5th January 2021, 23:37 | #30281 | Link |
BD Rebuilder v0.61.19
I have updated the first post of this thread with a link to the latest version of BD Rebuilder (v0.61.19). Changes for this release:
- Corrected an issue in which attempts to encode secondary video with NVENCC would result in another encode of the primary video stream by incorrect reference. - Fixed an issue in which --vpp-deinterlace might incorrectly be used in --avs mode during NVENCC encodes, causing an encode failure. - Corrected an issue in which setting a FIXED_CRF (with the hidden option) and choosing CRF for full backup encoded was preventing "keep original video" from occurring. - Added a workaround to an odd error that can randomly occur in NVENCC when trying to encode a single frame. - Fixed an issue in which 30fps sources that are being inverse telecined my still result in a keyint (gop size) of 30. - Reenabled the MULTIPROCESS hidden option. Note: MULTIPROCESS is disabled when the NVENCC encoding option is selected. - Other minor corrections and cosmetic fixes. |
6th January 2021, 17:52 | #30283 | Link | |
Any option to avoid extracting and remuxing when no re-encode is required or is it necessary to remux regardless? Thanks again and Happy New Year! |
7th January 2021, 00:58 | #30284 | Link | |
7th January 2021, 04:16 | #30285 | Link | |
One last question, what's the difference between Full Backup with Edit Mode (Manual Blanking) vs Movie & Menus (Auto-Blank Extras) with Edit Mode (Manual Blanking) Using the Options: BLANK_THRESHOLD=0 MIN_M2TS_SIZE=0 MIN_PLAYLIST_MINS=0 I found that I get ALL the streams for blanking if I use Movie & Menus (Auto-Blank Extras) with Edit Mode (Manual Blanking) But missing streams using Full Backup with Edit Mode (Manual Blanking) |
7th January 2021, 16:22 | #30288 | Link |
With some films with a slightly lower bit rate, the cpu load constantly changes from high to low. Two encoding processes would fix the problem.
I use the preset "High Quality CFR" for uhd on my AMD Threadripper 1950x. |
8th January 2021, 16:29 | #30289 | Link | |
@all: DGDecNV users should use build 222 or higher as it massively increased indexing performance. It's running at approx. 300MB/s here where it used to be at around 100 MB/s with previous builds. It's like PacMan eating up the progress bar :-) ggtop Last edited by ggtop; 8th January 2021 at 16:33. |
9th January 2021, 04:59 | #30292 | Link |
Huh? The version I am using is 2053 and I downloaded that on 4/26/2019.
My Total Eclipse 2017 Photos My Nov 2019 Game of Thrones Tour My NEOWISE Comet Photos 2020 Last edited by MrVideo; 9th January 2021 at 05:05. |
9th January 2021, 11:30 | #30294 | Link | |
Link to DGDecNV: http://rationalqm.us/dgdecnv/dgdecnv.html That one has a link to the binaries area Simply redo what you've done on 4/26/2019 ggtop |
9th January 2021, 12:45 | #30296 | Link | |
Useful n00b
Subscribe to the Binaries Notification thread and you'll get an email whenever a new slipstream is released. It's definitely worth upgrading to the latest slipstream. Be careful to regenerate your INI file if you are coming from a significantly older version. |
9th January 2021, 16:03 | #30297 | Link | |
9th January 2021, 17:13 | #30298 | Link | |
Before 223, alt movie MKV with NVEnc with my GTX1660ti/i7-10900k it was taking about 30-35 min per movie. With 223 and Optimize for HDD checked, and the same settings... the 5 movies I did last night took 10-15 min each! |
9th January 2021, 18:59 | #30300 | Link | |
Thanks for u're time, kind regards. |
