19th September 2009, 18:52 | #1 | Link |
Radeon HD 4550 DXVA corruption
Hi everyone. I'm helping someone put together an HTPC out of some various old parts (Athlon X2, 2GB, nForce 4 chipset) and a new GPU (HD 4550) and it works quite well - except when we try and use DXVA. We end up with serious corruption issues in a lot of MKV-encapsulated H.264-encoded content. Blu-ray discs play perfectly fine.
We've tried this on both Windows 7 and Vista, x64-versions both, and with the latest Catalyst 9.9 drivers. We tried with the release and SVN builds of MPC-HC and with Divx's beta MKV filter for Media Foundation. This corruption only appears when using DXVA; software decoding works fine but that machine doesn't quite have enough power for software decoding. We also tested the videos on a desktop machine (Q9550, 8GB, P45 chipset, HD 4870) and they played flawlessly. I've also tried GraphStudio using both the MPC-HC filter and Microsoft's H.264 decoder. Both gave corruption. Any suggestions on what to do besides buying a new GPU? Example MediaInfo: Code:
General Complete name : Z:\video\Anime\Macross Frontier\Macross_Frontier_Ep06_Bye-Bye_Sheryl_[720p,BluRay,x264]_-_THORA.mkv Format : Matroska File size : 550 MiB Duration : 24mn 9s Overall bit rate : 3 185 Kbps Movie name : Macross Frontier ep. 06 Encoded date : UTC 2008-10-31 10:47:14 Writing application : mkvmerge v2.3.0 ('Freak U') built on Sep 8 2008 18:32:16 Writing library : libebml v0.7.7 + libmatroska v0.8.1 Cover : Yes / Yes / Yes / Yes / Yes Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 8 frames Muxing mode : Container profile=Unknown@4.1 Codec ID : V_MPEG4/ISO/AVC Duration : 24mn 7s Bit rate : 2 802 Kbps Nominal bit rate : 2 860 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.127 Stream size : 484 MiB (88%) Writing library : x264 core 65 r999M cc51047 Encoding settings : cabac=1 / ref=8 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=9 / psy_rd=0.9:0.0 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=6 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=2860 / ratetol=1.0 / qcomp=0.60 / qpmin=9 / qpmax=40 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.70 Language : Japanese Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Codec ID : A_AC3 Duration : 24mn 9s Bit rate mode : Constant Bit rate : 320 Kbps Channel(s) : 2 channels Channel positions : L R Sampling rate : 48.0 KHz Stream size : 55.3 MiB (10%) Language : Japanese Text ID : 3 Format : ASS Codec ID : S_TEXT/ASS Codec ID/Info : Advanced Sub Station Alpha Language : English And a MediaInfo dump of a file that does work: Code:
General ID : 0 Complete name : Z:\video\BD-Rips\Kung Fu Panda.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 20.7 GiB Duration : 1h 32mn Overall bit rate : 32.2 Mbps Maximum Overall bit rate : 48.0 Mbps Video #1 ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Duration : 1h 32mn Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive colour_primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177 transfer_characteristics : BT.709-5, BT.1361 matrix_coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177 Video #2 ID : 6912 (0x1B00) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.2 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Duration : 1h 32mn Width : 720 pixels Height : 480 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Standard : NTSC Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive colour_primaries : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M transfer_characteristics : BT.601-6 525, BT.601-6 625, BT.1358 525, BT.1358 625, BT.1700 NTSC, SMPTE 170M matrix_coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M Audio #1 ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Format profile : TrueHD Duration : 1h 32mn Bit rate mode : Variable Bit rate : 640 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Surround: L R, LFE Sampling rate : 48.0 KHz Stream size : 422 MiB (2%) Audio #2 ID : 4353 (0x1101) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Duration : 1h 32mn Bit rate mode : Constant Bit rate : 640 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Surround: L R, LFE Sampling rate : 48.0 KHz Stream size : 422 MiB (2%) Audio #3 ID : 4354 (0x1102) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Duration : 1h 32mn Bit rate mode : Constant Bit rate : 640 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Surround: L R, LFE Sampling rate : 48.0 KHz Stream size : 422 MiB (2%) Audio #4 ID : 4355 (0x1103) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Duration : 1h 32mn Bit rate mode : Constant Bit rate : 640 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Surround: L R, LFE Sampling rate : 48.0 KHz Stream size : 422 MiB (2%) Audio #5 ID : 4356 (0x1104) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Duration : 1h 32mn Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : L R Sampling rate : 48.0 KHz Stream size : 127 MiB (1%) Audio #6 ID : 6656 (0x1A00) Menu ID : 1 (0x1) Format : E-AC-3 Format/Info : Audio Coding 3 Duration : 1h 32mn Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : L R Sampling rate : 48.0 KHz Stream size : 127 MiB (1%) Text #1 ID : 4608 (0x1200) Menu ID : 1 (0x1) Format : PGS Text #2 ID : 4609 (0x1201) Menu ID : 1 (0x1) Format : PGS Text #3 ID : 4610 (0x1202) Menu ID : 1 (0x1) Format : PGS Text #4 ID : 4611 (0x1203) Menu ID : 1 (0x1) Format : PGS Text #5 ID : 4612 (0x1204) Menu ID : 1 (0x1) Format : PGS Text #6 ID : 4613 (0x1205) Menu ID : 1 (0x1) Format : PGS Text #7 ID : 4614 (0x1206) Menu ID : 1 (0x1) Format : PGS Text #8 ID : 4615 (0x1207) Menu ID : 1 (0x1) Format : PGS Text #9 ID : 4616 (0x1208) Menu ID : 1 (0x1) Format : PGS Text #10 ID : 4617 (0x1209) Menu ID : 1 (0x1) Format : PGS |
19th September 2009, 20:41 | #2 | Link |
Angel of Night
Sorry, your first video falls under our rule 6 on illegal content, so we can't help you. I do know nvidia supports higher AVC levels but I don't know if that's applicable to your case.
4550, dxva, radeon |
