Old 3rd November 2020, 12:15   #1141  |  Link
Antonio
Good morning,
There seems to be an issue with the rotation feature, as when a content is reloaded (using ctrl+e for example) or a new content is loaded, it is displayed with its original orientation though the rotation value is kept, as requesting a new clockwise rotation decreases the previous z angle of 90° rather than setting it to 270°. It would seem more logical to either reset the rotation value to 0 or apply the transformation to the display of the content, wouldn't it ?
Also, there does not appear to exist a command for rotating the display through the window handle API, or I am missing it ?
The reason for all these questions is that rotation infos in exif data of jpg are ignored (as they are by ffmpeg and the jpeg lav demuxer), so a display rotation is needed to watch them in the right position.
Antonio is offline   Reply With Quote
Old 3rd November 2020, 15:54   #1142  |  Link
Snowknight26
That does sound like a bug but there should be a workaround in your case.
Consider losslessly rotating your JPGs before displaying them using something such as jpegtran, exiftran, pingo, etc.
Snowknight26 is offline   Reply With Quote
Old 3rd November 2020, 18:22   #1143  |  Link
clsid
I have fixed the issue with the rotation value not resetting on reload.
MPC-HC is a video player. It is not an full featured image viewer. DirectShow is not suitable for that.
Old 3rd November 2020, 21:59   #1144  |  Link
Antonio
I know that mpc-hc, as most video players, have to cope with limitations when displaying pictures, such as memory constraints, but for old digital camera photos in small resolution, the jinc algorithm of madvr does a very pretty job, sharp but without ringing.
Old 4th November 2020, 07:16   #1145  |  Link
Feel
Hi
excuse me, there is a way to propperly use finesharp shader?
in whatever order I put the shaders, with any video card I get a white or yellow screen
thanks in advance
Feel is offline   Reply With Quote
Old 4th November 2020, 23:35   #1146  |  Link
Homeless
I just upgraded to the latest version and I noticed that using the /fullscreen flag for video streams no longer works. In the changelog it says this now only works for video files. Does anyone know if there is a way to get video streams to open in fullscreen through a launch parameter now?
Homeless is offline   Reply With Quote
Old 4th November 2020, 23:50   #1147  |  Link
Dogway
I have been experiencing an issue when an audio track is delayed for some big amount, the video doesn't want to start until I click on the seekbar. This is using a mkv container, I'm not sure it's an issue on MPC-HC or LAVFilters though.
Old 5th November 2020, 23:39   #1148  |  Link
clsid
@feel
MPC-HC does not contain a finesharp shader by default. So whatever filter you are using might not be compatible.
@Homeless
Try with version 1.9.8.21
@dogway
Try increasing the queue sizes in LAV Splitter.
Old 6th November 2020, 03:23   #1149  |  Link
Dogway
@dogway
Thanks! It worked : D
Old 6th November 2020, 19:50   #1150  |  Link
DMU
The parameter /fullscreen now works.
R3 3200G / Vega8 / Samsung UE40NU7100
Win11Pro 21H2 / 4K RGB 59Hz / AMD last driver
MPC-HC 1.9.17 / madVR 0.92.17 / FSW / SM / 8bit
DMU is offline   Reply With Quote
Old 6th November 2020, 21:57   #1151  |  Link
akapuma
akapuma's Avatar
Hello,
1.9.7 was able to play:
http://www.memoryradio.de:5000/
1.9.8 shows "can not render file"
Best regards
akapuma
Left: MPC 1.9.7, right: MPC 1.9.8
akapuma is offline   Reply With Quote
Old 9th November 2020, 11:26   #1152  |  Link
Antonio
. Thank you, I also found this very useful page: https://www.autohotkey.com/boards/vi...hp?f=7&t=41683
. Thanks, jpegtran works fine, though it does not support stdin on windows, so I used named pipes. I then realized that the built-in rotation could be used by sending the corresponding key code (881 and 882).
. Thank you, I confirm it now works correctly.
I am very grateful for all your help, I was able to achieve the DLNA wrapper with a combination of copydata, command and control messages (https://github.com/PCigales/DLNAmpcRenderer) to make up for missing features in the API.
Old 18th November 2020, 00:20   #1153  |  Link
adipose
Originally Posted by LigH View Post
Because it is used in MPC-HC: Be aware of the RIAA takedown of the original youtube-dl repo on github; there is a fork: yt-dlc.
FYI
https://arstechnica.com/tech-policy/...download-tool/
adipose is offline   Reply With Quote
Old 18th November 2020, 09:26   #1154  |  Link
LigH
LigH's Avatar
Blame the German "media lobby court" (Landgericht Hamburg) claiming international jurisdiction...
New German Gleitz board
Old 20th November 2020, 17:41   #1155  |  Link
BDFan
MPC-HC 1.9.8 and newer broke BDAV/BDMV network (?) playback.
MPC-HC 1.9.7 true
MPC-HC 1.9.8
And you can remove "***" from recent files?
It's hard to know what the file name is.
BDFan is offline   Reply With Quote
Old 22nd November 2020, 17:30   #1156  |  Link
XRyche
I'm having a audio desync issue with the latest stable build 1.9.8 . The audio starts desyncing after about a few minutes or so of playing and the only way I have found to sync the audio and video back up is to use the seekbar. There are no dropped frames or anything like that. The file plays as it should in all other aspects.
Intel i5 3470, EVGA GTX 1050Ti SC ACX 2.0, Windows 10 Pro 64 bit, 16 GB 1600 mhz DDR3 RAM
XRyche is offline   Reply With Quote
Old 28th November 2020, 17:28   #1157  |  Link
stax76
stax76's Avatar
For voidtools Everything I want to change UI colors making it dark like most other apps I use.
So I tried changing the main menu colors using a tool called Classic Color Panel but it does not work unfortunately.
Has anybody managed to customize classic Win32 UI colors in the latest Windows 10 versions?
Old 6th December 2020, 01:23   #1158  |  Link
Xtreme512
I updated to the latest nightly MPC-HC to test the latest version MPC-BE audio renderer and its not working, app (crashes) is not responding upon playing any video.
Only "standalone_filters-mpc-be.1.5.1.x64" version of the audio renderer is working. 1.5.1 is old, yet I suspect there's extra feature in the new one, at least this works.
Someone wrote here not long ago that latest version was working, it's not.
Xtreme512 is offline   Reply With Quote
Old 6th December 2020, 17:58   #1159  |  Link
clsid
You need a recent SVN build of the audio renderer. That fixes the hang bug.
Old 6th December 2020, 22:28   #1160  |  Link
Xtreme512
I tried it now (Nightly standalone_filters-mpc-be.1.5.5.5274.x64), it still crashes/hangs. Back to 1.5.1 and its working again. Is there noticeable difference between those 2 versions? I know 1.5.1 is old but its rock stable and does true exclusive.
