Old 6th July 2022, 22:41   #31301  |  Link
MrVideo
MrVideo's Avatar
Originally Posted by gonca View Post
THD must have an interleaved ac3 core file for BD compliance.
MKV cannot store two interleaved tracks, so it splits them.
Stores them as a thd track and an ac3 track.
Yep, know all that. But, MediaInfo only shows the THD track. The AC3 core appears to not have been stored with it. I'll just have to get around it another way. Oh well.
Old 7th July 2022, 00:34   #31302  |  Link
gonca
MKV cannot store an ac3+thd track.
It has to separate the core from the thd, creating two separate tracks.
THD tracks in MKV are never BD compliant
gonca is offline   Reply With Quote
Old 7th July 2022, 02:28   #31303  |  Link
MrVideo
MrVideo's Avatar
As I noted, there was only the single THD audio track. No separate AC3 core track.
It would have been nice if BDRB would have indicated what it was doing. But, the point is moot as I've scrapped working with the particular file.
Old 8th July 2022, 05:17   #31304  |  Link
Lathe
Lathe's Avatar
Have you tried "Run as Administrator"
Yep, I tried that...
Thanks too to the other suggestions about the AV software, but I haven't changed anything that I am aware of. I'm still running Avast and AdAware. I'll try defeating those first and then try to run BDRB again, although I'm not getting any warnings or prompts.
Lathe is offline   Reply With Quote
Old 8th July 2022, 05:25   #31305  |  Link
Lathe
Lathe's Avatar
Heh, Bro, I swear it seems like you keep asking about this in different ways As I have suggested before, the solution is very simple. Just run UsEac3To, drop in the MKV file with the TrueHD track (which as Gonca says being muxed in MKV format the core is missing) and then choose as your output TrueHD+AC3 and then run the command line and it puts the AC3 core back in. THEN you can take the resulting file which now is compliant and simply add/mux it into BDRB.
Old 8th July 2022, 05:39   #31306  |  Link
Lathe
Lathe's Avatar
Yep, it's Avast. In the notifications it is saying it quarantined BDRB.exe because it has 'FileRep malware' I hafta figure out how to make an exception. It's never done that before, I wonder why it is doing so now...?
Old 8th July 2022, 12:18   #31307  |  Link
MrVideo
MrVideo's Avatar
I don't remember seeing this trick mentioned. I'll try and remember if I run into this again. I've decided to go into a different direction and have decided not to deal with this file at all.
Old 9th July 2022, 12:03   #31308  |  Link
gonca
You are trying to encode a non compliant track.
Merge the thd and ac3 tracks together or re-encode an ac3 core into the thd track.
Or wait while BD_RB does it
Old 9th July 2022, 20:56   #31309  |  Link
MrVideo
MrVideo's Avatar
As in previously mentioned before this current discussion.
Old 13th July 2022, 18:49   #31310  |  Link
CraigWally
Originally Posted by Hooman View Post
After a movie-only backup using that option it appears to me the 3d output of my BD rebuilder has artifacts(video pixelation)
That will be with a software player? Yes?.
Burn it to disc and play on a standalone player, trust me it will be fine
CraigWally is offline   Reply With Quote
Old 8th August 2022, 14:31   #31311  |  Link
Mark_Venture
So I've got bluray I'm trying to back up which BD Rebuilder gets the following error:
 BD Rebuilder experienced and error 2503 [09:11:07] SourceCheck() 00006 2503
followed by:
Selected source is not BD format.
BD-Rebuilder.log has:
 - [09:30:38] SourceCheck() 00006  2503
The disc is John Williams Live in Vienna, Wiener Philharmoniker - Anne- Sophie Mutter. from 2020. Purchased via Amazon, and says "all regions".
I tried using passkey and makemkv.
The original disc plays in my bluray player just fine.
EDIT: What info can I share to help with this?
