#121 | Link |
you can always add optional --show-audio-progress switch.
besides most of audio encoders have --quiet switch (opusenc,fhg aac,aften ac3, vorbis,flac) btw thanks for quick response. i wil test it as soon as i can.
#122 | Link |
I'm having a little problem when converting wav that would be over 4GB.
I'm piping audio from an avs script to neroaacencoder, but if I leave the default -wav setting and the audio is too long, it will say the following thing: Code:
avs2pipemod[info]: writing 14504.948 seconds of 44100 Hz, 2 channel audio. avs2pipemod[warning]: audio size over 32bit limit (4GB), clients may truncate audio. ERROR: could not parse WAV file avs2pipemod[info]: finished, wrote 0.011 seconds [0%]. avs2pipemod[info]: total elapsed time is 0.000 sec. avs2pipemod[error]: only wrote 506 of 639668224 samples. Now my problem is that even if avs2pipemod gives an error message, the return value is still 0 meaning there was no errors for DOS so I can't check the %ERRORLEVEL% variable for errors and try again with a lower bitrate. Is there any chance that this could be fixed? Unless it's me who does something wrong when I test it with the following: Code:
"C:\Program Files (x86)\avs2pipemod-0.4.1\avs2pipemod.exe" -wav test.avs | "C:\Program Files (x86)\NeroAACCodec-1.5.1\neroAacEnc.exe" -q 0.42 -if - -of test.aac & ECHO %ERRORLEVEL%
AMD Ryzen 9 5950X and EVGA RTX 3080 with G.skill 64Gb 3600 (2 16x2 kit) on Asrock X570 Taichi with Samsung 980 Pro 500Gb NVMe SSD running Win10 x64 on LG 34GN850-B 34.0" 3440 x 1440 160 Hz Last edited by SamKook; 10th October 2013 at 01:34. |
#123 | Link |
![]() Join Date: Feb 2005
To allow than NeroAacEnc.exe accept wav files greater than 4 GB you need add the parameter -ignorelength:
...neroAacEnc.exe" -ignorelength -q 0.42 -if - -of test.aac ... Edit: BTW the correct extension for output is test.m4a NeroAacEnc can only output audio AAC in mp4 container. Last edited by tebasuna51; 10th October 2013 at 08:53. |
#124 | Link |
Thanks, that make things a lot simpler. I'm not sure how I haven't tried it before since it seem so obvious now that I re-read the help for it.
A different errorlevel in case of errors would still be nice, but much less important now. Thanks for letting me know about the extension. It doesn't change much since it get muxed right after, but it's always better to do things right.
AMD Ryzen 9 5950X and EVGA RTX 3080 with G.skill 64Gb 3600 (2 16x2 kit) on Asrock X570 Taichi with Samsung 980 Pro 500Gb NVMe SSD running Win10 x64 on LG 34GN850-B 34.0" 3440 x 1440 160 Hz |
#125 | Link |
@Chikuzen (or doobry?, i am confused)
First, let me thank you for your great effort. Nice tool. I encountered a strange behaviour while trying to capture output of "avs2pipemod.exe -info somescript.avs" in Python. When the script had audio (via DirectShowSource( ... audio=true)) the output could be captured, but without audio (via DirectShowSource( ... audio=false)) thge cpatured output was always empty. Using the command from commandline showed output everytime. So my question ist: Do you do something to stdout when audio is absent or use different output for info? Update: Well I looked into the source code. And I don't get it. There is nothing done differently, just an additional if-block for audio, put to sdtout the same way as video. Okay, my new crazy theory: The program exits to fast for Python to capture the output somehow if audio is not present, which then would be a problem of Python not your program. This is weird. Greetings Malte PS I do use -info to probe with different scripts to find out which scripts can be used to render a file. Last edited by _argos; 31st December 2013 at 00:36. |
#126 | Link |
I'm using avs2pipemod to put the video info to file:
avs2pipemod -info encode.avs > info.txt Extracting the audio works well. Using the latest version from the above. Last edited by feos; 21st April 2014 at 18:49. |
#127 | Link | |
#128 | Link | |
The script alone loads very well into virtualdub, and audio/video processing works from the normal x264 command line. Also, what's notable is that the same batch and the same avs worked together very well for years. Then it stopped working. I installed another OS and it works on neither. EDIT: Code:
F:\Encode\TASEncodingPackage>AVSMeter encode.avs -i AVSMeter 1.7.7 (AVS 2.6, x86) by Groucho2004 AviSynth 2.60, build:Sep 18 2013 [17:36:36] Number of frames: 235326 Length (hhh:mm:ss.ms): 001:05:22.100 Frame width: 320 Frame height: 224 Framerate: 60.000 (60/1) Interlaced: No Colorspace: YV12 Here's the script: http://pastebin.com/CNAzMuxj Last edited by feos; 21st April 2014 at 20:48. |
#129 | Link |
You have to figure out what change causes the script to freeze. Since you mentioned that the script worked for years, you at least changed the avisynth version. It might be a incompatibility between Avisynth and one of the plug-ins.
#130 | Link |
Reverting to older Avisynth version (2010) doesn't help. But It seems the problem may be in using pass=1. The batch sets that before taking info. And when I set pass=1, the script won't load into virtualdub, telling "ExactDedup: failed to open dupinfo file". However the file is where the script reads it, and it looks ok. So the problem is with ExactDedup plugin. But I backupped the dll too, and it doesn't work, while it did (with whatever avisynth version).
#132 | Link |
It got loaded into virtualdub at pass=1 now, but avs2pipemod still freezes at the same line.
EDIT: It appears even when I do pass=0 (no ExactDedup used), avs2pipemod still freezes after creating the info file... EDIT: Using "info" instead of "-info" prints info into cmd window, but creates only the blank file. Which isn't what I need, because that file is read from, to set SAR according to clip parameters. EDIT: Had to solve it by dropping the FreeSub plugin use. avs2pipemod+freesub+ffmpeg were hanging. Here's some gdb trace: http://pastebin.com/QbPWLqwG. The issue got its workaround. Last edited by feos; 23rd April 2014 at 22:28. |
#133 | Link |
typo lover
new version released
avs2pipemod-1.0.0 - change avisynth_c.h to Avisynth+MT's avisynth.h. - change C99 to C++11. - change mingw-w64 to VisualC++2015. - drop Avisynth2.5x support. - drop WindowsXP support. - drop x264bd and x264raw options. - add Avisynth+MT's new 16/32bit formats support. - add FFmpeg's extended Y4M formats output support. - add '-dll' option. now, avs2pipemod requires VC++2015 runtime (because I decided to avoid avisynth_c.h).
my repositories Last edited by Chikuzen; 22nd July 2016 at 15:12. |
#134 | Link |
typo lover
my repositories |
#135 | Link |
typo lover
updated.
avs2pipemod-1.0.2 - fix calculating video duration of -info. - show avisynth's VersionString() on -info.
my repositories |
#136 | Link |
typo lover
my repositories |
#138 | Link |
typo lover
by Avs+'s warning.
my repositories |
#139 | Link |
Hi all!
Please advice how use avs2pipe with x265. I can write command for rawvideo: Code:
avs2pipemod64 -rawvideo test.avs | x265_64 --input - --input-res 960x720 --fps 50.0 --output video.h265 yup. |
#140 | Link |
typo lover
avs2pipemod64 -y4mp test.avs | x265_64 --input - --y4m --output video.h265
my repositories |
avs2pipe |
