Old 6th October 2012, 13:21   #21  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
update
vsavsreader-d219012.7z
* change RGB plane order from G->B->R to R->G->B.
my repositories
Chikuzen is offline   Reply With Quote
Old 16th November 2012, 01:30   #22  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
update
download it from the link of first post.
* support alpha channel
If input avs is RGB32, alpha will be stored in "_Alpha" prop.
my repositories
Old 16th November 2012, 01:36   #23  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Originally Posted by Chikuzen View Post
update
Actually the more proper way to do it to return two clips from the filter. See the avisource code for an example. The basic idea is that you call setvideoinfo(array of two videinfo, 2, core)
And then in the filter's getframe function you call getOutputIndex () to know which of the two clips you should output a frame for. Slightly more complicated to implement but it makes more sense. Or so I think.
Myrsloik is offline   Reply With Quote
Old 11th January 2013, 16:45   #24  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
updated to vsavsreader-0.1.0
* add new option 'alpha'
* change alpha channel support method.
my repositories
Old 15th October 2013, 12:21   #25  |  Link
RTW47
Rome Total War
RTW47's Avatar
then I use Eval() function:
import vapoursynth as vs
core = vs.get_core()
core.std.LoadPlugin(r'C:\Program Files\VapourSynth\filters\vsavsreader.dll')
avs = """
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\LSMASHSource.dll")
LWLibavVideoSource("D:\amv\10bit.mp4", format="YUV420P8")
#ConvertToRGB24(matrix = "Rec709")
video = core.avsr.Eval(lines = avs)
video.set_output()
In Python shell I get this:
Python 3.3.2 (v3.3.2:d047928ae3f6, May 16 2013, 00:03:43) [MSC v.1600 32 bit (Intel)] on win32
Type "copyright", "credits" or "license()" for more information.
>>> ================================ RESTART ================================
Traceback (most recent call last):
  File "C:\Users\Edgaras\Desktop\py\1_vsavsreader # 'Eval' Libav FAIL.py", line 9, in <module>
  File "vapoursynth.pyx", line 983, in vapoursynth.Function.__call__ (src\cython\vapoursynth.c:15542)
vapoursynth.Error: 'Eval:
failed to invoke \nLoadPlugin("C:\\Program Files\\AviSynth 2.5\\plugins\\LSMASHSource.dll")
\nLWLibavVideoSource("D:\x07mv\x08bit.mp4", format="YUV420P8")\n#ConvertToRGB24(matrix = "Rec709")\n'
then importing same .avs script(s) using vsavsreader's Import() function, then there's no error.
-vapoursynth r20 RC3
-avisynth 2.6 alpha 5
-vsavsreader 0.1.0
GOTO:EOF
RTW47 is offline   Reply With Quote
Old 14th December 2014, 22:00   #26  |  Link
Reel.Deel
Dumb question:
If there was a 64-bit version of this plugin could it be used to load 32-bit AviSynth scripts in a 64-bit VapourSynth? I know piping allows using applications interchangeably but that may be something completely different.
Old 14th December 2014, 22:13   #27  |  Link
Myrsloik
Myrsloik's Avatar
Originally Posted by Reel.Deel View Post
Dumb question:
No. Avisynth is loaded into the same process so it has to be 64bit too. You need a more elaborate wrapper that runs avisynth in a 32bit environment for it to work.
Old 14th December 2014, 22:19   #28  |  Link
Reel.Deel
Understood, sounds like it's something feasible though. Pity that Chikuzen is no longer around...
Old 16th December 2014, 10:34   #29  |  Link
Myrsloik
Myrsloik's Avatar
What remaining avisynth things do you need?
Old 16th December 2014, 15:53   #30  |  Link
Reel.Deel
I don't have a very strong case here but DGDecNV and DGMPGDec are really hard to leave behind considering how good they've been to me. I know there's d2vsource but as we all know is still a work in progress. On the other hand DGDecNV also comes in 64-bit so I'm wondering if a 64-bit vsavareader would work with 64-bit AviSynth+?
In the meantime I'm using AVFS to create a fake avi and then loading it with VS.
Old 16th December 2014, 16:19   #31  |  Link
Myrsloik
Myrsloik's Avatar
Yes, it should work with 64bit avs+ as well. I guess.
Old 16th December 2014, 16:25   #32  |  Link
Reel.Deel
Unfortunately I only have Microsoft Visual C++ 2010 Express so I guess I'm SOL when it comes to trying to compile a 64-bit vsavsreader.
Old 16th December 2014, 16:47   #33  |  Link
TheFluff
Excessively jovial fellow
http://www.visualstudio.com/en-us/pr...o-community-vs
Old 16th December 2014, 16:59   #34  |  Link
Reel.Deel
Visual Studio Community 2013 seems very nice for someone who does this on a regular basis. I've successfully compiled at most 10 avs plugins in the last 2 years. Also I read somewhere that Community version is a very large download/install compared to the express edition.
Old 16th December 2014, 17:30   #35  |  Link
TheFluff
there's a difference between being unable to do a thing and being too lazy to do a thing
Old 16th December 2014, 18:17   #36  |  Link
Reel.Deel
I don't like to be mean so I deleted my post...
Old 16th December 2014, 18:33   #37  |  Link
Myrsloik
Myrsloik's Avatar
I'm just going to add that using vs avisource to open an avisynth script and (if necessary) fmtconv's 16 bit avisynth compatibility functions should work just as well.
I completely forgot that this plugin kinda is obsolete now because avisource exists.
Old 16th December 2014, 20:18   #38  |  Link
Reel.Deel
Good point Myrsloik, I completely forgot about avisource also.
Old 29th December 2014, 13:00   #39  |  Link
HolyWu
HolyWu's Avatar
I just do some experiments, and 64-bit VS AVISource seems to conflict with a avs script using 64-bit DGDecNV as the source filter, while VirtualDub x64 can preview that same avs script without problem. The 64-bit vspipe crashed immediately when opening the vpy script. Do you have a supported NVIDIA card to test?
HolyWu is offline   Reply With Quote
Old 29th December 2014, 13:10   #40  |  Link
Myrsloik
Myrsloik's Avatar
No, I don't have nvidia stuff. It's probably some kind of threading issue since VapourSynth will use multiple threads to request frames from vfw. Especially when using vspipe.
Try using an mt version of avisynth and see if it helps.
Otherwise you're going to have to run it all in a debugger to see why it dies.
