Old 2nd September 2018, 12:54   #941  |  Link
SpasV
Posts: n/a
I need some help with FRIMSource64(), please.
My working enviroment: Windows 10, FRIM version 1.29 (x64) (Avisynth+ (Intel Media SDK 2018 R1))
I'm trying to pipe .h265 video to x265.
>avs2yuv64 -frames 24 -raw -depth 10 -par 1:1 encode_Mission_Impossible.avs -
LoadPlugin("C:\Programs\AviSynth+\plugins64+\FRIMSource64.dll")
FRIMSource64(codec="h264", filename="F:\Mission_Imposssible_Ghost_Protocol\Mission_Imposssible_Ghost_Protocol.h265", cache=1, num_frames=24)
The result is:
error: Script error: There is no function named 'FRIMSource64'.
(encode_Mission_Impossible.avs, line 2)
The requirenment for libmfxsw64.dll to be "placed in any directory which is specified in PATH environment variable" is fulfilled - it is in two directories.
What can I do about this?
Old 3rd September 2018, 06:21   #942  |  Link
videofan3d
What about
FRIMSource(codec="h264", filename=…
videofan3d is offline   Reply With Quote
Old 3rd September 2018, 09:57   #943  |  Link
SpasV
Posts: n/a
Originally Posted by videofan3d View Post
What about
FRIMSource64.dll is Version 1.29.
Maybe, it is because of the file I'm trying to source - .h265?
Format: HEVC
Bit depth: 10 bits
FRIM_release_notes.txt reads:
2018-07-08
FRIM all:
- experimental HEVC support
Actually, I'm trying to pipe .h265 stream to x265 encoder.
Old 3rd September 2018, 19:48   #944  |  Link
videofan3d
Format: HEVC
Bit depth: 10 bits
2018-07-08
FRIM all:
Second attempt:
FRIMSource(codec="h265", filename=…"
Old 4th September 2018, 01:55   #945  |  Link
SpasV
Posts: n/a
Second attempt:
The same result.
I've found a workaround:
ffmpeg -i Mission_Imposssible_Ghost_Protocol.h265 -strict -1 -f yuv4mpegpipe -
Maybe, I have some general problem. I cannot get this filter working at all.
Old 5th September 2018, 09:35   #946  |  Link
SpasV
Posts: n/a
Second attempt:
Are you suggesting my using 32-bit AviSynth+?
Old 5th September 2018, 10:24   #947  |  Link
SpasV
Posts: n/a
OK. I've run plugins64.reg.
I've run
FRIMSource(codec="h265", filename="G:\Mission_Imposssible_Ghost_Protocol\Mission_Imposssible_Ghost_Protocol.h265", cache=1, num_frames=24)
in AvsPmod and got
ERROR:Failed to load plugin (1D962A45A43FF41A6)
ERROR:undeveloped feature (-3), ...
Is there an instruction for installing these plugins?
Old 5th September 2018, 19:37   #948  |  Link
videofan3d
I've run
in AvsPmod and got
Read document FRIM_setup_readme.pdf which is part of the distribution. There is description of the plugin installation.
In general, you need to edit plugins64.reg and set there path accordingly - only then can FRIM find relevant plugin.
Furthermore, the plugins which are part of free distribution, are SW based only. So you will need to use FRIMSource(…, platform="sw", …)
Old 9th September 2018, 12:29   #949  |  Link
SpasV
Posts: n/a
Unfortunately, I cannot make FRIM works.
I’ve registered the plugins with plugins64.reg and I have:
>avs2yuv64 -seek 1 -frames 24 -raw -csp I420 -depth 10 avs\encode-FRIM.265.avs -| x265-10b - ...
error: ERROR: expect more data at input (-10), c:\prj\intelmedia\frim_decode\src\pipeline_decode.cpp (587)
ERROR: expect more data at input (-10), c:\prj\intelmedia\frim_decode\src\pipeline_decode.cpp (262)
encode-FRIM.265.avs
[FRIMSource(codec="h265", filename="F:\Mission_Imposssible_Ghost_Protocol\Mission_Imposssible_Ghost_Protocol.mkv", cache=1, num_frames=24, platform="sw")]
This one works:
>C:\Programs\FRIM_x64_version_1.29\x64\FRIMDecode64 -i:mvc insurgent_cut.264 -o output_L.yuv output_R.yuv
FRIM Decoder version 1.29 (experimental) - Win64 (build: Jul 8 2018)
- based on Intel(R) Media SDK
Media SDK impl SOFTWARE (C:\Programs\FRIM_x64_version_1.29\x64\libmfxsw64.dll)
Processing started
Frame number: 4087
Processing finished in 175.66 seconds
Old 11th September 2018, 05:12   #950  |  Link
videofan3d
FRIM does not parse .mkv container...