Mark_Venture is offline   Reply With Quote
Old 11th August 2022, 16:47   #31312  |  Link
Hooman
After lots of experiments, I found out it's a problem with Frim decoding/encoding because when MVC to AVI Converter + AVFS + CineVision MVC Encoder + setting "REBUILD_COMPLETE=0" + replacing ESs in Workfiles + re-rebuild are used there's no such artifacts.
Update: The software players such as PowerDVD 19 and WinDVD only play the 2D version (no artifacts when encoded with CineVision MVC Encoder) and my standalone Samsung Blu-ray 3d player doesn't start playing the BD-Rebuilder 3d clips, but when the same re-encoded MVC videos are re-authored in Scenarist BD (SSIF format) all of those players display the 3d effects perfectly (there's no viewable difference between the re-authored 3d BD-25 and the original 3D BD-50.)
Hooman is offline   Reply With Quote
Old 13th August 2022, 22:18   #31313  |  Link
bjones
This is probably an easy question for the experts here. I'm trying to create alternate output mkv's from my bluerays in HEVC for some size efficiency. Using the mBitrate along with vBitrate seems to have no effect and it encodes as a constant bitrate at the vBitrate setting. On the same settings except as AVC it works as expected with an avg bitrate close to the vBitrate setting and a peaking bitrate exactly at the Mbitrate setting. Is it another setting I'm missing or is mBitrate not supported on HEVC encodes ? Encoder is the nvidia one in the distribution. Thanks for any pointers
bjones is offline   Reply With Quote
Old 14th August 2022, 16:24   #31314  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
If one is used to control x264, then x265, then uses NVEnc:
Bitrate control is different within NVEnc (both 264 and 265), so some parameters have to be translated, some ignored.
Old 11th September 2022, 16:46   #31315  |  Link
SquallMX
Special SeeD
@jdobbs When reencoding seamless branching titles with Dolby Vision, not all the segments are reencoded using "VID_00XXX.CHP" for proper DV compatibility, mostly smaller segments:
From LASTCMD.TXT:
"D:\Archivos de Programa\BD Rebuilder UHD\tools\ffmpeg.exe" -probesize 100MB -i "E:\Star Trek 6\BDMV\STREAM\00605.m2ts" -an -pix_fmt yuv420p10le -f yuv4mpegpipe -strict -1 - | "D:\Archivos de Programa\BD Rebuilder UHD\tools\x265-64.exe" - --preset medium --profile main10 --uhd-bd --repeat-headers --vbv-bufsize 45000 --vbv-maxrate 48000 --hdr --chromaloc 2 --colorprim bt2020 --transfer smpte2084 --colormatrix bt2020nc --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(40000000,50)" --max-cll "1000,329" --fps 23.976 --slow-firstpass --pass 1 --sar 1:1 --keyint 24 --crf 23.7 --y4m --no-strong-intra-smoothing --no-sao --deblock -1:-1 --ipratio 1.2 --pbratio 1.1 --aq-mode 3 --dynamic-refine --rskip 2 --rskip-edge-threshold 3 --rdoq-level 2 --rc-lookahead 24 --stats "D:\VIDEO PROCESSING\UHD\WORKFILES\VID_00605.AVS.hevc.stats" --output "D:\VIDEO PROCESSING\UHD\WORKFILES\VID_00605.AVS.hevc""
