Old 15th April 2025, 16:55   #1801  |  Link
lvqcl
Originally Posted by MrVideo View Post
I wonder if the issue is the image type
The real issue is the presence of ID3 tags in your FLAC file. Their presence make it invalid.
Uncheck "Add ID3 tag" option in EAC settings.
lvqcl is offline   Reply With Quote
Old 15th April 2025, 23:32   #1802  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Hopefully there is a new version soon.
Patience is a virtue. I built the new version of MediaInfo tonight, and it indeed seems to fix the problem with your file. New build of LameXP with updated MediaInfo is up now
https://sourceforge.net/projects/lam...29/2025-04-16/
Old 16th April 2025, 02:25   #1803  |  Link
MrVideo
MrVideo's Avatar
Thanks. Downloaded and installed. And yep, the files are now indeed read in.
So, what was MediaInfo's issue? The previous version did work if the ID3 tag wasn't there.
Thanks for your help in getting this figured out.
Old 16th April 2025, 04:02   #1804  |  Link
MrVideo
MrVideo's Avatar
I am correct in assuming that LameXP will not traverse directories looking for audio files?
Old 16th April 2025, 05:31   #1805  |  Link
MrVideo
MrVideo's Avatar
Non-fatal error
Cannot assign process to job: Process is not running anymore!
Failed to assign process to job object!
The job has 339 files to convert to MP3. At about 160 done it started doing the errors. Now, at about 248 left, the error is occurring at pretty much every conversion. As indicated, the error is not fatal, as the conversion takes place.
I figured that I should report it anyway.
Old 16th April 2025, 19:56   #1806  |  Link
LoRd_MuldeR
Software Developer
I'm not exactly sure. The commit that fixed it can be seen here. Seems to be related to the order in which certain things are done.
Depends on whether you select "Open Folder" or "Open Folder Recursively" from the "File" menu, I suppose.
We use a job object to manage the sub-processes started by LameXP. This is mainly done in order to ensure that no "orphaned" sub-processes will be left behind, when the main (GUI) process is terminated for whatever reason. Sometimes it can happen, though, that the new sub-process has already terminated before we even had a chance to assign it to the job object. This is the warning you are seeing. In other words, it is harmless and can be ignored
Old 17th April 2025, 01:16   #1807  |  Link
MrVideo
MrVideo's Avatar
Never use the pulldown menu. I drag-n-drop. I'll have to remember that for next time.
Old 26th July 2025, 16:37   #1808  |  Link
libing114
How to stop the "Check for updates" window?
How to stop LameXP v4.21 from showing the "Check for updates" window every time it is launched? "Disable update reminder" has already been chosen.
libing114 is offline   Reply With Quote
Old 27th July 2025, 12:51   #1809  |  Link
LoRd_MuldeR
Software Developer
Please see here:
https://github.com/lordmulder/LameXP/issues/126
Old 29th July 2025, 01:28   #1810  |  Link
manolito
manolito's Avatar
@ libing114
I used to become a little mad by this intrusive behavior of LameXP, I hardly use it any more, and upgrading is not really an option.
My solution was to use one of those "Clicker Applications" which can automatically click away intrusive messages (I still use the ancient ClickOff app). There is still a small delay before the software starts, but it is quite short and not really annoying...
Cheers
manolito
Old 24th August 2025, 18:15   #1811  |  Link
shiro
~removed double post~
(duplicate of https://github.com/lordmulder/LameXP...ent-3218243384)
shiro is offline   Reply With Quote
Old 24th August 2025, 19:44   #1812  |  Link
LoRd_MuldeR
Software Developer
There is no need to double-post! I have already replied to your comment on GitHub:
https://github.com/lordmulder/LameXP...ent-3218295391
Old 17th January 2026, 02:54   #1813  |  Link
MrVideo
MrVideo's Avatar
Is there a new beta available? Currently running 4.22 Beta 1 build 2389. The update check fails as it can't connect to the server.
Old 17th January 2026, 17:32   #1814  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.22 Beta-2
https://sourceforge.net/projects/lam...29/2026-01-17/
Changes between v4.21 and v4.22:
* Updated MediaInfo to v25.03 (2025-03-21), compiled with ICL 2024.2 and MSVC 16.11
* Updated cURL to v8.18.0 (2026-01-07), with libcurl v8.18.0 and OpenSSL v3.5.4
Old 18th January 2026, 10:35   #1815  |  Link
MrVideo
MrVideo's Avatar
aac, aotuv, flac, lame, lamexp, mp3, mp4, ogg, oggenc, opus, vorbis
