Old 24th June 2021, 23:55   #1  |  Link
benwaggoner
Muxing AV1 .ivf into .mp4
What are folks using to mux a AV1 .ivf elementary stream into .mp4? Good old mp4box nightly builds? Any particular parameters?
Ben Waggoner
My Compression Book
Old 25th June 2021, 01:51   #2  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
IIRC I tried this and it works fine, but I don't do AV1 encoding on the regular
Old 26th June 2021, 00:38   #3  |  Link
benwaggoner
Using the default mp4box.exe -add foo.ivf foo.mp4 syntax, the resulting file looks correct in MediaInfo and plays in VLC and the Windows "Movies & TV" player. But it won't open in any of the Adobe Creative Suite apps, even though I have a HW AV1 decoder in my GPU.
I was hoping the new DirectX-based After Effects and Premiere would support generic DirectShow file decoding as it had in years past.
Ben Waggoner
My Compression Book
Old 26th June 2021, 15:17   #4  |  Link
Beelzebubu
I use ffmpeg -i file.ivf -c:v copy file.mp4
Beelzebubu is offline   Reply With Quote
av1, mp4, mp4box, muxing
