Old 18th January 2012, 12:34   #21  |  Link
tormento
Acid fr0g
tormento's Avatar
I'll make some tests about MT and SetMemory. If you have some influence on cretindesalpes, try to ask for a dither.dll and mvtools.dll in x64
@turment on Telegram
Old 25th January 2012, 11:28   #22  |  Link
tormento
Acid fr0g
tormento's Avatar
Dogway, I'm having major problems with 1920x1080 movies on the following code:
PHP Code:
SMDegrain (tr=6,PreFilter=2,lsb_out=true,Globals=2)
SMDegrain (tr=6,            lsb_in =true,Globals=1,mode=6
If used on cropped height I get almost decent FPS, on full height, i.e 1080, or nearest 16 multiple, i.e. 1072, I got ~ 1fps.
Any idea?
Old 26th January 2012, 01:10   #23  |  Link
TheProfileth
Leader of Dual-Duality
TheProfileth's Avatar
Just thought I should chime in and say Dogway is on "vacation" so don't expect much from him on this thread for about 3 more weeks.
I'm Mr.Fixit and I feel good, fixin all the sources in the neighborhood
My New filter is in the works, and will be out soon
TheProfileth is offline   Reply With Quote
Old 26th January 2012, 10:52   #24  |  Link
nhope
partially-informed layman
The v1.8 download is set to private on mediafire. Can anyone else please share this while Dogway is away?
nhope is offline   Reply With Quote
Old 28th January 2012, 00:37   #25  |  Link
reff24
new mirror please?
reff24 is offline   Reply With Quote
Old 28th January 2012, 09:59   #26  |  Link
Anacletus
Anacletus's Avatar
Here's an alternative link: SMDegrain v.1.8d.zip
Anacletus is offline   Reply With Quote
Old 28th January 2012, 16:06   #27  |  Link
reff24
Your download link has expired
too bad
Old 28th January 2012, 17:16   #28  |  Link
Taurus
Taurus's Avatar
Works fine here..
Taurus is offline   Reply With Quote
Old 28th January 2012, 17:48   #29  |  Link
reff24
yes it is now working. thanks for upload Anacletus
Old 28th January 2012, 17:50   #30  |  Link
poisondeathray
fileserve link above works fine here too
here is a mirror if you are having problems
SMDegrain v.1.8d
http://www.mediafire.com/?p6w5ndpdag9obym
Old 15th February 2012, 09:28   #31  |  Link
tormento
Acid fr0g
tormento's Avatar
Dogway, do you think this could be of any help for the MT problem?
Old 11th March 2012, 23:57   #32  |  Link
mandarinka
mandarinka's Avatar
Is there any reason why thSADC parameter isn't exposed? It might be useful in some cases.
mandarinka is offline   Reply With Quote
Old 12th March 2012, 00:21   #33  |  Link
Dogway
not really, I missed the option, so I might add it for next version in a not intrusive way, I just don't want to flood the function with endless parameters, and chroma has always been buggy in mvtools (I tend to denoise only luma). Important also is the truemotion parameter, more indeed to my eyes and already included in the pre 1.9.
cretindesalpes released today the awaited MT Dither tools with mvtools2mod. I will have a look on what I can implement from there, and along all the changes already made and due to when I got some time I will be releasing v.1.9 under a new thread in Doom10. I will keep my posts in Doom9 minimal and this the last one on this thread. So ask me there if you can. I will be active there posting functions, etc.
Old 12th March 2012, 07:33   #34  |  Link
nibus
Telewhining
Dogway is there a way to tweak the scene detection threshold? On dark scenes sometimes I get 1 or 2 blurry frames between scenes.
nibus is offline   Reply With Quote
Old 13th March 2012, 08:41   #35  |  Link
tormento
Acid fr0g
tormento's Avatar
Please tell us when to go there.
Old 21st March 2012, 02:39   #36  |  Link
canuckerfan
this function requires levels to be in PC range, correct?
canuckerfan is offline   Reply With Quote
Old 24th July 2012, 13:59   #37  |  Link
matfra
I made some speed/quality test.
SMDegrain (tr=6,PreFilter=1,lsb=true,mode=6)
I got about 3fps
MCTemporalDenoise(Settings="High")
I got about 8fps
The visual quality is about the same but MCTemporalDenoise is little bit cleaner than SMDegrain.
Do you think is possible to achieve better speed/quality with one pass of SMDegrain ?
matfra is offline   Reply With Quote
Old 25th July 2012, 09:03   #38  |  Link
tormento
Acid fr0g
tormento's Avatar
Dogway stated clearly that he doesn't support Doom9 anymore.
Old 25th July 2012, 11:39   #39  |  Link
matfra
I know tormentor. I was just hoping maybe someone else have idea. Thats why I post on the 2 forum
Old 7th November 2012, 19:53   #40  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by HolyWu View Post
I ported SMDegrain v2.1d to VapourSynth
Thank you
You should talk on Doom10 as DogWay doesn't read this forum anymore.
denoise, interlaced, mdegrain, smdegrain, yuy2