"D:\Archivos de Programa\BD Rebuilder UHD\tools\ffmpeg.exe" -probesize 100MB -i "E:\Star Trek 6\BDMV\STREAM\00596.m2ts" -an -pix_fmt yuv420p10le -f yuv4mpegpipe -strict -1 - | "D:\Archivos de Programa\BD Rebuilder UHD\tools\x265-64.exe" - --preset medium --profile main10 --uhd-bd --repeat-headers --vbv-bufsize 45000 --vbv-maxrate 48000 --hdr --chromaloc 2 --colorprim bt2020 --transfer smpte2084 --colormatrix bt2020nc --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(40000000,50)" --max-cll "1000,329" --fps 23.976 --slow-firstpass --pass 1 --sar 1:1 --qpfile "D:\VIDEO PROCESSING\UHD\WORKFILES\VID_00596.CHP" --keyint 24 --crf 22.5 --y4m --no-strong-intra-smoothing --no-sao --deblock -1:-1 --ipratio 1.2 --pbratio 1.1 --aq-mode 3 --dynamic-refine --rskip 2 --rskip-edge-threshold 3 --rdoq-level 2 --rc-lookahead 24 --stats "D:\VIDEO PROCESSING\UHD\WORKFILES\VID_00596.AVS.hevc.stats" --output "D:\VIDEO PROCESSING\UHD\WORKFILES\VID_00596.AVS.hevc"
SquallMX is offline   Reply With Quote
Old 27th September 2022, 16:06   #31316  |  Link
Blurayhd
Hi guys I have a problem, I´m trying to encode an mkv movie in 4k to mkv movie in 1080p with Alternate movie only output, but no matter what I do, the result mkv is not an 1920x1080, still 3840x2160 and I so need it in full hd please could you helping me? I´ll appreciate it here is the log
09/27/22] BD Rebuilder v0.61.28
[10:49:34] Source: MI_VILLANO_FAVORITO_(2010)_REMUX_4K_HDR_LATINO
- Input BD size: 26,82 GB
- Approximate total content: [01:34:40.007]
- Windows Version: 6.2 [9200]
- MOVIE-ONLY/ALTERNATE OUTPUT mode enabled
- Mode: MKV Container, 1920x1080, Intact Audio
- Quality: Highest (Very Slow)
- UHD-BD source detected.
- Decoding/Frame serving: NVENCC
[10:49:34] PHASE ONE, Encoding
- [10:49:34] Processing: VID_00000 (1 of 1)
- [10:49:34] Extracting A/V streams [VID_00000]
- [10:59:29] Reencoding video [VID_00000]
- Source Video: HEVC, 3840x2160
- Rate/Length: 23,976fps, 136.184 frames
- [10:59:29] Reencoding: VID_00000, Pass 1 of 1
- [11:45:26] Video Encode complete
- [11:45:26] Processing audio tracks
- Track 4353 (spa): Keeping original audio
[11:45:26]PHASE ONE complete
[11:45:26]PHASE TWO - Rebuild Started
- [11:45:26] Building ALTERNATE OUTPUT Structure
[11:57:34] - Encode and Rebuild complete
- WORKFILES folder removed.
[11:57:35] JOB: MI_VILLANO_FAVORITO_(2010)_REMUX_4K_HDR_LATINO_.finished.
Blurayhd is offline   Reply With Quote
Old 28th September 2022, 12:08   #31317  |  Link
MrVideo
MrVideo's Avatar
Use NVENCCRE.exe, as you can resize the output to 1920x1080.
Old 28th September 2022, 19:07   #31318  |  Link
Blurayhd
Thank you I find it but I notice this tool not let me to choose de crf or pass
Old 28th September 2022, 22:09   #31319  |  Link
jdobbs
Just a reminder. You have to have a compatible NVIDIA video card to use NVENCCRE.
You can do the equivalent of CRF but it's called "Constant Quality". As for "pass", the NVIDIA encoder only does 1 pass encoding. They have a mode they call "two-pass", but it doesn't really meet the definition of a two-pass encoder.
Website: www.jdobbs.net
Old 29th September 2022, 14:19   #31320  |  Link
Blurayhd
Hi Jdobbs I have an Nvidia, and I have to say it I really appreciate your work buddy, first was Dvdrebuilder and next BDrebuilder, I follow you from years and Thank you
If you let me to ask you, the only problem that I have with Bdrebuilder is when I try to encode from 4k to 1920x1080 intact audio, the result still 4k is there one possibility that you can fix it?
