update that adds the setting for selecting LSmash, should I use it for MPEG-2 sources only?
Old 24th August 2019, 22:07   #17260  |  Link
slalom
slalom's Avatar
@Atak
I wanted to ask something regarding which server runs the CombineAllChunks.cmd
Is it the one who finishes the last chunk?
