20th November 2013, 01:05 | #201 | Link | |
If you fail to plan; you plan to fail, would you not agree? Think about it. |
20th November 2013, 01:21 | #202 | Link | |
Even if BD3D would be conflicting with 23.976 I would assume that most players won't care. Is your experience different? |
20th November 2013, 01:52 | #203 | Link | |
1920x1080x23.976-p 1280x720x59.94-p 1280x720x50-p Secondary video SD 720x480x24-p, 23.976-p (4:3/16:9) 720x576x25-i (4:3/16:9) --------------------------- 1440x1080 not allowed under any type for 3D. Yes I do own the specs as well.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 20th November 2013 at 01:59. |
20th November 2013, 05:58 | #204 | Link | ||||||
20th November 2013, 09:52 | #206 | Link | |
ChangeFPS(60000,1001) ConvertToYV12().AssumeFPS(60000,1001) Added: I was lucky in my case as the SBS source was 29.97fps, so the frames are just getting duplicated for 59.94, means no judder, and frame duplication should not produce too much overhead bitwise I assume. Pulldown is not supported by FRIMEncode, right? For 720p 23.976fps sources, speedup to 25 fps and subsequent frame duplication for 50fps could be a solution for BD3D compliance. Last edited by Sharc; 20th November 2013 at 12:15. Reason: Added |
20th November 2013, 16:10 | #207 | Link |
No, it was a script which for some odd reason cutting of movie around 50% sometime before 50% reached and sometime after 50% reached even for same movie.
I modified workflow and doing quick test run.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 20th November 2013 at 17:36. |
21st November 2013, 00:38 | #208 | Link | |
Am I doing something wrong? Last edited by jdobbs; 21st November 2013 at 00:41. |
21st November 2013, 00:48 | #209 | Link | ||||
If you are interested in my workflow, it consist of following setting and yes these are new ones. Which allowed full encode to complete. 1. Call tsmuxer to extract avc and mvc stream, or any supported stream. 2. Create batch file with parameter similar to one shown shown on next line, for this example it is mvc Quote:
Although not required, but here all the parameters encoder and decoder will accept with encoder parameters first, follow by decoder. Quote:
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 21st November 2013 at 00:57. |
21st November 2013, 01:03 | #210 | Link |
@HWK
Thanks. I modified your command line for a 2D input file and it works fine. I'm a little confused, though, by the first post of the thread that says v1.15 can work using an Avisynth script -- but I can't get one to work at all. It would sure save me a lot of time if I could use DirectshowMVCSource() or ssifsource3 to feed an OAU or SBS picture to the encoder. That would be a good project for someone -- creating an AVISYNTH source filter out of FRIMDecode eliminating the need for directshow filters. Last edited by jdobbs; 21st November 2013 at 01:14. |
21st November 2013, 01:07 | #211 | Link |
I couldn't manage it as well , If you used my command line and you set -u 1, it is considered placebo in x264 terms. I thought I let you know about this.
21st November 2013, 01:11 | #212 | Link | |
Although I haven't tried I am thinking if x264 can accept pipe input, you can use frim to decode any of the following codecs mpeg2|h264|mvc|vc1|jpeg which may open door for potential to have self contained package, rather than relying on external decoders.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 21st November 2013 at 01:24. |
21st November 2013, 01:29 | #213 | Link | |
Commandline for an O/U source (includes resizing): Code:
"C:\Program Files Video\MVCtoAVI.exe\FRIMEncode.exe" mvc -avi -tab 2 -i directshowsource.avs -viewoutput -o Base1.avc -o Dependent1.mvc -w 1280 -h 720 -dstw 1280 -dsth 720 -l 4 -cpbsize 3750 -vbr 6000 15000 -u 4 -profile high -level 4.0 -gop 24 4 0 O pause |
21st November 2013, 01:36 | #214 | Link | |
It is probably some kind of local issue or something, I gave it a try and get same message "Cannot get YUV420 frame from input file Encode_3D_Movie.avs" where pipe works.
21st November 2013, 01:44 | #215 | Link | |
Can you show an example script. I get that error message every time I try any encode using frimencode with any script I try. |
21st November 2013, 02:48 | #216 | Link | ||
http://forum.doom9.org/showthread.php?p=1653848#post1653848 [Update] After couple of tries it still didn't work for me.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 21st November 2013 at 03:41. Reason: Update |
21st November 2013, 05:50 | #217 | Link | |
21st November 2013, 07:06 | #218 | Link | |
French Love
2013-11-29 MVC Player Free v0.0.2.6 BD & 3D BD's Player, Demuxer v0.0.0.8b, Recoder. Tutorial Demo for MVC Player Free: Trailer 3D 3DBD's Free - v0.0.0.0005.exe Old Programing free for all. |
21st November 2013, 07:07 | #219 | Link | |||
Also for windows xp, it won't work according videofan3d first post. Quote:
Same message is displayed for FRIMEncode and FRIMTranscode on XP, although xp has dll already but it needs different one.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 21st November 2013 at 08:08. |
21st November 2013, 07:14 | #220 | Link |
I have done couple of times and it still doesn't work. Thanks for trying I will use pipe if I use Frimencode.
encoders, mvc |
