6th December 2009, 11:31 | #601 | Link |
Life's clearer in 4K UHD
Wonderful work... Thanks Zenitram
6th December 2009, 12:00 | #602 | Link |
I try to do the same for DTS/DTS-HD a bit later (a bit more complex with "in the core stream" or "after the core stream" extensions, and the TrueHD was a paid work, not tthe DTS-HD stuff, so DTS-HD is in lower priority).
Want to know all about your media files? http://mediaarea.net/MediaInfo |
6th December 2009, 13:19 | #603 | Link |
sidekick
could you plz implement duration of audio/video files like
hh:mm:ss ? my point is, seconds are missing for files > 1h.
greets, kurt. Pioneer PDP-427 XA | Popcorn Hour NMT C-200 | Sony STR-DB 840 QS | Canton Ergo 91 DC |
6th December 2009, 13:47 | #604 | Link | |
Feature request is already done, with "debug" --> "Advanced Mode" (or -f for CLI): Code:
Duration : 6636960 Duration : 1h 50mn Duration : 1h 50mn 36s 960ms Duration : 1h 50mn Duration : 01:50:36.960 Code:
Duration : Play time of the stream in ms Duration/String : Play time in format : XXx YYy only, YYy omited if zero Duration/String1 : Play time in format : HHh MMmn SSs MMMms, XX omited if zero Duration/String2 : Play time in format : XXx YYy only, YYy omited if zero Duration/String3 : Play time in format : HH:MM:SS.MMM
6th December 2009, 19:15 | #606 | Link |
sidekick
same here. why would it be useful to hide such a information? would it bloat the gui? I guess not... If you mux videofiles with audio tracks of other files it is very useful to get the exact duration.
anyway, thx for the hint with the debugging mode
6th December 2009, 19:19 | #607 | Link |
Zenitram,
Would it be possible to identify MPEG-4 ASP encodes generated with multiple B-VOPs separately from those encoded with just 1B-VOP? Cheers
6th December 2009, 19:19 | #608 | Link |
If I obey to everybody, I would have all that is in the "debug" version, and I would display 4 times the duration... Some people want hour+minutes, some other the exact value (seconds are not enough, milliseconds are needed).
This depends a lot from the "profile" of users, on Doom9 people want exact value, but on some other forum (more newbee), they want "logic" value ie only a rounded value. This is the reason I add a custom text. LAter, whan I have time, I plan to customize the "Easy" view with you own template too, so everybody would be able to have its perfect "Easy" view :-D.
6th December 2009, 19:26 | #609 | Link | |
BVOP = No BVOP = Yes. You would like to have: BVOP = No BVOP = 1 frame BVOP = 2 frames ... ?
6th December 2009, 19:33 | #610 | Link | |
If it possible for you to identify the actual quantity of consecutive b-frames, that would be very useful for bug testing streams for use in hardware players
6th December 2009, 19:38 | #611 | Link | |
But I don't currently parse the whole file (very long), only the 30 first frames, if there is 1 bframe only between I/P frames, can I say there is 99% chance to have only 1 bframe between I/P frames for the whole file?
6th December 2009, 22:00 | #612 | Link | |
sidekick
7th December 2009, 21:06 | #613 | Link | ||
Does it really disturb them ? I doubt it. However it would be a really helpfull information without the need to switch between tabs each time we open a file. Quote:
Say 60 frames ? After all that's only one second of a video at ~60 FPS. |
7th December 2009, 21:26 | #614 | Link | |
And why should I accept seconds and not milliseconds too? Some other users have asked for the precise duration in milliseconds, they say that seconds are not enough (and some others, in seconds + frames, not yet implemented but planned, because milliseconds are not interessant). Every user says that his point of view is the more logic point of view and that all other users are stupid... ;-). Again, I know I have multiple kinds of users, multiple "profile sets" are planned. And if you are in hurry, you can compile your own version of the DLL, this is only one line of code to change, this is open source . I can go up to 60 fps, yes. I will do some tests in order to see if this has no big impact on performances.
Want to know all about your media files? http://mediaarea.net/MediaInfo Last edited by Zenitram; 8th December 2009 at 00:35. Reason: typo :) |
8th December 2009, 00:15 | #616 | Link |
I actually require the "milli-second" bit
8th December 2009, 00:37 | #617 | Link |
Oups
One day, maybe, I will know how to speak good english...
8th December 2009, 00:39 | #618 | Link |
eh eh... This is a lot requested feature here... I promiss I don't forget this "profiles" feature, but days are only 24 hour long!
15th December 2009, 04:56 | #620 | Link |
0.26 beta still show "Resolution" field for AAC inside MP4 videos or M4A podcasts, it is hiddenly only when viewing raw .aac files (adts)
no such problem with mp3 and mp3 inside avi no such problem with ac3 and ac3 inside mkv |
