#2 | Link |
Big Bit Savings Now !
https://sourceforge.net/projects/ffmpeg-batch/files/
FFmpeg_Batch_AV_Converter_Portable_3.0.7_x64 -> Tools -> Image extraction wizard For the burnt-in subs you will want to generate an AviSynth Script tailored to your needs and feed that to the abovementioned GUI.
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 5th August 2024 at 21:25. |
#4 | Link |
This assumes that you write the text to burn in:
v=LWLibavVideoSource("myfile.mp4") a=LWLibavAudioSource("myfile.mp4") AudioDub(v,a) Subtitle("My desired text here") Code:
v=LWLibavVideoSource("myfile.mp4") a=LWLibavAudioSource("myfile.mp4") AudioDub(v,a) assrender(last, "My subtitle file.srt") MPC-BE is your friend, a thumbnail maker is integrated, with the capability to render subs into the jpg.
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 6th August 2024 at 00:41. |
#6 | Link |
MPC-HC can not render subs into the stills, IIRC.
Image Sequences: VirtualDub can generate these, use the assrender script above. After generation you may throw away the unneeded ones.
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 6th August 2024 at 00:42. |
#7 | Link |
How do I make FFmpeg Batch AV Converter look like this when extracting frames?
https://imgur.com/a/373Kf1x |
ffmpeg, ffmpeg gui, frames, image |