Old 11th September 2018, 22:45   #951  |  Link
SpasV
Posts: n/a
Sorry my absentmindedness.
The context is avs2yuv64.exe. It is avs2yuv-0.24bm5 - the last version.
When I use ffms2-2.23.1 as a source FFMS2(<"file_name.m2ts">, colorspace = "yuv420p10")
it works and the process displays the mesage:
encode-FFMS2.265.avs: 3840x2160, YUV420P10, 10-bits, progressive, 12500/473 fps, 3171 frames
When I use FRIMSource - FRIMSource(codec="h265", filename=<"file_name.m2ts">, cache=1, num_frames=24, platform="sw")
the mesage is:
avisynth 16-bit hack enabled
encode-FRIM.265.avs: 1920x2160, YV12, 10-bits, progressive, 24000/1001 fps, 24 frames
The same mesage I've got with ffms2-2.23.1 when I used the old avs2yuv64.exe version - avs2yuv-0.24bm3
Old 12th September 2018, 05:18   #952  |  Link
videofan3d
the mesage is:
When using file.m2ts (i.e. TS-container), you have to add
FRIMSource(… ,container="ts",...)
For more FRIMSource details see FRIMSource_readme.pdf from distribution...
I'm not familiar with avs2yuv64.exe …
Old 12th September 2018, 09:20   #953  |  Link
SpasV
Posts: n/a
All plugins are in place, obviously.
Intel/MediaSDKPlugin
C:\Programs\AviSynth+\FRIM_x64_version_1.29\x64\
With container="ts"
Old 12th September 2018, 20:16   #954  |  Link
videofan3d
With container="ts"
Can you open your script encode-FRIM.265.avs directly using e.g. MPC-HC(x64) media player?
(You need to use some 64-bit media player which is capable to play Avisynth+ scripts. MPC-HC(x64) is able to do it).
If yes then script is correct and problem is somewhere in avs2yuv64.exe - this I cannot help...
If not, MPC-HC(x64) will show you error message to resolve...
Old 13th September 2018, 10:24   #955  |  Link
SpasV
Posts: n/a
MPC-HC(x64), AvsPmod too, can play the scripts.
When playing FFMS2("file_name.m2ts", colorspace = "yuv420p10") there is a normal 3640x2160 picture.
When playing FRIMSource(codec="h265", filename="file_name.m2ts", cache=1, num_frames=240) there is no picture.
with FRIMSource(codec="h265", filename="file_name.m2ts", cache=1, num_frames=240, container="ts")
there is the Error message above when I've tried .mkv file.
but FRIMSource(codec="h265", filename="file_name.h265", cache=1, num_frames=240) plays and V: rawvideo, yuv420p, 3840x2140
Old 14th September 2018, 14:36   #956  |  Link
SpasV
Posts: n/a
@videofan3d
Are you capable of developing an MVC encoder?
Old 14th September 2018, 19:45   #957  |  Link
videofan3d
@videofan3d
I'm not sure whether you read the first post of this thread
Free H.264 MVC 3D Encoder ...
Old 14th September 2018, 19:46   #958  |  Link
videofan3d
Send me the script - I'll check it....
Old 15th September 2018, 15:57   #959  |  Link
SpasV
Posts: n/a
The scripts:
container not specified - no picture
container="ts" - error
Old 15th September 2018, 16:15   #960  |  Link
SpasV
Posts: n/a
As to "I'm not sure whether you read the first post of this thread
Free H.264 MVC 3D Encoder ..."
Sorry, I've missed the important part.
I've tried it and I would like to ask you some questions about:
(Better if there is a written instruction.)
- VBR - avg, maximum; obviously I can change them. But, working with x264, I prefer Constant QP with control over the maximum bitrate.
- are there other parameters avilable
- performance - with no more than 38% CPU load I've got 7 fps.
In general, the most information the better.
encoders, mvc
