Old 20th December 2022, 14:35   #1  |  Link
RGMOfficial
RGMOfficial's Avatar
Remove antialiasing from Subtitle
I'm trying to do an simulation of analog test text on-screen, but there's a problem:
I need to remove the antialiasing from the text, but i don't know how.
Can you guys help me?
ColorBars(width=640,height=480,pixel_type="YUV444").ChangeFPS("ntsc_double")
text = BlankClip(last, pixel_type="YV24", color=$000000, width=(StrLen("01:00:58:00")*13)*2, height=20*2).ChangeFPS(FrameRate(last)/2)
text = text.ShowSMPTE(offset="01:01:00:00",font="VCR OSD Mono",text_color=$FFFFFF,halo_color=$FFFFFFFF,size=21*2,y=18*2)
text = text.ChangeFPS(FrameRate(text)*2)
#text
SeparateFields()
text = text.SeparateFields()
Overlay(last,text,x=(width()/2)-(width(text)/2),y=height()-48)
Weave()
LanczosResize(720,height())
AviSynth+ Projects:
DotCrawl++
RGMOfficial is offline   Reply With Quote
Old 20th December 2022, 17:47   #2  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
ShowSMPTE() is based on Subtitle(), and yes, Subtitle() renders with antialiasing out of the box.
Maybe this Avisynth internal filter could be recompiled to make antialiasing switchable,
but can also be that the underlying function CreateFont() (Visual C++) already has this baked in ?
Old 20th December 2022, 19:37   #3  |  Link
DTL
To skip most of AA you can rasterize in higher size (like 3..10x larger) and PointResize() to required output size.
Something like
text = text.PointResize(text.width*10, text.height*10)
text = text.ShowSMPTE(offset="01:01:00:00",font="VCR OSD Mono",text_color=$FFFFFF,halo_color=$FFFFFFFF,size=21*2*10,y=18*2*10)
text = text.PointResize(text.width/10, text.height/10)
Old 20th December 2022, 19:50   #4  |  Link
RGMOfficial
Thanks guys.
AviSynth+ Projects:
DotCrawl++
Old 20th December 2022, 20:56   #5  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
That's no guarantee though - you still might end up with grey pixels. You could add this expr on it before downscaling:
expr("x 128 > 255 0 ?", "128", "128")
That font seems a little off though - the diagonal line on the 0 seems to leave a half-"pixel" gap which I'm not sure is accurate.
wonkey_monkey is offline   Reply With Quote
Old 21st December 2022, 16:53   #6  |  Link
Emulgator
Emulgator's Avatar
Yes, these suggestions together work beautifully.
Only the last LanczosResize has to go, because it introduces grey pixels again.
text = text.expr("x 128 > 255 0 ?", "128", "128")
#text = text.ShowSMPTE(offset="01:01:00:00",font="VCR OSD Mono",text_color=$FFFFFF,halo_color=$FFFFFFFF,size=21*2,y=18*2)
#text
SeparateFields()
Weave()
#LanczosResize(720,height())
Old 15th January 2023, 19:06   #7  |  Link
RGMOfficial
Oh, very thanks.
AviSynth+ Projects:
DotCrawl++
analog, antialiasing, avisynth, subtitle
