Old 5th September 2009, 14:08   #21  |  Link
Gavino
Avisynth language lover
Sorry I confused you with that. At that point, I was referring to the default length being 1001 frames, and thinking from your 41 secs timing that you probably had set the rate to 25fps yourself. In an earlier post, you had used 29.97.
The actual frame rate used for this probably doesn't matter since you have no moving pictures anyway.
Old 5th September 2009, 14:16   #22  |  Link
Smirky
I used 24fps and 5779 frames. It came out 4:00sec. But the damn audio just won't mux. Some other weird thing: I adjusted CBR in Xvid to 1100kbps and the project size while encoding showed 16MB. After it was done the video was 2.3MB with 87kbps bitrate.
Update: I've found a nice script for that:
# SCRIPT VARIABLES #
audiosource="audio.mp3"
videosource="video.png"
framerate=1
thumbduration=6
# SET AUDIO/VIDEO #
audio1 = directshowsource(audiosource)
duration1 = audio1.Audiolength / audio1.Audiorate
video1 = ImageSource(videosource, end=duration1, fps=framerate).ConvertToRGB32
# ADD MINI THUMBNAIL #
duration2 = (duration1 - thumbduration) / 2
thumb1 = imagesource(videosource, end=thumbduration, fps=framerate).ConvertToRGB32.lanczos4Resize(19,14)
thumb2 = blankclip(thumb1, length=duration2, color=$000000)
thumb3 = blankclip(thumb1, length=duration2, color=$000000)
thumb4 = thumb2 + thumb1 + thumb3
video2=Layer(video1, thumb4)
# RETURN FINAL VIDEO #
return(video2)
But audio still doesn't mux, in Vdub too...
Smirky is offline   Reply With Quote
Old 5th September 2009, 16:15   #23  |  Link
What are you using to mux? What container are you muxing to? What is the error that you receive?
Old 5th September 2009, 16:39   #24  |  Link
Smirky
Ok. I've found scripts made by Frifox out here and they work perfectly. Thx to neuron2 and Gavino for great help and I'm definitely going to get to the bottom of my errors soon and will post as I do.
image, source, static, video, youtube
